Question about LG LRBN22514ST Bottom Freezer Refrigerator
Frizey is right but cool r not found - LG LRBN22514ST Bottom Freezer Refrigerator
    Guru:
  • 683 Answers
Please tell me what you are trying to say, and i will help you.
Posted on Mar 16, 2011
Rm2852 not cooling and makes a noise like a water pipe with air
The noise you bear is the ammonia and hydrogen trying to circulate. Check k the backside of the unit for yellow residue. If this is found then your cooling unit is leaking and must be replaced. If it is gurgling and not cooling it may be clogged. You can try "burping" the unit. To do this you will have to remove the refrigerator from the cabinet. Make sure the gas is turned off and all power is disconnected from the unit prior to removing from the cabinet. Once the unit is out turn it upside down and let set for a few minutes. The turn it right side up. Repeat this process a few times. Then reinstall, right side up. Reconnect power and L.P. lines. Use a soapy water mix to check for gas leaks. Once installed allow the unit to set for a few hours before turning on. This is not a guaranteed fix and if it does work it may not last long... the only sure fix is to replace the cooling unit.
Mar 14, 2014 | Dometic RM2852 Refrigerator
Overheating
Stuck Relay for electric cooling fan. Dirty connections from Fan relay to cooling fan.
Feb 27, 2014 | 1997 Ford Windstar
My 2004 pontiac grand am cooling fan doesn't work what do i need to do
The cooling fan can be run through a self diagnostic by a dealer using a special tool called a scanner, it will then deliver back to the tech what is found, this can be any number of things, the fan motor wiring to it or the controller for the fan. Guessing is not an option and if you keep overheating this engine you will shortly need a new one.
Jul 18, 2012 | 2004 Pontiac Grand Am
I have a code 21 that tells me cooling temperture system
A code 21 is a TPS circuit(signal voltage high). Check for sticking or misadjusted TPS. Check all wiring and connections an the TPS and the ECM. If all is good replace the TPS. I dont know how you found that the code is for the cooling system but it is not right.
Dec 26, 2010 | 1994 Hyundai Excel
On 2000 4runner, i changed the water pumr ,thermastat, and timeingbelt the problem i am having is heat . When i pull both heatercore hoses i do not get any flow of coolant untill i rev the motor ,i tried...
There is an air pocket trapped in the cooling system. I have found that if I splice a flushing tee, found at the auto parts store, into the upper heater hose, and fill the cooling system, it usually bleeds the air out of the system.Is the t-stat installed properly?
Jan 07, 2010 | 1990 Toyota 4Runner
Camper fridge will not cool down(unsure of model)
ok firstly if you remove the element and give it 110v does it warm up if it warm up and still not making the fridge cold the propane chemicals are not right any more
May 15, 2009 | Dometic WA3210 Compact Refrigerator
After driving for 25-30 minutes, the car won't start for about 3 hours
Any chance you've got 'Titanium' spark plugs. We had this same issue, and found it was caused by a mechanic replacing our plugs with the titanium ones. If they were hot, they didn't ignite properly during startup. If you let the car cool, it would start right up (~2 hours). Changing the plugs for good quality old-style plugs and the problem hasn't occurred since.
Aug 01, 2008 | 2000 Saturn SW2
Honeywell 88031 is not cooling. Fuse may be blown.
opj38 -
Thanks, I used your hint/tip.!!!
I have a Honeywell 88031, it was flickering the light, buzzing intermittently and not cooling.
I took the back cover off and looked at the capacitor you mentioned. (Right by the Heatsink)
It was bulged and buckled outwards. Marked 1000uF 16V
I looked around in the junk parts I have laying around and found a 1000uF 10V Capacitor. I put it in and now it works normal and cools.
I suppose I should get one rated for 16 or 25 V, but for now I am going to see if it will stay running or ?
Good Luck to others with this problem.
May 19, 2008 | Refrigerators
Only bottom part is cool
The next step is to replace the thermostat timer thats causing the build up on your freezer . hope this helps AJ
May 12, 2008 | GE GSH22SGRSS Side by Side Refrigerator
I found it
coolness..
see this site for more neat self help desk stuff.
Feb 18, 2008 | Office Equipment & Supplies
LG LRBN22514ST Bottom Freezer Refrigerator Logo
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
