Question about Samsung RS2630SH Side by Side Refrigerator
It was getting hot so I unplugged it to reset it and now it won't come back on
    Guru:
  • 683 Answers
Do you hear any clicking or and thing when you try to start it, let me know. I will help you.
Posted on Mar 16, 2011
Tv won,t come on makes beeping noise
Try unplugging from outlet for fifteen seconds. Press the power button for a few seconds "before" plugging back in. Now plug back into the wall outlet and try turning it on to see if this reset the TV's settings.
Sep 28, 2014 | Emerson Televison & Video
No power door won,t open
unplug the washer for 30 mins or so and then plug it back in to see if it wil reset it self. does the light come on inside at all.
Jun 10, 2014 | Samsung Washing Machines
Reset frigidaire dishwasher model FDB1100RHC
I had the same issue. I unplugged the dishwasher and plugged it back in. Bam! It's working fine now.
Oct 16, 2012 | Frigidaire Dishwashers
THere is no electricity in the bedrooms and I can't get them back on?
If the circuit breaker will not reset - all the way off and then back on with a click sound. Then something you have plugged into the outlets in those rooms is probably shorted causing an over current condition. If the circuit breaker won't reset, shut off all lights and then unplug EVERYTHING and then see if it will reset. If it does, then replug everything one at a time until the electricity goes off again, that is the bad apple.But if it won't reset, then your breaker is probably bad. Yes, they do go bad, just infrequently.
Jan 11, 2012 | CUTLER HAMMER BR4040B200V BREAKER CIRCUIT...
My son put a load of laundry in and forgot the hot water heater was broke when he turned the machine on. It wouldn't run and the door is still locked. We tried unplugging it, holding the cancel butt
Remove the lower panel by taking out the screws at the bottom. Unplug washer. Then reach up inside to the bottom of the door switch and pull down on lever to unlatch the door. Try running machine again after plugging back in.
Nov 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
2005 mustang is overheating and shutting off. Turned the key and it won't stay on. I noticed that the fan might not be turning on. How do I troubleshoot? I put water in the radiator and didn't...
It could be a leak, check your radiator for any leaks, also check upper and lower radiator hoses, water pump, etc. But you said the fan doesn't kick on even when it's reading "hot". So I would look into that more. route the wires and locate the plug, make sure it's plugged in, or reseat the cable by unplugging, and replugging it back in. You could also unplug the negative cable on the battery terminal for a few seconds in attempt to reset the ECU (computer).
Oct 21, 2011 | 2005 Ford Mustang
I'm trying to reset my password on the router and it won't save the new password. It keeps defaulting back to a generic password or none at all.
Try to reset using the little reset hole in the back and then after reset power cycle it ( unplug it for about 2 minutes then plug it back in let me know if that works
have you saved it on the webaccess page?
also did you hold in reset button for at least 30 seconds?
May 20, 2011 | Linksys Wireless-G WRT54G Router
Dual control ac blows hot air 2004 chev silverado
try this, it may work ,may not. unhook the battery for a few minutes, then hook it back up.. now turn the key on, but dont start the truck for 2 minutes. now start the truck, it may reset????
Sep 22, 2009 | 2004 Chevrolet Silverado 1500 Crew Cab
My powershot G9 built in flash is not working
There is a switch on the hot shoe to detect the external flash. When you use an external flash, the switch will be pressed down, then the unit will bypass the internal flash and won’t let it fire. If the little switch gets stuck somehow, you won’t get your internal flash on.
Check this switch on the hot shoe (either on the left side or the right side), blow some compressed air then plug/unplug an external flash several times. Hopefully you can get it back
Feb 06, 2009 | Canon PowerShot G9 Digital Camera
Samsung RS2630SH Side by Side Refrigerator Logo
27 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
