Question about Husqvarna Riding Lawn Mower 42 Inch Cut Yth2042
Were is the battery at in a ct151 - Husqvarna Riding Lawn Mower 42 Inch Cut Yth2042
    Brigadier General:
  • 3,911 Answers
Open the hood exposing the engine. it is right behind the engine almost under the dashboard. there is a rubber strap holding it down and two bolts holding the cables on. remove the negative cable first, then the positive, then the strap and lift it out. install in reverse order.
Posted on Mar 16, 2011
Kohler ride on mower ct151 not running smooth when idling it keeps revving every 2 seconds and dyes back again have cleaned plug and filter ???
Sounds like tick over speed is running to slow adjust till it runs smoothly,also u might like to adjust the air screw just a possibility also make a note how many turns u do just in case u go to far then u can put back as was
Oct 13, 2013 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Ct151 keeps reving and idle
Check plug and clean and re gap also a clean filter will help some times mixture to rich dirty filter ,
The other thing u could o if filter and plug is ok adjust idle speed up till it runs smooth ,1 last thing adjust air screw turn both ways till it runs smooth
Engine of my husqvarna CT151 ride on mower starts and runs fine but cuts out when any load is applied i.e. put into drive gear or into cutting mode
This sounds much like a micro switch issue, make sure the block connector on the seat micro switch is pushed completely on, if this does not help make sure you are sitting squarley in the centre if the seat so as to push the switch in, if all else fails replace the switch.
Aug 06, 2011 | Garden
I need a new battery for my 1986 Oldsmobile ninety-eight regancy sedan. fully loaded. what type of battery would i need?
Attributes Battery BCI # : 75
Battery CA @ 32 Degrees F : 775
Battery CCA @ 0 Degrees F : 630
Battery Height : 7 1/4"
Battery Length : 9 3/4"
Battery Posts Type : Side Post
Battery Reserve Capacity : 90
Battery Voltage : 12 volt
Battery Weight : 33 lbs.
Battery Width : 7"
Wet or Dry : Wet
A lead acid battery with the fallowing specs
group 75
Battery Width : 7"
Wet or Dry : Wet
Battery Width : 7"
Wet or Dry : Wet
Battery BCI # : 75
Battery Width : 7"
Wet or Dry : Wet
Feb 27, 2011 | 1986 Oldsmobile Regency
Husqvarna CT151 Smoking
the belt is smoking because a pulley isnt spinning like its supposed to. its gonna break the new belt if you don't remedy the problem. try taking the belt Back off. then see if you can spin the pulleys by hand with no belt .
Jul 31, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
I cant replace the deck belt on my husqvarna ct151 lawn mower. the old one snapped and i have no idea what way the new one goes on around the pulley wheels.
The manual shows how the belts are put on, if you do not have one they may be purchased through dealers or small engine repair shops or online. On mine there is also a little diagram on the top of the mower deck. Another way to check is find an identical one that is functional and look at its belt. There are only so many ways it could fit and these are all made by just one or two manufacturers so there is not much variance.
Jun 01, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Nikon D40x indicate battary low
Rechargeable Lithium-ion 7.4V 1000mAh Nikon D40x battery for sale,20% off! Full one year warranty! For more info visit: http://www.nikon-coolpix-replacement-battery.com/d40x.htm
May 13, 2009 | Nikon D40x Digital Camera
Need a belt diagram for a CT151
Hello barryhenness
You can View the Husqvarna Model List at this Site Addy, http://www.partstree.com/parts/ and Click on the Husqvarna Logo. Now Enter the Model Numbers in the Search Box on the Left and Click Go. Now Select the Model of the Equipment you Wish to View. These Breakdowns Usually have a Good View of the Belt Routing.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Apr 19, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna Riding Lawn Mower 42 Inch Cut Yth2042 Logo
113 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
