Question about Texas Instruments TI-84 Plus Calculator
I have installed the new operating system on my TI84 Silver Editions. It will not convert the square root of 5 to a fraction (thank goodness) but it does convert the square root of 720 to a fraction :( This did not happen with the old operating system.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
The calculator is showing you its best fractional approximation to the number. To not have it do that, press MODE, up-arrow four times to get to the "ANSWERS:" line, use left/right arrow to highlight "AUTO" then press ENTER. Press 2ND [QUIT] to exit the mode screen.
Posted on Mar 16, 2011
30xiis decimals square root
In general you cannot. If the square root happens to be an integer (ex: SQRT (4)=2) or a rational number (SQRT(16/9)=4/3) you can convert from one form to the other, but that is the same as converting from a decimal to a fraction.
However you can never convert 1.414213562 (the first 10 digits of SQRT(2)) into the radical SQRT(2). The reason is that root here is an irrational number: its decimal representation is endless and not periodic (non repeating).
Nov 17, 2013 | Texas Instruments TI-30 XIIS Calculator
Convert decimals fractions standard form
If you are concerned about fraction handling and conversion to decimal representation, upgrade the OS of your calculator to 2.5x MP. As to handling of irrational numbers (such as square roots) you should visit the TIcalc.org website to look for any 3rd-party program that can do that.
Oct 03, 2013 | Texas Instruments TI-84 Plus Calculator
Installing
Try to find a classmate who has the same calculator (TI84 Plus or TI84 Plus Silver Edition) and effect a transfer of the OS from the classmate's calculator using an IO cable.
Alternatively, download the new version of TI Connect (version 4.) and install it on your computer. Then connect your calculator to the computer through the USB cable. When it recognizes the calculator click the update button in TI Connect interface and select update OS. Good luck.
Sep 27, 2013 | Texas Instruments TI-84 Plus Calculator
My ti-83 stop changing decimals to fraction
The Frac command only works if the number can be expressed as a fraction with no more than three digits in the denominator. Since the square root of 5/9 is an irrational number, it cannot be expressed as a fraction at all. The calculator is telling you that the value cannot be adequately approximated as a fraction with three or fewer digits in the denominator.
Jan 14, 2013 | Texas Instruments TI-83 Plus Calculator
How do you convert decimal complex numbers in TI-84 (OS 2.53) to fractions?
I answered a similar question not long ago and here is what I wrote:
Not quite true for OS 2.56 MP for the TINspire with Ti84 keyboard. To convert a complex decimal value, that you just calculated, into a fraction use the command Math [1:>Frac] and it will convert the value to complex fractions
See below.
I suggest you upgrade the OS to version 2.55 MP.
Mar 06, 2012 | Texas Instruments TI-84 Plus Silver...
Error when converting complex numbers to fraction form With mode in a+bi form, when dividing two complex numbers, the answer is displayed in decimal form. The old operating system would allow the decimals...
See below.
Oct 27, 2011 | Texas Instruments TI-84 Plus Silver...
How do I graph equations like x^2 + y^2 = 9 on my TI84 Plus silver calculator?
This is the equation of a circle centered on (0,0) and with radius r=3. You can draw it as a conic section.For that you will need the conics application. Look for it on education.ti.com
You can also draw it as two branches: y1=+ square root (9-x^2) and y2=-square root(9-x^2). The two parts may not overlap at the points on the the x-axis, but if you are willing to accept the calculator limitations you will have your graph.
May 21, 2011 | Texas Instruments TI-84 Plus Silver...
How do i convert the answer of cos(30) which comes out to 0.8660254038 to a fraction?
I am sorry, my friend, but you are asking the impossible. The reason is that the exact value of cos(30 deg) is equal to square root (3) /2 which cannot be fraction (the square root of 3 is an irrational number).
However, it may be possible for your calculator to give you a result with a radical (3)/ 2 but that is no fraction. (A fraction must have both numerator and denominator as integers).
To get a radical result set the IO mode to MathIO.
Press [SHIFT] [MODE] to open (SETUP) and select [1:MathIO]
Feb 18, 2011 | Casio fx-300ES Calculator
How do a take a division problem and square root it on a TI-84 Plus Silver Edition for example 87.34/5 then square root the answer. I can do the math, but how do I take the dvision answer and square...
Two ways:
2ND [square-root] ( 8 7 . 3 4 / 5 ) ENTER
8 7 . 3 4 / 5 ENTER then 2ND [square-root] 2ND ANS ENTER
The first sequence takes the square root of 87.34/5, the second sequence calculates 87.34/5 then takes the square root of the result.
Dec 15, 2010 | Texas Instruments TI-84 Plus Calculator
Texas Instruments TI-84 Plus Calculator Logo
66 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
