Question about Honeywell Heating & Cooling
How do I install a honeywell thermostat TH8110U1003
  • 17,970 Answers
* Click Here for the Owners Manual
* Click Here Installation Instructions
Hope this helps to solve it; good luck.
Posted on Mar 16, 2011
  • ZJ Limited
    ZJ Limited Mar 16, 2011
    An generic comment, is that you will need to do is go to the indoor fan section. Turn off power
    to it and open the access panel. Locate the thermostat terminal board,
    it will have similar connections as the thermostat sub base.
    The R
    terminal will have one of two wires from the control transformer
    attached to it. There will be a second wire from the transformer
    connected to another terminal. We need to know which terminal it is
    connected to and identify the wire color from it to the thermostat. It
    will either be the brown or blue wire, most likely the blue. This wire
    will connect to the C terminal of the new stat and O/B will not be used,
    this terminal is for a heat pump and the brown will not be used at all
    if the blue is in fact the common transformer wire.
    All other
    connections are the same for each terminal. Good luck.
Heating& CA
would think that the thermostat has failed .
Jul 07, 2016 | Honeywell Air Purifiers
My thermostat showing on screen 76F when really room temperature is 70F and I HAVE MEASURED PROPER room sensor resistance OHMS to real room temperature. Why thermostat showing higher temperature and n
Where is the thermostat in relation to the return? Is there air flow or is the air stagnant in the area of the thermostat. Have you placed a thermometer in varios locations where the thermostat is located? Try these locations and see if the thermostat needs to be placed in a location better able to reflect room temperature. Also how long have you lived in the house? If it is a newer home I suggest that you contact the builder or the air conditioner/heater installer to see if they have a schematic of the placement of the thermostats.
Nov 25, 2014 | Honeywell TH8110U1003 VisionPRO 1H/1C...
Lost the Schedule Function How do i get it back? This is for the thermous stat TH8110U1003 Also need a copy of the User Guide How do I get one?
Well here is where you can get the manual for your Honeywell thermostat in PDF format http://customer.honeywell.com/techlit/pdf/PackedLit/69-1894EFS.pdf
You should be able to press "cancel" or "sched" to bring back the schedule function. It will display "following schedule" on the right side of the display when the schedule is on. If you press "sched" then "edit" you can make changes to the programming schedule.
May 14, 2010 | Heating & Cooling
Honeywell th8110u1003 touch screen frozen working but cant adjust at all
It sounds "locked". Refer to the installation/setup manual that came with the tstat for information on how to lock and unlock the thermostat.
Apr 06, 2010 | Honeywell Programmable Thermostat Heater
How do you reset a honeywell th8110u1003 thermostat honeywell 800 # will not tell me but he said it needed to be reset because off ee code on screen
http://www.pexsupply.com/Honeywell-TH8110U1003-VisionPro-Thermostat-1-Heat-1-Cool-3909000-p YOU MAY FIND THE ANSWER HERE BUT IF NOT YOU CAN FIND IT RESET BUTTON IN THE (FURNACE?) UNIT. THE REASON HONEYWELL WILL NOT GIVE THE INFORMATION IS BECAUSE THIS CONDITION USUALLY MEANS THERE IS A PROBLEM IN THE SYSTEM AND GAS IS NOTHING TO FOOL AROUND WITH. FYI HAVE YOUR IGNITER CHECKED OUT.
Mar 05, 2010 | Honeywell Programmable Thermostat Heater
How to program Honeywell thermostat for remote sensor
Remote Sensor (Setup Function 0340): If an optional outdoor sensor is installed, the thermostat can display the outside temperature. If an optional remote indoor sensor is installed, the thermostat will display the temperature at the sensor location (the internal sensor in the thermostat is not used).
\ 0 No remote sensor
1 Outdoor sensor (display only)
2 Outdoor control sensor (select heat pumps
Dec 31, 2008 | Honeywell Heating & Cooling
How do I change the temperature range on a Honeywell TH8110u1003 thermostat. The range now won't let me go below 77 in AC mode.
Try adjusting the heat range up. Set it a 77 then try the cool.
I believe the Honeywells have a max range between cool and heat.
also sometimes there is a lock out code on them you'll need the book.
Good luck
May 20, 2008 | Honeywell Heating & Cooling
Heating & Cooling Logo
117 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
