Optical mouse model PD430P Disconnected mouse to clean tower! Upon replacement of connection failure to find contact to mouse ! No power 1have reconnected several times ! like no power available !
  • 27,725 Answers
You might have to uninstall the mouse then restart your computer then reinstall the mouse and its drivers
click start control panel administration tool computer managenent device manager scroll to mice and other pointing devices you might see a yellow question mark? right click to update drivers
make sure the lead from the mouse has a secure seating and the lead is not bad/faulty
(if applicable)
click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver
make sure the battery is good (has full charge)also you might test the usb device for the mouse is inserted correctly into the usb port (if applicable)
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot also you can select properties under driver you will have options to update driver,rollback driver or uninstall and under hardware you can troubleshoot
in xp hope this helps
Posted on Mar 16, 2011
Tower turns on but screen says no signal?
Check to be sure your monitor connection needles are seated properly. Is mouse wireless or connected to back of tower?
Jan 02, 2014 | Acer Aspire X3200 PC Desktop
Use LogitechMX3000 with optical mouse. The mouse has stopped working. Keyboard OK. I have replaced batteries. Help please How can I use keyboard to do mouse functions whilst mouse does not work?
Hi, I suggest you to contact the Logitech support for a replacement this is an hardware failure and it's covered by warranty terms.
If you are not under warranty you still can contact them as I know for instance in Europe they can offer you some good deal on nowadays products for out of warranty people.
US/Canada support: http://www.logitech.com/en-us/contact
European support: http://www.logitech.com/en-gb/contact
Thanks and have a nice day ! J -
Apr 17, 2010 | Dell Wireless Keyboard Optical Mouse w0147
Replaced Microsoft Wireless Optical Mouse 2000 doesn't work
I would have suggested opening up your old mouse and cleaning the right click button first.
Generally, wireless devices have a connect button that finds the frequencies of the devices. On the receiver press this button, then press the button on the bottom of your new mouse. the receivers lights will stop flashing once connected.
Jul 21, 2009 | Microsoft Wireless Optical Mouse
I need driver for pd430p mouse
Here you are:
http://www.bioticaindia.com/pd430p-optical-mouse.html
Jul 15, 2009 | Micro Innovations PD430PD Mouse
The 2 red lights on the right side of the mouse receiver are on.
usually the receiver is powered via the connection to the pc. ( ps2 style sockets usually green and purple ) dependant upon make/model of wireless. i would suggest replacing the batterys. on the mouse. these do use more power than the keyboard. roughly 5 to 1 or more.
after replacing the batteries. ( 2 x AA Or 2 x AAA ) press the button on the bottom of the mouse, and should have a button on the reciever. to syncronise the pair together.
In regards to your question, you may have 2 lights on the receiver. 1 for transmit, and 1 for receive.
new batteries should solve this problem.
Thankyou for using Fixya.
Mike @ Compurepair.
Jan 05, 2009 | Dell Wireless Keyboard Optical Mouse w0147
MS Optical Mouse 4000 problem; computer mouse pad no longer functional
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
Hope this helps. Bud
Aug 08, 2008 | Microsoft Wireless Optical Notebook Mouse...
Power failure after connecting the mouse
Hi sambi,
If you are currently, working on PS2 mouse port which is the error occurred as stated in your problem. Try to used other PS2 mouse which working on the other pc maybe there was a short circuit on your old mouse. If the problem persist, You can use the alternative way by using USB port to plug your optical mouse.
Try to look for ps2 to usb port converter in the computer stores maybe you can still used your old mouse.
Hope this will be helpful to you.
Best Regards,
Philip
Oct 24, 2007 | Computers & Internet
OPTICAL MOUSE FACING GARBAGE CAN IF IT DOESN'T WORK RIGHT
it sounds like the mouse needs repair but if you could get same mouse or another optical mouse and see if it does the same make sure the area you are using it on is clean and the sensor has direct contact with mouse the model of optical keyboard and mouse i use is a4 tec model the model youv'e got does not last as long the mouse lots of problems with the micro swich buttons after a while they go. if same happens on new mouse then operating system needs re-installing. hope this goes well
Aug 11, 2007 | GE Jasco® 98446 (030878984454) Keyboard...
Computers & Internet Logo
82 people viewed this question
David Payne
David Payne
