Question about Intel XEON X5482 QC LGA 771 3.20 12MBCHIP1600MHZ TRAY
XEON X5482, can it working on my HP xw6400, dual socket 771
System configuration data error
First check the battery.
They have a life of about 5 years.
Second, if you have replaced the battery,
go to Advanced Setup Features in the BIOS.
Select PCI Configuration, and set the Reset Configuration data to YES.
Save, continue, shut down and reboot a second time.
May 26, 2014 | SuperMicro X7DBN-B Dual Lga 771 Xeon/...
System configuration erroe
This is normally the battery.
They last about 5 years
Error 17
"Initialize cache before memory autosize"
This is the cache in the CPU.
The most common cause of this error is the CPU has been overheating.
Check the airflow.
Overheating can destroy the CPU.
Mar 19, 2014 | Tyan S5397WAG2NRF Dual Lga-771 Xeon Ddr2...
Ahci bios not installed
AHCI SATA or USB controller. can install , AHCI Sata is a mode .you can set IDE mode and install Operating system
Apr 25, 2013 | HP xw6400 Workstation - 2 x Intel Xeon...
Single core 2.8ghz xeon to quad core cpu
http://en.wikipedia.org/wiki/Xeon#Prestonia
"In 2002 Intel released a 130nm version of Xeon branded CPU, codenamed "Prestonia". It supported Intel's new Hyper-Threading technology, and had 512KB L2 cache. This was based on the "Northwood" Pentium 4 core."
Meaning it is a Single-Core processor.
http://en.wikipedia.org/wiki/List_of_Intel_Xeon_microprocessors#.22Prestonia.22_.28130_nm.29
Scroll down.
400MegaHertz Front Side Bus. (400MHz FSB)
http://en.wikipedia.org/wiki/Xeon#7300-series_.22Tigerton.22
"The 7300 series, codenamed Tigerton (product code 80565) is a four socket (packaged on Socket 604) and more capable ->
QUAD-CORE processor.................."
http://en.wikipedia.org/wiki/List_of_Intel_Xeon_microprocessors#.22Tigerton.22_.2865_nm.29
1066MegaHertz Front Side Bus. (1066MHz FSB)
The motherboard uses the Intel E7505 motherboard chipset,
http://en.wikipedia.org/wiki/Intel_Xeon_chipsets#NetBurst-based_Xeon_chipsets
Note the - Processor FSB supported -
533MegaHertz
ONLY supports Single-Core processors, too.
The answer is No
Regards,
joecoolvette
Dec 17, 2012 | Computers & Internet
Can I connect two different nvidia graphics with SLI ?
No
They use two different GPU's.
The Nvidia Quadro FX 3700 uses the Nvidia G92 Graphics Processing Unit, (graphics chipset),
http://en.wikipedia.org/wiki/Comparison_of_Nvidia_graphics_processing_units#Quadro
(Scroll down)
,and the Nvidia GeForce GTX7900 uses the Nvidia G71 G.P.U.
http://en.wikipedia.org/wiki/Comparison_of_Nvidia_graphics_processing_units#GeForce_7_.287xxx.29_series
(Scroll down)
You need two LIKE graphics cards to use Scalable Link Interface,
http://en.wikipedia.org/wiki/Scalable_Link_Interface
Scroll down, read under the bold black subheading - Caveats
Nov 22, 2012 | HP xw6400 Workstation - 2 x Intel Xeon...
Dimensions
Dell Support > Dimension 8300 Desktop PC > Main Support Page,
http://support.dell.com/support/edocs/systems/dim8300/sm/index.htm
Left-click on - Technical Specifications - in the list.
Left-click on - Physical - in the list.
Height: How tall the computer tower is. Outside edge to outside edge measurement.
Width: How wide the computer tower is. Outside edge to outside edge measurement.
Depth: How long the computer tower is. Outside edge to outside edge measurement.
If you meant Specifications instead;
A) Processor:
Intel Celeron, or Pentium 4, that uses a Socket 478 processor socket.
Either a 533MegaHertz Front Side Bus, or an 800MHz FSB.
(Dell also indicates the Intel Pentium 4 Extreme Edition processors are supported. Too expensive for what you get in return)
http://en.wikipedia.org/wiki/Socket_478
B) Ram Memory:
DDR Sdram that operates at 333MHz, or 400MegaHertz.
PC2700 and PC3200 respectively.
Maximum TOTAL Amount is 4GigaByte
There are 4 Ram Memory slots. EACH slot has a Maximum Amount of 1GB.
C) Motherboard Chipset:
Northbridge chip: Intel 875P. (Part Number Intel 82875P )
(For Intel the Northbridge chip is the MCH, for this particular Northbridge chipset.
Memory Controller Hub)
The Southbridge chip is an Intel 82801EB (Part Number) or Intel 82801ER (P/N)
Commonly known as the Intel ICH5, or Intel ICH5R.
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Pentium_4_chipsets
In the chart go down on the right side to - 875P
Looking across, and at the headings, you can see under the heading - Processors, that there are more Intel processors supported, than just the Intel Celeron's, and Pentium 4's.
Core2 Duo, Core2 Quad, Core2 Extreme, Pentium Dual Core, and Xeon.
Problem is they don't use a Socket 478 processor socket.
All except for the Xeon ( 'Zee-On' ) use an LGA 775 processor socket.
Xeon models use a Socket 603, or Socket 604, or LGA 771, processor socket.
It is just processors that the Intel 875P chipset will support.
D) Graphics Expansion Slot:
AGP
Uses AGP 8X graphics cards.
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 03, 2011 | Dell Dimension 8300 PC Desktop
Monitors will not turn on due to a power spike. Tower makes a beeping noise with a red blinking light. What could be the problem?
The moitors did not turn on at all after the power spike?
If that is the case, probably some electronic components were burned due to power surge damage.
I advise you to contact the manufacturer for repair and your local electricity supplier.
The beeping noise and the red blinking could be indication that no monitor is plugged in.
Jul 06, 2011 | HP xw6400 Workstation - 2 x Intel Xeon...
Intel XEON X5482 QC LGA 771 3.20 12MBCHIP1600MHZ TRAY  Logo
155 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
