Question about Omega Juicers 8006
Hello, I just received my omega 8006 and it wont turn on
  • 48 Answers
This juicer has a 15 year warranty which you can contact the manufacturer or retailer you bought it from depending on their return policies and exchange it.
http://www.omegajuicers.com/juicers/masticating-juicers.html
Posted on Nov 16, 2013
Omega 8003 does not turn on. Could it be the switch that is defective?
Never oil a power switch. Sounds like a defective switch and if others have the same problem go to the manufacturer website and look for a possible recall or solution.
May 18, 2014 | Omega Juicers
Omega 8006 locking clip is stuck and will not come off
Same. It was working fine and now the black end piece (where pulp falls out) is locked on and completely stuck!! No hope of it coming over. I need help.
Jan 09, 2014 | Omega Juicers 8006
Not working
This juicer has a 10 year warranty and you can contact Omega directly for warranty information and servicing the juicer. The link for their website is below:
Jun 02, 2013 | Omega Vert HD Machine VRT350 VRT 350...
My omega juicer won"t turn
Unscrew the bottom cover to expose the electrical cord. Check voltage if coming from the electrical cord by using a tester.If there is power, look for a a thermistor or a fuse and test if it is broken.
Sep 03, 2011 | Omega Juicers
My omega 1000 juicer won't turn on - I just bought it today.
Make sure it is assembled correctly and the latch arms snap shut completely
without any undue force. Also on the bottom of the juicer there should be a
reset button that might have tripped, just push it in. Other wise give Omega
a call.
Apr 23, 2011 | Omega 1000 Juice Extractor
Just received replacement Latch arm for Omega 1000. Old one is removed. Can not put the new one. Top part does not slide in. Also noted the old part and new part look different. Base is longer in the...
Believe it can be done. You might have to file or shave the new arm a little then seat it as best
as possible and tap it in place with a screw driver and hammer. If you do manage to attach
the new arm and the fit is a little too snug when you latch down the cover, file the upper tip
of the arm for a little more tolerance. Also, believe it or not, a worn blade will produce less
vibration. There is a set screw bottom center. With the juicer fully assembled, unlock it,
turn it clockwise until feed chute contacts the shredder blade and back it off a half turn.
You now have the proper gap between the chute and blade.
Jan 30, 2011 | Omega 1000 Juice Extractor
Hello! the top of of one of the arms has broken off about 2 inches at the top... is it fixable?
You can purchase new latch arms from Omega. Kinda tricky removing and installing them, but
it can be done. Have Omega walk you through it.
Jan 08, 2011 | Omega 1000 Juice Extractor
I need one of the clutch arms on Omega 1000 juice extractor replaced. I live in South Africa (Johannesburg) and so far could not find an agent. It broke off from side. The machine has been standing...
Hello Christien,
I would order a latch arm from Omega. they are around $7.00 plus change.
www.omegajuicersdirect.com
Regards
Alan Hood
amiman
UK
Jun 10, 2010 | Omega 1000 Juice Extractor
HI, I have omega 1000 juicer, and the latch arm was broken. I ordered the replacement latch arm online. I received my order today and there is no intruction how to replace it. I looked in omega 1000 manual...
There are no instructions. Call Omega 1 800 633 33461
for advice. Also new arms on an older juicer may not
be an exact fit so you might have to do a little filing
down on the arm to get it to fit. You can remove the
4 screws on the bottom to separate the base and get
a clearer picture of what you have to do. Basically
you have to pry the base of the arm away and push
up to remove it. If you're not handy you may need
some help cause it gets tricky.
May 08, 2010 | Omega 1000 Juice Extractor
Omega 4000 won't start even after reset
LOOK UNDER WHERE YOU PUSH DOWN
ON THE LATCH ARMS TO SECURE THE
LID. ONE ONE SIDE THERE MAY BE A
SMALL INTERLOCKING SWITCH WHICH
WOULD PREVENT THE JUICER FROM
RUNNING WITHOUT THE COVER LOCKED
DOWN. USE A SMALL SCREW DRIVE TO
CORRECT IF MISALIGNED. THE JUICER
ALSO COMES WITH A 15 YEAR WARRANTY, SO OMEGA WILL FIX FOR
FREE.
Oct 31, 2007 | Omega 4000 Juicer
Omega Juicers 8006 Logo
239 people viewed this question
Top Omega Juicers Juicers Experts
Tom Chichester
David Payne
David Payne
Are you an Omega Juicers Juicer Expert? Answer questions, earn points and help others
