Question about Iomega Prestige 1 TB USB 20 Hard Drive
My hard drive is beeping and "clicking" non stop
  • 56 Answers
The drive is defective. that clicking noise is the read head not aligned properly. take the hard drive out of the enclosure and place it in the freezer for about an hour and see if it works long enough to the data off it, but ultimately you will need a new hard drive.
Posted on Mar 16, 2011
External hard drive won't show up on my computer
Enable Drive Letter View b> Click the "Start" button and choose "Control Panel" from the start menu. Click "Folder Options" and navigate to the "View" tab. Scroll down and place a mark next to "Show drive letters," then click "OK." b> Configuring Drive Manager b> Click the "Start" button to launch the start menu. Right-click "Computer" and choose "Manage" from the menu. Click "Storage" in the menu on the right side to extend the section. Click "Disk Management" under the "Storage" header. This will show you a list of drives and removable storage on your computer. It will also report the status of the drives, such as "Healthy." If the removable storage does not have a drive letter or has a drive letter in conflict with another drive, you can assign it a new letter. Right-click the icon of your removable storage drive and click "Change Drive Letter and Paths." Click the "Change" button, then choose a drive letter from the drop-down menu. Select a letter that is near to the end of the alphabet to prevent drive overlap issues. Click "OK" to allow the changes to take place. You should now see the removable storage listed with your other drives on the "My Computer" screen.
Dec 29, 2012 | Imation Apollo Expert D200 1. 0 Tb...
Why does my portable hard drive not show up on my computer
See if Testdisk sees the drive and if so try to resotre the boot sector.
Nov 12, 2017 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
What does continuous non stop beeping means?
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM and Cmos battery are securely seated
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
a computer needs its connections to continue its cycle and to have and end to function
the beeps are post pre operating system searching for some hardware it could be RAM cd/dvd hard drive or motherboard all of these must have secure connections for the computer to work
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure make sure the connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs all electric current and computer data to travel to and through every working device and have an end to work properly click start right click on my computer so any faulty leads will end up with a computer error
hope this helps
Aug 23, 2011 | Computers & Internet
When I format my sony DCR-SR68E then it show "unable to format" and its show a time "E 30:00" and when show in my lcd panel HDD format error. Please help me.
click start control panel administrive tools computer management then select event viewer depending on what operating sytem you have this may vary
in left panel extend the events there you will see errors in red right panel you will no what exactly what the error was and at what time it occured you might be able to work your way through the problem
how are you trying to format this usb hard drive it might be listed as a mass storage device
click start click on my computer you should see your drive
right click then select format
another way is to control panel administrive tools computer management disk management right click on your drive select format
hope this helps
Jul 21, 2011 | Sony DCR-SR68E/S Handycam(R) PAL Video...
My maxtor external hard drive gives a beep sound when I plug it to my computer. The computer says "a new external hard is added to your compute"r but when I click on MY COMPUTER, it doen't...
1) click start
2) right click on "computer" or "my computer"
3) click manage
4) IF you get a user account control popup click yes
5) double click on storage
6) double click on disk management
7) identify your disk, it should be empty and most likely named "disk 1" or maxtor drive or something
8) right click on it and select format (quick format, default allocation size, NTFS)
9) voila!
-Luke
Jul 21, 2011 | Maxtor Hard Drive
Everytime I max the volume, there's a beeping noise coming from the speaker.
If you want to turn of the Beeping sound,You can disable the Beep device by doing this steps.
Just go to (right click) My Computer > properties > device manager > clicl view menu > show
hidden device > under Non-plug and display driver, go to Beep > right click then properties >
under Beep properties go to Driver > current status then press stop > under start up then TYPE >
click the window then click DISABLE.
Thank you for visiting FixYa...
Jun 28, 2011 | Computers & Internet
Seagate Momentus 500GB hard drive on a Dell Latitude laptop running Windows XP with an Excel spreadsheet open. I went away for about 20 minutes, came back and unlocked the user and then blue screen with...
This is a typical hard drive failure scenario, please check if your computer has valid contract if so get your hard drive replaced.
If you have valuable data in your hard drive and willing to spend you can go for hard driver data recovery which is an expensive process.
Jan 04, 2011 | Seagate Momentus 5400.3 Hard Drive
My hard dive beeps when i make a mistake even though I have disabled all of the sounds in the control panel. Mostly happens on Outlook.
The sound is coming from the speaker that is attached to the motherboard.
Sometimes you can disable the speaker by following these steps:
  1. In Control Panel, System, Hardward
  2. In Device Manager click View and click "Show hidden devices"
  3. This should make "Non-Plug and Play Drivers" visible in Device Manager.
  4. Expand Non-Plug and Play Drivers by clicking the plus and double-click Beep.
  5. Within the "Beep properties" window click the Driver tab.
  6. Under the driver tab if you wish to temporarily disable this device click the Stop button. If you wish to permanently disable this device under the Startup Type select Disable.
Please let me know if this solves your problem or if you would like any additional assistance. Thank you.
Sep 18, 2009 | Acer Computers & Internet
Iomega Prestige 1 TB USB 20 Hard Drive Logo
325 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Starnley Johnwells
Starnley Johnwells
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
