Question about RCA RS2605 CD Shelf System
Drive belt for a HH957 CD player
Where do I buy a new drive belt for my HH957 Koss CD player? When the disc door would not open, I removed the top cover, to discover the belt is gone!!!!!!!!!!!! All that was left was a small stringy piece of black rubber. The pulleys all run fine, but no belt.
Help, If you can.
Most Sincerely,
Rodney H Hess
34351 701st Avenue
Kimball MN 55353-2721
reenieandrod@meltel.net
Found a belt at a local dealer.
Posted on Aug 03, 2008
  • Phill Katz
    Phill Katz Nov 08, 2011
    Glad to hear it. For those though that do not have access to a parts supplier you can also use a thick rubber band. I have used this on several dvd drives adjusting and trimming the rubberband to fit and have found that it worked. Again for those without many options it's a temporary solution :}
The tray is blocked. When I try to open it, I hear an ugly humming sound. The cd stuck inside can still be played. how can I open the blocked tray? I read that there is a emergency button under it, but I...
There is no easy quick release to the Drive Door. You have to take the cover off of the Player and in the front of t he drive tray there is a small motor that has a small belt on it. If that belt breaks of falls off of the pulleys, you will hear the motor spinning and then it gives up. You can remove a plastic plate over the motor and pulley and manually spin the drive gear to open the Draw and remove the Disc. The belt shuold be available online.
Jul 06, 2014 | NAD C541 CD Player
When I push the cd open-close buttons on the player, the disc tray does not come out. When I select a CD# it says reading, but nothing happens. The player indicates that there are discs in all 3 spaces,...
It is likely worn drive belts. There are 2 within this hi-fi. I replaced my belts with elastic bands. No issues so far.
1) Remove power and unplug unit
2) Remove 4 x lid screws and lid
3) Remove both side panels.
4) Remove silver plate from shielding cd drive
5) Replace belts with 25mm diameter bands
6) Reverse the strip down.
New belts are $6 each on e-bay
Jul 29, 2011 | Philips MC-70 CD Shelf System
The DVD drawer will not open unless a disc is in the drive. When the drawer would not open I took the cover off the player. The DRC8295N is a VCR-DVD/R RW player recorder. The DVD drive will record on...
The problem isn't with the motor being too weak, but the belt which the motor drives. I had the EXACT problem just as you described. What I did was I took off the belt and cleaned it with rubbing alcohol because apparently the belt picked up some of the grease from the gears and wouldn't rotate when the motor spinned. This belt actually pulls down the mechanism, on which the CD sits, from the magnet. So, just clean the belt and you should be good to go. If the belt is very loose, you might need to replace it.
Feb 14, 2011 | RCA DRC8295N DVD Recorder/VCR
Right side cd will not open. Took off cover and if I push down slightly on the apparatus in front of the ribbon the door will open but only if I push down on that point
There is a small round rubber belt which allows a motor to open the tray. Open the tray, as you say you can, Remove the mains plug. Remove the mounting screws for the deck and you will find the small drive belt underneath. I would recommend buying 2 belts and replacing them both. The diameter is 1 or 2 mm less than the old one (because they stretch)
Dec 19, 2010 | Sony RCD-W1 2-Disc CD Recorder
Cd tray will not open. Is there a quick fix for this I can do myself?
If when ejecting the disc tray you can hear motor noise from inside but the tray doesn't open up...
1. Unplug the unit from the A.C. outlet
2. Remove top cover
3. Look for rubber drive belt that causes load/unloading tray to move in and out.
4. Replace with new rubber belt..not a rubber band but a rubber belt.
Nov 08, 2010 | American Audio CDI-100 Personal CD Player
Liteon DVD recorder LVW-5045 has disc inside and won't open tray
Use your knuckles to knock on top of cabinet just above disc tray door while at the same time pressing open button,99% of the time disc tray will open.The problem you have is caused by a worn out belt drive or the tray is out of alignment.The disc tray belts only cost $2,when tray is open you can see the minature belt that controls door to the right.Use twizzers to remove and replace.Belt size 1.9
Aug 02, 2009 | Lite On LVW-5005X DVD Recorder
My DVDR04 door will not open
Tray is out of alignment or belt drive is shot.Knock on top of cabinet with knuckles while pressing open button it will open the disc tray door 98% of time.While disc tray door is open you will see a tiny pulley to the right,this belt is probably too worn out to open the door properly.Uses 1.9 size belt.You can remove and replace with twizzers.Make sure new belt is in the tracks or tray won't move.
Jan 31, 2009 | iLO DVDR05 DVD Recorder
Koss cdp4045 cd player won't regonize new cd
it might be to old if not make a copy of the disk try again if not get a new cd player for £3.50
Dec 31, 2008 | Koss CDP4045 Personal CD Player
Wont unlock
Usually when the drive door won't open in either a DVD player or a CD player, it's because someone has put a CD or DVD that was not seated correctly in the tray, and once the tray closed the disc caused it to jam.
The only other causes are the mechanism. If it uses a belt to open the drive tray it may be slipping. There could be a broken or misaligned gear, or the tray may have come off of the track or rail it slides on. In these cases the unit would have to be taken apart and repaired.
If it contains a misaligned disc, you will have to take it apart, and remove the top from the drive. Then remove the disc and reassemble the unit.
If you're really lucky, the manufacturer may have put a small hole at the front of the drive. It almost looks like a pinhole, but slightly bigger. If you push a piece of wire (like a paperclip) into the hole, it may force the tray open for you. However, if there is no hole, the drive will have to be disassembled.
Jan 31, 2008 | Fisher DVDS1100
Disc Tray will not open
DVD door is opened by a small pulley-belt system. Disconnect the power cord and remove cover on R6740 (one screw on each side and 3 in back). Remove top cover on DVD drive (4 screws on top). Manually open door; you will see a small "O" ring sized rubber belt (they stretch and lose flexibility with time, which is why the door stops working). Remove and replace belt. I found a 11/16" X 1/16 belt at Lowe's in the plumbing dept @ 2 for $.59. Its not a perfect fit, but the door works now!
Nov 05, 2007 | GoVideo R6740 DVD Recorder
RCA RS2605 CD Shelf System Logo
130 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
