Question about Paradyne FrameSaver SLV 9626 (9626-A1-202) Remote Access Server
Where is the firmware on this board? - Paradyne FrameSaver SLV 9626 (9626-A1-202) Remote Access Server
I replaced a MFPB board on a Konica Minolta bizhub C220 machine. When I rebooted the machine I got a C-C164 error. How can I fix it. Thanks!
The wrong model of firmware is detected in the MFP board you replaced when the main power switch is turned ON. Get a tech out to see if he can update the re-flash the copier OS firmware and or replace the NVRAM Bad move on your part can't replace boards !!!! each machine is set up with certain OS firmware, hopefully the tech can flash the firmware and get a new NVRAM and maybe new board ITS GOING TO BE EXPENSIVE
Sep 24, 2017 | Konica Minolta Office Equipment & Supplies
Minolta C450 C-D212
Will require a re-flash of the board firmware, MFP. Multi-Function Board. Or Replacement $$$$$$$$$$$$$$$$$$$$$. Firmware via a Secure Konica Minolta Web site they like their firmware secure that is why you will need a tech.
Apr 28, 2014 | Konica Minolta bizhub C450P Laser Printer
Bizhub c550 code c d403
check all connections between the main boards start with having the firmware re-flashed via secure konicaminolta web site only tech have assess to, KonicaMinolta wants their firmware secured. secondly remove each connector on the board check for bent pin on the board connector, then re-seat each plug and there are a lot of plugs on each board!!!!!!!! worse case bad boards $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
Apr 08, 2014 | Konica Minolta Bizhub C550
Error code c173
NVRAM or main board issue has any boards been replaced? has any firmware been attempted is NVRAM board missing???? GET a qualified tech out to look at this you might need OS firmware updated and or NVRAM and or board replaced properly
Dec 07, 2013 | Konica Minolta Office Equipment & Supplies
Hyundai tv firmware
It sounds that the fault is not with its firmware. Check all the solder terminals at its main board, and power supply board, for any loose solder points. OK?
Nov 22, 2013 | Televison & Video
Firmware on main board 10000100 error
Live (free support) chat with Epson:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&category=Products&infoType=Contact&oid=14397&prodoid=19302859
Nov 06, 2013 | Epson Stylus Pro 9600 InkJet Printer
The copier is giving error code f07
F07 Communication error between boards (LGC and SYS boards)
Firmware is where I would start along with the wall power.
If this isnt work, replaced logic board and updated firmware. Machine will must works perfectly.
Hope this helps.
Oct 12, 2011 | Toshiba e-Studio 45 Black and White Copier
I erased some things i didn't think i would need from the mp3 player (photo folder, etc.) and now when it turns on it just says "Load main image failed, switch to recovery mode"
STEP 1: Soft Reset
Simply press and hold the power button for 20 seconds. The soft reset would refresh the player. After doing the soft reset, try to turn on the player once more. If this didn't resolve your issue continue to step 2.
STEP 2: Firmware Update
Firmware controls the functions of your device (how your device operates). In cases where the product does not perform as intended, the update fixes the issue by replacing the current firmware with the latest enhanced version.
Please be reminded that for your player to work properly you need to meet the requirements below.
- Windows XP SP2 or higher
- Windows Media Player 10 or 11
To Download the Sansa Firmware Updater, you may copy and paste this link to the address bar of your web browser:
http://mp3support.sandisk.com/sansa/Application/SansaUpdaterInstall.exe
To Know More on Using the Sansa Firmware Updater:
http://kb.sandisk.com/cgi-bin/sandisk_en.cfg/php/enduser/std_adp.php?p_faqid=306
If you encounter any issues with the Sansa Firmware Updater, we can try to use the Manual Firmware Update.
There are three versions of the Sansa e200 - Version 1, Version 2, and Rhapsody. This can be found by going over to "Settings" if you found "format" then you have a "v2" or look at the back of your player and check the exact model number under the "CE" logo it should say "model:e200" for Version 1; "model:e200 V2" for Version 2; and "model:e200R" for Rhapsody Version. Make sure that you choose the correct firmware version for your device as updating it using the wrong firmware version may render your device useless.
E200 Manual Firmware and Instructions:
http://forums.sandisk.com/sansa/board/message?board.id=e200&thread.id=15209
E200V2 Manual Firmware and Instructions:
http://forums.sandisk.com/sansa/board/message?board.id=e200&thread.id=13548
E200R Manual Firmware and Instructions:
http://forums.sandisk.com/sansa/board/message?board.id=e200R&thread.id=2280
Dec 25, 2010 | SanDisk Sansa e200 MP3 Player
I now have 2 HP LJ P3005n printers within the past 3 days that have stopped working. 1st error code on printer #1 is = 49.4C22 and 49.4C02 and the 2nd printer is now displaying error code = 49.4C02. What...
The codes indicate firmware errors (possibly a failure of the formatter board, but more likely firmware). Up-to-date firmware is available for download at www.hp.com/support/LJP3005. Read the installation instructions for the firmware update. If you have ANY doubt AT ALL about your ability to successfully update the firmware, pay a shop to do it for you. A failed firmware update may not be recoverable, and the formatter board is rather costly.
Oct 20, 2009 | HP LaserJet P3005n Printer
Paradyne FrameSaver SLV 9626 (9626-A1-202) Remote Access Server Logo
14 people viewed this question
Top Paradyne Computers & Internet Experts
Michael Galve
Michael Galve
Are you a Paradyne Computer and Internet Expert? Answer questions, earn points and help others
