Question about Dualit 20084 2Slice Toaster
I have bought new elements for my dualit toasteer and have replaced them but the one in the middle seems not to work. Maybe I have connected it back together in an unpropper way?? Are there any manuals on the internet?
  • 229 Answers
Visit this website
http://www.kitchen.manualsonline.com/manuals/mfg/dualit/dualit_toaster_product_list.html
and select the option that suits your model. Hope it helps
Posted on Mar 16, 2011
RH end element was not heating to same temperature as middle element. Bought and fitted new end element but still same problem ie this new element still not heating to correct temperature high causing...
the new version has a plastic cover over element wires its best just to change all elements to solve this if you have had this toaster a wile the old elements dont have it,,,make sure its correct ones fitted as they are all different watts ..
Feb 23, 2011 | Dualit Vario Combi 2+1 65-Slice Toaster
Tip
Procedure for replacing heating elements for Dualit Bread toaster
91b14ba.jpg370ea57.gifPROCEDURE
PROCEDURE FOR REPLACING ELEMENTS
A. Disconnect the toaster from the mains
B. Remove the crumb tray.
C. Unscrew feet and remove base plate.
D. D. Loosen the two nuts and slide back element retaining strip.
E. Note the position of the connecting links and wires, then unscrew nuts which secure them to the broken element, bend back the connecting links, pull out the old element and slide in the new element. Fasten connecting links back to their original position by tightening the nuts.
F. Slide back element retaining strip and tighten nuts.
G. Make sure that you have the high wattage elements marked ?CENTRE? in the middle and the two low wattage elements marked ?END? at ends.
H. Refit base plate, feet and crumb tray
on Apr 02, 2010 | Kitchen Appliances - Others
Dualit element gone
Very very dificult to replace. I have try it but then I have purchase a new complete base with element.
Apr 30, 2010 | Dualit 72102 / 72100 Cordless Electric...
I changed the element in my Dualit toaster; still doesn't work
If I understand well the blackened wire is an overheated wire which it is probably but off in one point so no electricity comes to the element anymore.
However overheated wire in you metalic toaster is a very danger thing to have and need to replace all the wires you have noticed that they changed color or not look good contition.
The problem have been caused from a problematic element which is the one you have already replaced.
However you if after you replace the wires you need to inspect the toaster after some time in order to be sure that not any other element causing the problem.
Good luck.
Mar 05, 2010 | Dualit 20247 2-Slice Toaster
Where do I buy replacement elements from for Dualit toaster, the middle one has died? I last bought one from a shop in Puckle St Moonee Ponds and it has closed down.
Try ebay, their good price and they will come to you fast and on low cost. The midle one is called "CENTER" and the one at the two ends called "END"
Good Luck
Feb 05, 2010 | Dualit Vario 2 Slices Toaster
Dualit 4-slot toaster - is this how it's supposed to work?
your toaster is working correctly if both are off you are in BAGEL/BUN mode ( did i spell that wrong ? ) in that mode it will only toast the cut side .... Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob
Mar 02, 2009 | Dualit Vario Combi 2x2 65-Slice Toaster
Problems with Dualit 20247 2-Slice Toaster one of the elements is out. Both sides of one toast is good, the other heats up only one side, as the element on the right is dead. Where can i send this, as i...
It is probably not under warranty. I would advise getting a new one. By the time you send it off and pay the repair and get it back, you will have a repaired toaster will a question mark on when it will go down again. Get a new one same brand.
Dec 30, 2008 | Dualit 20247 2-Slice Toaster
Replacing the elements on a Dualit 2-slice
You can find out how to replace the heat elements and purchase replacements at the Dualit Repair Center at:
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700
fax 201-439-1701
info@electra-craft.com
www.electra-craft.com
Nov 05, 2007 | Dualit 20247 2-Slice Toaster
Dualit 20084 2Slice Toaster Logo
160 people viewed this question
Top Dualit Kitchen Appliances - Others Experts
Herve Boissonnault
Herve Boissonnault
Angel Joseph Jr.
Angel Joseph Jr.
Ross Keen
Are you a Dualit Kitchen Appliances - Other Expert? Answer questions, earn points and help others
