Question about Taylor 632-27 Ice Cream Maker
My Taylor 754 makes ice cream. You make a draw on either side and that side times out about 15 minutes before you can make another draw.
    Scholar:
  • 81 Answers
First, be sure you have good scraper blades. All too often the importance of the scraper blades is overlooked. After you know these are good (you should put some new ones in just in case), be sure the refrigeration condensers are clean. Also, check the air discharge to verify it is not clogged. Hi pressure air or CO2 is best for cleaning condensers. They are located on the sides of the machine (if your machine is water cooled, be sure you have adequate water supply.). You will have to remove the sides of the machine to access the condensers appropriately. Clean the hopper condenser as well while you are inside the machine. It is the small condenser located in the middle of the machine toward the front. If all of the above are done and your problem continues, you will need to call for service as you likely have a low refrigerant level.
Posted on Jul 04, 2011
Does the taylor model 8756 put out a substantial amount more product than the 754?
Absolutely! The Taylor 754 and Taylor 794's are capable of 284 3 1/2oz. servings per side / per hour. The 8756 is capable of 426 of the same 3.5oz. servings. The 8756 packs more air into the product making it easier to freeze and reducing recovery time.
Soft Serve Parts Taylor Machines
May 07, 2017 | Taylor Ice Cream Makers
Standby keeps turning on when in standby but auto works turns itself on and off fine. Both sides of unit
I don't think you have a problem... I have a Taylor 8756p-27. In standby mode with my unit the beater motor turns on for about 15 seconds every 15 minutes and the compressor turns on as needed to keep the mix at a safe temperature. This is what standby mode is supposed to do. If you don't want it to turn on and off so much in standby mode, perhaps leave it in AUTO mode and it will turn off and on as it needs to to keep your product at the proper temperature.
May 06, 2015 | Taylor 754-33 Ice Cream Machine Soft Serve...
I bought a Taylor soft serve ice cream model #754-33 and serial #k1126268 I need to know how to set it and make ice cream?
too hard to explain online, you need to contact your local taylor dist. or a local service company who might install or know about them.
Feb 19, 2015 | Taylor Ice Cream Makers
Why is my taylor 8756 - 27 freezing the chocolate side and will not dspense?
This seems like it could be many things. Is the pump coming on when you try to dispense? Can you stick a thin wire up through the feed holes in the chocolate side when you try to dispense to help free the product?
May 04, 2014 | Taylor 754-33 Ice Cream Machine Soft Serve...
Product comes out frozen after all night on standby in a 754 taylor
The same thing happened to my Taylor 8756 and it was the thermistor probe. The probe is a thin copper tube that is near the freeze cylinder. It cost me about $20 for the part and $200 for the labor to have a technician put it in. Hope this helps and good luck.
Apr 18, 2014 | Taylor 2001 754 Air Cooled Soft Serve...
I need pice from 339-27 ice cream mashin
Dear friend, Well if you are planning to buy an ice-cream machine.i can provide you a few links.
for 339-27 ice cream mashin 1)http://shop.ebay.com/sis.html?_nkw=TAYLOR+339+27+SOFT+SERVE+ICE+CREAM+MACHINE+AIR+COOLED
2)wvw.lucantoniblanz.tk/taylor-339-27-ice-cream-machine
3)http://www.fashioninpassion.com/index.php?jeans=simac+il+gelataio&pj=67167
Price:$2392.0 - Taylor Soft Serve Ice Cream Machine Model 339-27 for the 3rd website
the cost is ranging from $1,995.00 to $7,500.00 (cost on ebay.com)
the below link will guide you in a more better way.
http://shop.ebay.com/sis.html?_nkw=Taylor+754+33+Soft+Serve+Ice+Cream+Machine+Air+Cooled
Buy It Nowor Best Offer $7,500.00
Jul 31, 2011 | Taylor 632-27 Ice Cream Maker
I purchased a used taylor 754 about 6months ago i never try to use it...last month i passed the city and health inspection...i unwraped the used taylor 754 machine and plug to the outlet and light...
That's a low mix light. It tells you that you don't have very much ice cream mix left in the hopper. There is a sensor in there that when no mix is touching it, it turns that light on.
Jul 24, 2017 | Taylor 632-27 Ice Cream Maker
Taylor 754-27 runs good until ice cream is made then trips-not able to restart in auto or wash-able to turn beater with hand-not binding - after ice cream becomes liquid able to start again in auto or...
It is possible that your viscosity is set too cold. You should check the temperature of your product to see if it is too cold. Is the Ice Cream hard? It sounds like maybe the beater overload is tripping. Some of the overloads can reset on their own. If you have and know how to use an ammeter, it would be beneficial to check the amp draw of the beater motor to determine if you are exceeding the overload or not. Ice cream is generally good at a temp between 16 and 20 degrees F. Temps vary with product and product brands. I hope this information helps, it is hard to determine exact problem without being there.
Oct 04, 2010 | Taylor 632-33 Ice Cream Maker
Ice Cream Makers Logo
211 people viewed this question
Top Taylor Ice Cream Makers Experts
Dennis Boxerman
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Are you a Taylor Ice Cream Maker Expert? Answer questions, earn points and help others
