Question about Pioneer DEH-P4200UB Car CD / USB/ MP3 Player
I recently hooked up my pioneer cd player in my car and when i play a cd it works fine for awhile but then the sound goes out. i double checked the wiring and the battery and its all connected right. the fuse is fine. i noticed that the time bar on the oel screen is still moving and reading the track but the sound just cuts out. any ideas?
  • 731 Answers
Hi:) Sound like the pre-amplifier transistors are burnt out if you hear no sound at all. If you can hear a very fate sound then it would be the Output amplifier IC's. If you are using a separate output amp check the amp.
Posted on Mar 16, 2011
Hello i recently just got this Pioneer car cd player and it's started to frustrate me a bit. I've connected it all up as the instructions have said and the first immediate problem was that i...
did you hook the constant power wire up? its the yellow wire coming out of the deck. if this was not hooked up the deck would work fine, but it would not hold the time, or preset stations either
Aug 09, 2011 | Pioneer DEH-1300 CD Player
I got a premier, pioneer DEH-P200 sterio and ive hooked it up to my 92 chevy truck and my 94 camero but in both it powers on. and beeps through the cd player for volume changes and stuff like that but its...
WELL THIS RADIO CD PLAYER WILL NOT WORK WITHOUT AN AMP HOOK UP IT JUST SENDS A SIGNAL TO THE AMP AND THEN TO THE SPEAKERS. YOU MAY HAVE TO FIND THE AMP THAT DIRECTLY HOOKS TO THIS UNIT...
Jul 15, 2011 | Pioneer DEH-P200 CD Changer
Pioneer xv-hdt520 stereo dvd/cd player cant get it to play cd,s works fine on the dvd part of it and all discs are read by the same reader it just tries to start then boots the cd out no matter which...
I would guess this model is over two years old. not sure how much you paid, but target sells a decent surround sound blue ray system for just under 300. i got it. it works great, streams netflix movies an even has an internet radio system in it.
if you dont wanna do that, and have made sure that you have tried brand new cds, another option is to play cds on a cheap cd player hooked into your surround sound. it can go in any input on the back with an adaptor you can buy at radio shack, or many of them have an input in the front.
they used to make a cd lens cleaner, not sure if they still exist. it was a tiny brush hooked onto a cd that you put in and it cleaned up the lens.
bottom line is that it makes little to no sense to me that it would play dvds and not cds. i would assume that they both use the same lens to read the device.
Nov 22, 2010 | Pioneer Audio Players & Recorders
I HAVE A NEW PIONEER AVIC-710BT THE AM/FM WORKS FINE HOWEVER WHEN I INSERT A CD NO SOUND FROM THE SPEAKERS
chances are, you hooked up the wrong blue wire... the power antenna wire (blue) is hooked up to the amp turn on wire... so while the radio is on its sending the signal to the amp to play and when the cd player is on it shut off... swap the blue wires and everything should be dandy...
Apr 29, 2010 | Pioneer AVIC-F700BT Car GPS Receiver
How to make mp3 work on DEH P3500 ?
when it says mp3 it means you can hook an mp3 player to the stereo and play music that way. if you have an mp3 player you need a cable that will hook the mp3 player to the stereo and you can get that cable from pioneer.
Nov 16, 2008 | Pioneer DEH-P3500 CD Player
AUX input on Pioneer DEH P31000
There is a plug on the back called an IP-BUS. You should be able to hook the ipod directly up to that with a simple homemade adapter. I built one for mine and it works fine.
http://stereophonik.com/gutterslide/IP-BUS_Hack/
Oct 07, 2008 | Pioneer DEH-P3100 CD Player
Avicn3
Check see if you antenna is hook up to the back of the radio. Goodluck.
May 19, 2008 | Pioneer AVIC-N2 Car DVD Player
No Sound Through Speakers
Hi Jake,
If you haven't done so already, I'd try double checking the speaker wiring, you may have some exposed or badly kinked wires behind the unit.
Cheers,
Matt Coyote
Feb 20, 2008 | Car Audio & Video
Speakers dropping out & engine sounds
sounds like your amp is bad
remove the amp and hook your speakers directly to the radio if the problem stops
then the amp might be messed up
if you got another radio try the amp with that radio to "double" check that it is the amp
if the problem is still there with the speakers hooked to the radio then you need to fix or get another radio
Sep 03, 2007 | Pioneer DEH-P690UB CD Player
Pioneer DEH-P4200UB Car CD / USB/ MP3 Player Logo
175 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
