Question about Dishwashers
Hi There I am having a problem with my Candynova CD122J Dishwasher, The problem is the water is not emptying out of it, I have checked and cleaned the filter and made sure there was not cutlery etc caught in it, Have you come across this problem before or would you have any help on this?? Any help would be well appriciated. Regards, John 00353852113372
    Champion:
  • 202 Answers
Water pump could be out could be restriction in the hose that runs into the sink drain
Posted on Mar 16, 2011
My dishwasher leaves sand like residue in my glass cups. I have tried running it empty and with vinegar, it still does it, how do I stop this from happening?
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes.
Hope this helps...
Daniel
Apr 02, 2011 | GE Dishwashers
Dishwasher inbuilt has recently stopped cleaning thoroughly. Little hard specks stuck on finished crockery, much worse on top shelf. top shelf items greasier and smeary... Cleans much better with Finish...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Feb 26, 2011 | Dishwashers
Dishes are not coming clean. The detergent basket is not emptying out, after cycle has run, the detgergent is still partically in the dispencer
Hi
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Jan 24, 2011 | Maytag 24 in. MDB3700 Built-in Dishwasher
Water does not empty completetly after the cleaning and rinse cycle is completed
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems -
Water will not drain out
heatman101
Dec 26, 2010 | Electrolux EIDW6105GB 24 in Builtin...
NOT CLEANING DISHES AND LEAVING SOAP ON EVERYTHING. I HAVE CHANGED SOAP 3 TIMES, AND RUN THE DISHWASHER EMPTY WITH VINEGAR. NOTHING HELPED
You may have a problem with your heating element...if the water isn't staying hot the dishwasher2_bing.gif will not work well...
Check out this tip and the there are others at the bottom of that one...
http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not
heatman101
Apr 20, 2010 | Kenmore 24 in. 17669 Free-standing...
Dish water not emptying out after a full cycle.
heatman101
Feb 22, 2010 | Neff 24 in. S5443X2 Built-in Dishwasher
My superba dishwasher leaves a heavy film on the dishes. Sometimes it is black as though there was dirt in it. I use Cascade and electrosol jet dry. melody
Hello, Over time dirt and grime both from the dishes and from the chemicals in the water build up in your dishwasher, you can resolve this by going to Wal-Mart, K-Mart or your local grocery store, their is a product that comes in a square bottle, it is in your dishwasher soap isle, you empty your dishwasher and take the cap off, tip it upside down inside your silverware tray, turn your hot water on in your sink and get it hot, then turn it off, turn on your dishwasher and run it from the pots and pans setting, it will clean the scum out of the dishwasher, I reccomend useing it every 30 days to keep your dishwasher clean and opperating efficiently, also you can remove the arm in the bottom of the dishwasher and clean that out by gripping the big ring at the base of the unit and turning it counter-clock wise and to clean it use a toothpick or q-tips to clean the debris from the holes in the arm, then install it back after you rinse the arm in the sink............hope this helps.........
Jul 02, 2009 | KitchenAid KUDK03ITBK Built-in Dishwasher
FOOD PARTICLES ON DISHES
Hi
If your dishwasher is cleaning poorly, check these:
Water-inlet valve Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it.
When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need to completely replace it.
Internal filters Every dishwasher has some type of filter to keep large food particles and foreign objects away from the pump assembly:
  • Most modern dishwashers have self-cleaning filters that don't need any routine cleaning.
  • Some have filters in the bottom of the dishwasher that you need to periodically clean. You don't need any tools to remove the filter, and cleaning it is easy. Consult your owner's manual to determine which type you have and its maintenance requirements.
If your filter is clogged, it may be causing the cleaning problem.
Drain valve Some dishwashers have a valve (or gate) that should open only during draining. If debris lodges in the valve, it can't close properly, so water drains out during the wash cycle. Most dishwashers drain into the garbage disposer. If yours does that, listen for water flowing into the disposer during the wash cycle. If you can hear it then, the drain valve may be clogged.
Spray arms There's a spray arm at the bottom of your dishwasher--it may have a tall spray tube mounted to the center of it. There may also be a spray arm located directly beneath the upper rack of dishes and/or above the upper rack.
If debris is blocking the holes in the spray arms where the water comes out, it could cause cleaning problems. Regularly inspect each of the spray arms and clean out the holes as necessary.
Water temperature To get the best cleaning results, the water entering your dishwasher needs to be hot enough. Try running the hot water in your kitchen sink for about 30 seconds before starting the dishwasher, to pre-heat it. Also, if your dishwasher lets you select a higher wash or rinse temperature, try that to see if it helps.
To check the temperature of the hot water that comes from your kitchen faucet use a waterproof thermometer. If the water isn't 120 degrees Fahrenheit, your dishwasher may have trouble getting your dishes clean. You could increase the temperature of the hot water to the whole house--and therefore the dishwasher--by adjusting the hot water heater thermostat.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Detergent cup Dishwashers don't perform their best if detergent is introduced only at the beginning of a cycle, so add detergent to both parts of the cup.
If the detergent cup isn't opening, see the "The detergent cup doesn't open" section, below.
Please do rate this solution as "FixYa" and revert for further assistance.
Thanks
Rylee
Mar 26, 2009 | Dishwashers
Dishwasher won't empty
sounds like the hose is blocked (usually with broken glass, followed by larger food particles) that runs from the dishwasher to the sink. You may need to remove this piece to check. If that isn't the problem, it's probably electrical.
Jan 26, 2008 | Hotpoint 24 in. FDW60 Free-standing...
E1 Error on LG Dishwasher (LD-2040WH)
Maybe the blockage is somewhere else. How about removing all the trays from the dishwasher, in other words, empty it from all racks and dishes and try it again
Oct 14, 2007 | Whirlpool 24 in. DU940QWD Built-in...
Dishwashers Logo
51 people viewed this question
Top Dishwashers Experts
Owen Barnes
