My hard disk have problem if i open may pc in go to 2 my os he said disk boot failure what can i do pls help me pls.
  • 52 Answers
Run windows setup from windows CD/DVD and see is it detecting ur hardisk if yes than try repair windows option in seutp.
also check is there any usb flash disk or external hardisk is attached to your pc if yes first remove it and than restart you pc.
also check in pc Bios setup that your hardisk is your first boot.
Posted on Mar 16, 2011
  • 111 Answers
Kindly Try this:
1. Restart your PC
2. Repeatedly Press F9 (Window must appear with list of Drives on it)
3. Choose the drive where your OS is installed.
Hope that this help.
Else give me feedback for me to get back to you.
Have black screen. Error PXE E53 help
Check the physical connection for your hard drive. Sometimes they get loose. With the computer off and the battery removed, remove he hard drive and then replace it. Try to boot again.
If this fails to help, you may have a hard drive failure and need to replace it.
Feb 17, 2015 | Dell Computers & Internet
Disk boot failure on compaq presario S7300CL
Hi friend,
The message, "Disk boot failure" often means that the OS is corrupt and needs to be re installed. Try restarting the computer twice or thrice and check whether you can log in to the system. If the same error displays again then you have to re install the OS. But re installing the OS leads to data loss from the hard disk. So at such kind of situations you need a data recovery software to recover your data back. Yodot Hard Drive Recovery is a wonderful data recovery software which performs recovery after disk boot failure.
Jan 12, 2012 | Computers & Internet
I have a Maxidata msi 865GM3-LS (ms - 7037 Ver:1) Motherboard , have two hard drive as master and slave. Suddenly when opened the pc, I got a message disk boot failure and unable to ...
Not shown in BIOS!!!
How old is that hard disk?
Have you been receiving messages showing "SMART error" or something like that?
If yes, hard disk can be damaged.
Aug 11, 2010 | MSI 865GM3-LS (MS7043020) Motherboard
I am not able to instal OS in my home PC. Asking me to install scsi drive. my hard disk seagate. where download this flopply disk bios drive software
hi
Checked the Bios Setting and check whether the Hard drive is recognizing or not -
Check the Boot sequence
Check Boot from the CD Drive
Format the Hard drive
it will work
Feb 23, 2010 | Seagate 500GB Maxtor Diamondmax21 SATA2...
Medion akoya e1210 notebook. failure to boot pxe
Failure to boot PXE 061 is a BIOS message that indicates 2 things:
  1. System failed to boot to the hard drive
  2. System failed to boot to a network connection
The apparent problem is failure to boot to the hard disk. If the system was running yesterday and there have been no hardware changes to the system, then most likely failures are:
  1. HDD failure (Replace the HDD, reinstall OS and applications) I hope you have information backed up.
  2. HDD not being detected by the motherboard due to connection issue (Remove HDD and reseat it, then see if seen in BIOS) If no change replace hard drive, if new drive not seen, replace motherboard
Jan 11, 2010 | Computers & Internet
PXE-E61: Media test failure, check cable Pxe-M0f: Exiting Broadco
PXE-E61: Media test failure, check cable (of the HARD DISK pls)
pls first check the hard disk seated in the bottom left side of ur notebook u have to take out the 7 or 8 screws first and then take take it out by pulling the connector gently and try to re seat or re fit the hard disk so connector can seat firmly in hard disk and then power up ur notebook if Error persists
then sorry to tell u my friend that ur Hard disk has CRASHED and not giving up files for OS loading kindly replace ur HARD DRIVE and restore ur OS thru backup disk u got
Pls take care of ur notebook from bumps and falls and hard impacts during operation and carrying bcoz the disk inside the HDD is very sensitive and gets damaged easily by impacts
pls rate me FIXYA for my diagnosis
Mar 09, 2009 | Acer Aspire 4720 Notebook
Tecra M2 doesn't boot is it a processor problem?
given the symptoms, it points to motherboard.. if it was processor, video or ram. it wouldnt boot at all and you'd just get error beeps from your laptop. i'd first try resetting the bios, by removing the bios battery for 30 min, then putting it back in. if that doesnt work try changing it out, usually costs under 8 bucks. if that doesnt work then I would change out the motherboard, if its cost effective.
Mar 03, 2009 | Toshiba Tecra M2-S730 Notebook
Disk boot failure error while booting
What does it says???Cant find hard drive or what???
Jul 18, 2008 | Compaq Presario 700 470024-192 Notebook
Error loadign operating system
This error message is normally indicative of a hard disk failure. The hard disk of course contains the files necessary to start your OS into opening. This could either be a hardware or software issue then in the harddisk. Often, this would be the hard disk itself not being recognized by the motherboard. At times, this could also part(s) of the OS were corrupted. The former would require replacement and the latter would require recovery/re-install of the OS.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 30, 2008 | HP Computers & Internet
Kika633@yahoo .com
you need to reinstall windows, put in floppy boot up disk set the cd to run have your windows cd in tipe d: install
Dec 24, 2007 | E-Machines eMachines Desktop PC
Computers & Internet Logo
79 people viewed this question
David Payne
David Payne
