Question about Vizio Gallevia GV42LF 42 in. LCD Television
I have a green tint on the faces on my Vizo flat screen,
I went into menu and went to custom and it said in my book that if I pushed the custom it would bring up the colors red, green and orange. I can't get to that part of the menu to bring up those tints. I need help. I have Model number VP42HDTV
  • 3 more comments
  • nnblumb7 Aug 02, 2008
    yes I went into menu and tried to adjust color, tint, sharpness and even checked to see if cable was loose. It said in the book to go to menu then custom and I highlighted custom and it was suppose to bring up the tints but it didn;t do it so I am stumpted. I have even pushed re set orginal settings and still have the green faces. I just don't know what else to do I am using the remote.
    Yes. I have the picture mode up now on custom it has contrast, brightness, tint, color, sharpness color temperature and advanced picture adjust, I have been adjusting these however I need to get to the screen that has the actual colors red, green and Blue, I had it wrong there is no orange. I can't get to that menu the book said to choose the custom option then a new menu would pop up with these colors it does not do that.
    are you still there?
    should I get a T.V. person to do this or my grandson will be here later tonight and he is much better at this than I am , can he possible do as you said? If not I will call a T.V. guy. I got the T.V. last year in August.
    I am new on the computer how do I rate it here. You have done a great job so I rate you high. Have a great weekend.
    Brigadier General:
  • 3,614 Answers
Have you try to adjust the picture settings./
Posted on Aug 02, 2008
  • 2 more comments
  • micromaster
    micromaster Aug 02, 2008
    it seem that you got a problem on the inside, could be some parts inside the television is going down, if this the first time you encounter this, and the problem is not changing even you have resetted all the settings, it is better to check the inside if you dont have idea to do this it is better to call a service guy near you. just check and the Change the 120k resistor on the green video output module. Resistor is located parallel and in front of the video output transistor heat sink. Failure can occur with blue and red also.
  • micromaster
    yes your grandson can check the unit, just tell him what i said.BTW you said it was purchased on august last year, is the date of purchased or the warranty has not been expired..?
  • micromaster
    kindly rate my solution here, will yah...?
    regards,
    micro
  • micromaster
    thankz & thank you for using this SITE fiXya...
46 toshiba plasma has red tint in back ground
If you can see the red tint with every input source and also in the On-Screen Menu, then this indicates that the Green phosphor is burning off of the screen faster than the Red and Blue. This is typical of plasma screens. Even if you dont watch a lot of golf or football, green is the most dominent color and burns out of the phosphur pits(pixels) faster than the Red and Blue. Take away green, you are left with Reddish looking screen and Pink whites. This is not repairable.
If the Menu looks nice and white, check your source cables.
Good luck
Dec 30, 2009 | Toshiba Televison & Video
Image green tinted.
TRY VIDEO CONVERSION OPTION IN THE MENU,,IF NOT TRY NEW CONNECTERS
May 15, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
My aopen f2925 monitor has a green tint.
The solution: hidden menu within the main menu itself. Hold the Menu button down while pressing Power to power on, and release power button only when the screen comes up, still holding the menu button. The menu will appear and there will now be a hidden selection, "Auto Color", printed in a red-on-black font at the bottom of the menu. Use the +/- buttons to access it, and press Menu. My green/yellow tint went away! Now my picture works great, and the setting lasts through Auto-Adjusts and Resets!
Apr 08, 2009 | AOpen F70PS 17" Flat Panel LCD Monitor
Magenta Color
Here is something that may help from the toshiba.com website under your model number television. Q. Why are people on my screen green?
Models: 32HL17, 37HL17, 42HL17, 42HL167, 47HL167, 52HL167, 42HL167, 42LX177, 46LX177, 52LX177, 57LX177
REF:FAQLCD00107
If the problem is not the connections, try adjusting the tint on your television. A high tint setting will usually create a green
image on the screen where as a low tint will create a more red hue. In order to access your television's tint:
1. Press the “MENU” button on your remote control and use the LEFT or RIGHT arrow keys and select the
VIDEO menu.
2. Then use the UP and DOWN arrow keys to highlight PICTURE SETTINGS and press the "ENTER" button on
your remote.
3. Next use the UP and DOWN arrow keys to highlight TINT then use the LEFT or RIGHT arrow keys to adjust the
TINT. If the picture is too green the tint will need to be lowered.
4. Once you have adjusted the tint to your liking, use the DOWN arrow key to highlight DONE and press ENTER. The toshiba customer service telephone number is : 1-800-631-3811. I hope this helps you with your problem.
Feb 01, 2009 | Toshiba 42HL167 42 in. LCD Television
I have been working on the settings I now have a lot of blue tint and green faces
Aug 02, 2008 | Vizio Gallevia GV42LF 42 in. LCD...
Green shading appears around faces of people on the screen
Try adjusting your TINT control in the menu.
IF the problem seems to be in a surtan area of the screen, the light engine is bad. This is very expensive to fix. You might want to buy a new tv.
Jun 21, 2008 | Mitsubishi WD-62327 62" Rear Projection...
Blue and Yellow Tint accross the screen ILO - 32HD
if you have speakers or a magnet or maybe an arial too close to your screen move them away. now try it. they can all interfere.
Jun 05, 2008 | iLO 3200 32 in. LCD Television
Red tint is gone
It sounds like the red cable on your component input is bad, one way to check this is press menu and see if the menu bars and letters are the right color. if they are then you may have a cable issue, if they are bad you may have a bad DG board in the unit. This will probably require a service technician. Hope this helps
Apr 03, 2008 | Panasonic TC-32LX20 32 in. HD-Ready LCD...
Green tint on left & right edges of screen
Purity problem?? Try manual de-gaussing.....T
Oct 25, 2007 | Televison & Video
Vizio Gallevia GV42LF 42 in. LCD Television Logo
535 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
