Question about Acer Computers & Internet
My left side speaker not working - Acer Computers & Internet
    Problem Solver:
  • 6 Answers
Try this:
  1. Right click "My Computer"
  2. Click "Manage"
  3. Click "Device Manager"
  4. Check to see if there is a Yellow question mark next to the "Sound, video and game controllers" (where the driver resides)
  5. Right click on one that says Audio in the name
  6. Click properties
  7. Click the "Driver" tab
  8. It should say something along the lines of "Driver Provider:" "NAME" (name being your audio driver company)
  9. Google the company and get the driver from their.
Should be good to go.
Posted on Mar 17, 2011
Onkyo m 504 left side not working
Amplifier section to left side, as well as connection to wire going to left side speakers,and speakers itself shoud check for damage/
Apr 29, 2012 | Onkyo Audio Players & Recorders
KA-994 Model Right speaker channel not working. How do I fix it?
Hello
Check the speaker of the right side first for damage. Connect it to left side and listen whether it works or not. If it works with left side, make sure that the audio output section circuit to the left side inside your amp has damaged and should be replaced. If the speker does not works with connecting it to the right side, make sure that the speaker has damaged. OK.
Dec 23, 2011 | Audio Players & Recorders
Only right side volume working wehn volume is low, when volume is high both sides work but distorted
It may mean that the connection for your left side speakers are loose or they are not connected properly. you can also try plugging the speakers to another music source (ipod, stereo, etc.)
If the same problem happens it is most likely a faulty wiring on the left speakers.
PS - if your computer volume software has the balance option make sure it's in the middle and not set to have output on just the left or the right side.
Hope this helps!
May 12, 2011 | Logitech R-10 Computer Speakers
Sbs 2.1 370 speaker problem is only when we coonect speker to right side. Left side not working
i have this problem too,sbs 2.1 370 speaker problem is only when we coonect speker to right side. Left side not working
Nov 21, 2010 | Creative Labs SBS 370 Computer Speakers
Left Speaker not working
if you swap the speakers and the dead one moves,than it is the amp that is missing a channel,in your case,it is the speaker.
if you try the good speaker in both speaker outputs,it should work on both to confirm the dead speaker theory.
there may be a broken wire in the speaker from shipping.
Sep 04, 2009 | Bose 3·2·1 II System
Right side speaker barely works
Likely the control is old and dirty.  It is known as a rheostat on older units and often a little contact cleaner on it will work.  A simple thing to try that might work is to rotate the knob back and forth, left to right, each time going to full stop.  do this several, several times.  See if this makes things better.  Of course, the assumption I am making is that the right speaker is operating normally.  If you switch out the left speaker for the right, and the problem persists, on the same side, it is the receiver.  If the problem now appears on the left side, it is a speaker issue and not the receiver.  Good luck and let us know how it goes.
Jan 02, 2009 | Audio Players & Recorders
New alpine speakers just stopped working on one side of my car and don't know what to do
Just check the wiring connection from receiver to your speaker,try to interchanges the left and right or to one side and to other side,so we know that the speaker is the problem .If happens still only one side is working even you interchange,then the problem is the speaker. If happens the speaker from left to right is working then the right to left is not works then the problem is the one side of the amplifier section is defected maybe the IC chip is busted or just loose,crack or cold solder joint.If cold solder only then reworks the solder joints in amplifier section.Then if the speaker is defected just reworks the solder connection of the speaker only .If still not working even you resolder the speaker then thats is the time you replaced the speaker...
Hope this may help;
Regards,
VOTIT
DON'T FORGE TO RATE;
Sep 01, 2008 | Audio Players & Recorders
Possible Blown Speakers?
Any speaker, if abused, can be blown. And if overdriven with dirty power at extreme levels it is not uncommon to burn out the voice coil. You might also want to check out the speaker surrounds. If they go, the speaker works but sounds lousy.
Localize the problem by hooking up two known good working speakers and see what happens. If they also do not work properly or sound like cr-p then the radio is at issue.
Jul 24, 2017 | JBL - MR4W Am/Fm with CD Player White
Sound not coming from left side surround sound speaker or my right side front speaker
it is highly likely that you're TV is outputting mono sound, hence the left channel only. check your physical connections to the TV and the balance / channel volume on the television as well.
May 01, 2007 | Onkyo HTR500 Receiver
Computers & Internet Logo
48 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
