Question about Maxtor OneTouch III Mini Edition 120GB External USB 2.0 Portable 120 GB IDE Hard Drive
My maxtor one touch is not found on my white macbook
    President:
  • 1,768 Answers
Several things could be happening here:
1. your electronic controller in the hard case has failed.
2. you didn't properly disconnect the external hard drive in Windows > with the
"Safely Remove Hard ware and eject Media" in the task bar.
3. if you have a power supply to the USB drive it may have a damaged power connector or not supply proper power to the device.
Posted on Mar 18, 2011
Does my Maxtor backup, indeed backup my photos
Depends one how you are backing up your photos and other data. Is your Maxtor an external hard drive. Did it come with software that you installed to backup your computer? I would need more information in order to help you. =)
Feb 12, 2014 | Apple MacBook 13"White /2.0Ghz Intel Core2...
My Maxtor one touch has stopped being picked up by my computer when plugged in. When power source is plugged in led light (white) just blinks and never turns solid
You said it has stopped being picked up when plugged in so I hope this is note is relevantbut I don't think it is abnormal for it just to blink.
If the OneTouch does not appear in My Computer or cannot befound by Maxtor Manager, right click on My Computer icon and select Properties,Device Manager, Disc drives, and expand Disc Drives.
There may be ayellow overlay over Maxtor drive, to show it has a problem, so right click onit and select 'Choose drivers for this device' to reinstall them.
Without goingonline they seem to be found and reinstalled from somewhere locally on the PC and I hope this willdo the trick.
Also in case this helps, I don't find the OneTouch (Maxtor Manager) software appears when the driveis plugged in, so I think this is normal too.
You should look for an icon (a capital M within a blue disc) for Maxtor Managerin the taskbar, at the bottom right of the PC's screen.
Right clicking on this icon, (capital M), should bring up awindow with Maxtor Manager at the top.
Then click on the text 'Maxtor Manager' to open the program's window.
Hope this is what you wanted.
Dec 28, 2010 | Maxtor OneTouch 4 500GB External USB 2.0...
My screen goes white, but will go back to normal after touching screen
Normally you shouldn't touch the display at all. By touch the screen you are directly touching the LCD module. Touching it maybe causing the screen to fail.
You will need to replace the LCD module to fix this issue.
Dec 15, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
My Maxtor One Touch III no longer turns on. The
well after some research or a lot of research. I found a few articles that suggest that there is a problem with the board inside the case. It suggest that you take apart the case and remove the hard drive and put it into your computer and it will work just fine.
Nov 04, 2009 | Maxtor OneTouch II external hard drive...
How do I use my Maxtor111 on my apple Macbook Pro? I had used it on PC laptop previously. I connected it and turned it on and the sync button flashed for a long time but nothing appeared on the screen. Can...
with it connected open applications and select utilities and then go to disk utility, open that and when it is loaded the maxtor should be in the list, you need to erase it, this will install the apple operating info (it should read some sort of f.a.t. to start with) you will loose all of the information on it
Oct 06, 2009 | Maxtor One-touch III Mini 40 GB USB 2.0...
Maxtor exter hdd 500 gb green light flashes but cant be detected
maxtor one touch 3 -500 does not detect on my macbook pro worked fine on my G5
Sep 11, 2009 | Maxtor MaxAttach NAS 3000 40 GB Network...
Macbook and I-touch loses wireless connection with versalink dsl
It sounds like the dsl modem and the gateway should be sync'd in the following way:
1. Turn everything off and disconnect the dsl for a bit. Make sure even the wifi stuff is off.
2. Turn on your gateway and let it cyce up.
3. Plug the dsl ethernet cable into your gateway, and to your phone line, then plug in the power to the dsl.
This will cause the dsl modem to "find" the gateway IP address and connect.
4. Turn everything else back on.
This should eliminate all the drops...
Let me knowhow it goes...
K
Jun 19, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Maxtor OneTouch III Mini not appearing on MacBook Pro
Hi Lois,
If your Maxtor appears in Disk Utility but the disk volume is not displayed, it's possible that the partition on the disk has been deleted for some reason. If that's the case, you will have to use a disk partitioning utility to create a new partition and then format the hard drive.
Best wishes,
Graemevm
Apr 28, 2009 | Maxtor OneTouch III Mini Edition 120GB...
Maxtor 1Touch4 won't connect
FIXYA! Hey, found out my maxtor issue...pretty much by accident though, with a little pinch of desperation. I powered down my MacBook, disconnected the drives (2) from their firewire and power and waited for about, oh, I dunno....30-40 seconds. Upon stubborn study of the power supply, something told me to just switch one adapter for the other!
So...I did it. Once plugged back in to my power strip, both LED's lit up and stayed continuous. Then, I just reconnected their firewire ports and, voila!...I was back online. Hate to think all that stress was just a matter of swapping power cords...but...here I am.
Hope that helps someone else.
Dave
Jul 07, 2008 | Maxtor One Touch III 500GB FireWire/USB2.0...
Installing Maxtor onto mac osx
I found the solution here: http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=SATA_Troubleshooter_-_Mac_OS_X_Installation_Basics&vgnextoid=a0a44a3cdde5c010VgnVCM100000dd04090aRCRD#storage
but short version of it all:
Basically you just need to format the drive to get it working. Open up disk utility. Selecting the maxtor drive on the left in disk utility. Then select the erase tab. Then change MS-DOS (FAT) to Mac OS Extended. Finish by clicking erase.
Mine didn't work at first even though I plugged it in but after I did that it worked. Hope you can get yours working too!
Jun 08, 2008 | Maxtor BASICS Personal Storage 3200...
Maxtor OneTouch III Mini Edition 120GB External USB 2.0 Portable 120 GB IDE Hard Drive Logo
54 people viewed this question
Top Maxtor Computers & Internet Experts
Computer Links
Rick Arnold
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
