The alarm system is a Gardtec 360/580 alarm system I have a code F6 on the display screen and the alarm will not reset found wire broken on one room sensor
SOURCE: Sensor alarm notice on GE Simon 3 system
Most likely it is remembering a alarm at that station. If you enter your alarm code following the "status", it will clear it. (That's how mine works)
Posted on Jan 19, 2009
  • 37 Answers
SOURCE: Service traction error, repaired broken wire now I need to reset computer.
you have to have what is called a tech II hand held analyzer to reset.It's a dealer or auto shop tool.to purchase one would be way more expensive than to just have it done
Posted on May 25, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: Whirlpool wmh1162xvs service code F6 after power failure
This is almost always a shorted microwave power relay on the control circuit board.
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Or feel free to contact me
directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Posted on Jan 17, 2010
  • 54 Answers
SOURCE: my gardtec ace home alarm external bell box wont
I'm not familiar with your particular alarm bell but most of the ones I've worked on have a dot on the gong that should be aligned with where the strike hits the gong. This is the "sweet spot" where the bell sounds the loudest. Another possibility is the gong may have loosened up and needs to be tightened or there is debris in there that needs to be cleaned out. I have found that bees and hornets love to build their homes inside of these boxes.
Posted on Mar 03, 2010
SOURCE: gardtec alarm 360/580 has gone off and i have no l...
Yes, There is an answer you should have another Box somewhere under the stairs cupboard, most likely a dialer.
There is a rechargable) battery in there (Life Span 10 Years) which has ceased - you need to replace the battery and all is well.
Sandy
Posted on Sep 24, 2010
I have an f6 code and the machine will not operate once it comes up
The F6 error code means that the computer on the control didnt detect that the motor reached a high speed on the spin cycle, sometimes it thinks the washer didnt spin fast enough because of a loose wire connection either on the motor or the control boards (motor &machine control) if you find that the washer did actually spin at high speed (clothes dont come out sopping wet at the end of cycle) the wire connections or the motor control board will be the potential causes of the F6 error code. Try unplugging the machine for five minutes to let the computer reset then try again. Next check the control panel wires. f6 code flashing on display Kenmore Elite HE3 Washing Machine
May 19, 2015 | Washing Machines
HOW DO I REMOVE THE GARDTEC 300
remove the power from your alarm main box and battery if there is one.
Jan 10, 2015 | Home Security
Gardtec 370 repetitive bb tamper alarm
Yes any bell box will do. Just note your terminals.
you can link out the bellbox tamper from the control panel as a temporary measure until you replace the bellbox, assuming its faulty
Apr 12, 2014 | Home Security
I accidentally locked myself out of my Smarthhome Securelinc Alarm Installer Code Model OH-41073AT. I would like to reset the unit to my installer code or create a new one. Can you assist?
The first thing to try would be to disconnect the mains supply and remove the internal battery for a minimum of 5 minutes and then reconnect it.
If this doesn't reset the system then remove the mains supply and battery again for another 5 minutes.
After 5 minutes reconnect the battery.
Then with the help of a friend try holding the # & * keys while they turn the mains supply back on.
These are generic resets for most house alarms but I'll keep looking if there's a specific one for your system so if neither of these work just let me know.
If I find anything else in the mean time I'll add to this post.
Jul 06, 2011 | Visonic INC Smarthome SecureLinc Wireless...
MY ALARM SYSTEM KEEP BEEPING UNCONTROLABLY..ADEMCO ALARM
Resetting Your Installer Code
1. The installer code (IC) is the code that allows you to access the system programming. If you forget your IC, your alarm company probably won't give it to you. This is because they use the same IC for many installed units and keep it a heavy guarded secret. If your forget your IC code, you're going to have to reset it.
First locate and disconnect the transformer. This is a cube-shaped wall outlet, usually placed around the alarm control panel. Next, shut down the alarm system's power supply. You may have to unplug a battery if you have a secondary power source connected to the alarm system. Once the alarm is powered down, you will reconnect the transformer and the battery in that order.
The rest of resetting comes on the keypad. Within 30 seconds of powering up the alarm, go to your alarm key pad press down the * and # keys simultaneously until you see "20" displayed. At the same time, you should see "Installer Code." Enter your new installer code while the "20" is still on the screen. Your installer code will be four digits. The keypad will beep to acknowledge the new installer code. After the keypad beeps, press *99 to exit the program. To check if you have reset the code successfully, enter your new installer code and press 1 (off). The keypad will beep once if you have successfully changed your installer code. If it doesn't beep, repeat the process.
Resetting Your Master Code
2. The master code is usually only used by the home owner. Other users codes can also be set up, including manager, babysitter, gardener and housekeeper codes. The home owner will use the master code to set up these other codes. The master code is also the code you will use when you come home and need to deactivate the alarm before it goes off.
To reset your master code, type in your installer code, press 8, press 02 and then punch in your new master code. Press 1 to turn off the programming. Your keypad will beep when you successfully reset your master code. You can now activate and deactivate your alarm system as you please.
Read more: Ademco Alarm Resetting Instructions ' eHow.com http://www.ehow.com/way_5752912_ademco-alarm-resetting-instructions.html#ixzz3pC2j96jl
Feb 04, 2011 | Audio Players & Recorders
Gardtec alarm 360/580 has gone off and i have no led display on the control panel. Can anyone help please
Sandy
May 21, 2010 | Home Security
My gardtec ace home alarm external bell box wont
Mar 02, 2010 | Kjb Security Sn1 Telespy, Portable...
Kenmore elite he4t
CHECK DRAIN HOSE coming from washer TO ENSURE WATER IS DRAINING PROPERLY down drain.
USUALLY YOU CAN RAISE DRAIN HOSE A LITTE AND RESET WASHER TO RINSE & SPIN F6 is caused by water not draining Fast Enough
Dec 12, 2007 | Kenmore Elite 45986 Front Load Washer
Computers & Internet Logo
106 people viewed this question
David Payne
David Payne
