Question about Garden
The van won't start after it rains for a couple of days but if it sits a few days and it's warm then it will start.
    Sergeant:
    Champion:
  • 250 Answers
If the sparkplug wires are old moisture will get in to the insulation which will cause that problem. You should change the sparkplug wires, plugs rotar and distributor cap.
Posted on Mar 16, 2011
Why does my ECM-I fuse keeps blowing?
Did you check the crank sensor wire, it may be hitting the hot exhaust. does the wire going to fuel pump have a problem and is shorting out. ECM 1 ..... then there are 5 components that this fuse feeds
1-crank sensor
2- all injectors
3- ECM
4- electronic ignition control module
5- ignition coil - check for a bad wire in these areas. Hope this helps.
May 21, 2014 | 1997 Chevrolet Astro
I have a honda EX5 (GN5 engine) which is single cylinder and single cam.. the problem is,it's suddenly start to sputter after a ride in a heavy rain.. the idle is a little slack on it,sometimes it...
Hi, Saisoku this happens to a lot of bikes and different brands it is usually caused by water getting into the fuel system and/or moisture getting to electronic components, wire connectors, wiring harness. This situation usually clears itself by letting the bike sit for a couple of days in the sun. For more information about your question please click on the blue links below. Good luck and have a wonderful day.
intermitent running rough in heavy rain
Bike runs poorly in after hard rain
bike won start after heavy rain
bike runs terrible after rain
Running Rough After the Rain
Apr 06, 2017 | Honda Motorcycles
1999 Chevy astro van won't start
Had the same issue with our 1999 chevy astro van, would crank but would not start. It had been raining and windshield had a leak, after 2 days of no rain it started. Pulled codes and was the Security system in the ignition switch. Hope this helps.
May 04, 2012 | 1999 Chevrolet Astro
Will not start after raining.Takes two to three days of no rain to start again.Then van will run again till it rains again.
you don`t say but it sounds like the moisture from the rain is sitting on the plug wires causing them to short the voltage to ground and possibly moisture in the distributor cap.how long has it been since a tune-up was done to the van.
May 09, 2011 | 1997 GMC Safari
We ran ut of gas, then it ran for a couple days ut then it started to rain and rained for 3-4 days straight. my van wouldn't start.
If it is a minivan there is a connector under the floor on the drivers side behind drivers seat under van.(by front of sliding door) Could have water in it. Or your fuel pump could have gone bad.
If you have a rubber mallet I would try tapping on the middle of the fuel tank while someone is trying
to start it. Do you hear the fuel pump run for 3 second when the key is first turned on? If not hit the tank with the mallet. What van model and year and what engine is it?
Paul
Dec 28, 2010 | Chevrolet Astro Cars & Trucks
1999 Chevy Astro van will not start after sitting day of rain
Have the resistance checked on your ignition wires! When it's wet, the wires break down or don't allow enough voltage to get through to the plugs. Therefore the spark is weak & the van won't start. You may have to change them. Good luck!
Mar 22, 2010 | 1999 Chevrolet Astro
Went to start my truck Sun morning and it idled very sluggishly. When it was given the gas it hesitated. Applied brakes and it died but started right up. No warning hadn't driven it for a couple of days,...
I own a 93 GMC and I have had this happen a few times, First its a chevy they are cold blooded take a bit to warm up and get heat. That and im sure the oil had not warmed up and gotten up to the top end. Let it warm up then try it out.
Nov 02, 2009 | 1993 GMC Sierra K1500
1989 Chevy Astro Van CL will not start if it has rained hard
these vans where kind off know for haveing problems with there dist. check the dist cap for cracks, check the coil wire also. what has happened is that mosture is getting in some where and probley the cap is at fault. when s the last time the vech has had a decent tune/up cap rotor plugs wires . replace the cap and rotor and coil wire, should solve your problem . but i would recommend looking at the other tune /up parts good luck kdc744
Dec 24, 2008 | 1989 Chevrolet Astro Cargo
Car won't run after rain or after it sits for a couple days
you need a tune up new plugs wires and cap an rotor
Nov 07, 2008 | 1990 Geo Prizm
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
