Question about Dryers
I have this but i only have one problem with it. the rubber on my dryer is lose and i want to know how to tighten it so i can start using again.
  • Michael Thibodeau May 11, 2010
    where is the rubber that you see?
  • 135 Answers
If it is on the door you may need to replace it
Posted on Aug 02, 2008
Dishwasher humming noise during wash. washes good but humming noise all during wash
humming can be the motors or the rubber supports are lose happens as the devices get older, if its annoying you just need to go round re tightening the screws and bolts so they tight again. can also be that the washer is not level and use will drop it down and need releverling and screwing the screws down tight.
Dec 24, 2017 | Dishwashers
New Rancher 455. Ran for a few minutes then tried to tighten chain but adjuster was maxed out (completely tight clockwise). Removed cover, now can't get tension adjusting pin in hole in bar....pin sits...
Ok.. with the cover off the clutch you notice the screw and the pin that is suppose to go into the hole.. with the chain on the bar back the screw until the pin sits in the hole of the bar.. The chain should be lose you will see the chain dangle at the bottom of the bar.. put the cover back on with it lose.. hand tighten the two nuts that hold the cover on. with the bar in hand and you pulling the bar up make sure the two nuts are on tight enough so the bar does not move but dont over tighten it. tighten the screw you will notice the chain starting to move, and start to tighten up.. once the chain is in the grove of the bar grab the chain and move the chain with your hand to make sure you have not over tighten it. if the chain moves freely and is not lose ( you can also double check how tight it is by grabbing the chain below the bar and letting it go if it snaps back into the bar and doesnt hang there you are where you need to be.) tighten the two nuts up on the cover and start up the saw. Run the saw to make sure everything is all set and nothing is lose before cutting.. If the chain never get to tighten up you need a new chain. buy a new chain and follow the steps again. let me know if you have any questions
Jun 19, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
I recently had my 2005 Chev Aveo LS have ther thermostat housing blow up and replaced at the Chev Dealership. At the time I smelt rubber burning but figured the thermostate housing replacing would...
Hello
make sure that they check all of rubber materials that could be burning which is a number of things, The ac belt could be slipping and getting hot, other hoses could be burning on the exhaust, sound insulation or under coating on the bottom of the car. they need to do just a good thourough inspection, even raise the car up on the lift to make sure nothing is bent, broke,rubbing or missing. The loose hose clamp is not going to smell like burnt rubber, maybe antifreeze but not rubber simply tell them you would like these things checked out they should do that for you
Good luck
Chris
Mar 25, 2011 | 2005 Chevrolet Aveo
Yesterday I dryed several heavy loads after the third load the inside of the dryer was very hot and had an odor of burning rubber? I unplugged it and let it cool and last night started it again with...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Either belt is no good or the motor is going bad...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 14, 2010 | Amana Dryers
I have a 2007 mitsubishi galant and I am replacing the sway bar link but I need to know what the torque setting is and no one seems to know ??
Unless you are a body builder, just tighten it on reasonably tight. Use some locktite so it will stay on and you shoud be all right. Most of the time it's just common sense.
Jul 23, 2010 | 2007 Mitsubishi Galant SE Sedan
Agitator doesn't move unless cap is tightened.
There is a metal piece that is inside the plastic agitator that is broken. I connects the agitator to the rod that drives it. It has an oval shaped slot inside and is ribbed on the outside. I have the same problem. Simple to replace, I just need to find the part.
Dec 28, 2009 | Frigidaire FGX831CS Top Load Stacked...
We changed the oil and then it was running fine. Well then after we turned it off and tried cranking it again it wouldn't start? There is oil all over the sparkplugs so we know there is an oil leak just...
you need to replace the sparkplug rubber gasket you will see it when you remove the valve covers w/c were the sparkplugs go through you will need 4 rubber gaskets only dealer will have it and make sure you tighten the valve covers properly after changing or else it will leak again
Oct 18, 2009 | 1995 Honda Accord
G. E. Electric Dryer - on drying rotation making noise
Drum bearing is worn out and needs replacing. There is an axle on the drum that goes into this bearing. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 28, 2008 | GE DBSR453EBWW Electric Dryer
Rubber door seal
Try here: http://www.searspartsdirect.com
Jul 12, 2008 | Hoover HDV7FM Electric Dryer
Dryers Logo
Top Dryers Experts
