Question about Electrolux EIFLW55I Washer
Clothes are getting damaged because they are getting stuck between drum and rubber boot.
    Brigadier General:
  • 6,277 Answers
Hi from retired Englishman in SW France
I'm wondering if it is doing that because the drum is shaking about too much because the washer needs balancing. Just in case it is that ---------->
It is necessary to ensure absolutely that the machine, even when empty, has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has not cured the problem it is possible that the internal drum suspension is malfunctioning.
Good luck,
John C
Posted on Mar 16, 2011
Why is my whirlpool deut washer tearing clothes
Check the little holes around the drum, I have seen pins and needles get stuck in these and cause lots of damage. I would replace the seal.
Apr 10, 2013 | Washing Machines
My washer damages clothes
You should inspect the inside of the drum for damage or something stuck in the drum perforations. I have had exactly this problem and it was caused by the wire from one of my wife's bras coming out in the wash and getting stuck in the drum perforations.
Mar 01, 2010 | GE WSXH208A Front Load Washer
My dryer burns holes in my clothes
are the clothes getting stuck in the front part of drum,the glides could be gone,the front felt strip could be worn or some dryers ride on rear bearing that wears down,the drum isn't spinning correctly because one of the parts i mentioned are damaged and the clothing gets caught in the space that's made from the drum sagging down
Nov 06, 2009 | Kenmore 63942 Dryer
Dirt is accumulating between drum and rubber seal and leaves stains on the clothes.
Clean the door boot with a 50/50 solution of bleach and water with a rag. This should be done regularly. It will help keep the mildew off boot as well.
Oct 28, 2009 | Kenmore 44102 Front Load Washer
Dirt marks on clothes from dirty rubber door gasket
Unfortunately you need to remove the front panel and change both drum slides to re-align drum again and keep it from damaging your clothes.
Aug 18, 2009 | Kenmore Washing Machines
Clothes get stuck between dryer and barrel
If your clothes get stuck, marked or torn in your dryer, check these:
Rollers
Rear seal
Front glides
Front seal
Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set.
Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it.
Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set.
Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it.
May 31, 2009 | Electrolux Kenmore 5.8 cu. ft. Super...
Drum spins off center and clothes get stuck between drum and casing
If your clothes get marked or torn in your dryer, check these:
Rollers
Rear seal
Front glides
Front seal
May 28, 2009 | Kenmore Dryers
Fridgidare dryer problem
there is a front glide assembly, depending on model will have 3 teflon/plastic glides attached t o the felt, this may be your grinding and gap issue
Nov 16, 2008 | Dryers
Holes in clothes
ok make sure there is nothing stuck in the machine that is sharp ,make sure none of the little holes though out the machane are damaged and check if there lying to get free clothes lol joking
Sep 09, 2008 | GE WSM2780W Stacked Washer / Dryer
Drum is stuck
Maybe that a sock or other piece of clothing get between the clothes tub and the outer tub. Open washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then,try to remove the clothing through the port. keep a rag nearby to dry up spillage of water when removing the rubber host. Good luck !!
Jul 01, 2006 | AEG Lavamat W1050 Front Load Washer
Electrolux EIFLW55I Washer Logo
122 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
