Question about SanDisk Cruzer Micro 2GB USB 2.0 Flash Drive
I have cruzer 16gb i entered wrong password 3 times and it got locked i need access to data what do i do?
  • 51 Answers
It doesn't look like this is possible. For your protection, SanDisk did not build in a backdoor or reset feature in the device.
Please see SanDisk's official statement on this feature:
http://kb.sandisk.com/app/answers/detail/a_id/191/~/u3-launchpad-password-feature
Posted on Mar 16, 2011
I forgot my password to open this jump drive.My computer will not let me gain access to any of my files on the disk. What can I do to access it again?
Retrieving a forgotten password on a Cruzer Enterprise drive How do I recover the password on my Cruzer Enterprise drive? Password hint
If you set a hint when you enabled the password protection, click Hint in the log in window to display the hint you entered. If you did not set a hint or still can not remember your password, you can click Forgot Password on the logon window and choose a new password. This will reformat the drive.
Reformatting will delete all files and applications in the user-accessible removable partition.
Password attempts
There is a limit of 10 attempts (default) before the drive is locked and no further access is possible. During this process, you MUST change the password and reformat the drive. This is an important security feature, protecting data in lost devices from brute force hacking attempts.
Cruzer Enterprise drive managed by CMC (Central Management and Control)
A drive managed by the Cruzer Enterprise CMC software can be unlocked remotely by the System Administrator when it is inserted into an online computer. The System Administrator can unlock the drive remotely even after the maximum failed password attempts has been reached. The user must then choose a new password. Data stored in the removable partition will be preserved.
If the device is managed but in an offline computer, the System Administrator can send the user a one-time unlock code. The user must enter the code then choose a new password. The existing data on the removable partition will be preserved.
hope this helps
Feb 27, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
My password protected scandisc cruzer usb stick is refusing to accept the correct password-any solution
Unfortunately, you can NOT access your user data and applications on the device without a password.
If you think you are entering the correct password, ensure that CAPS lock or NUM lock is not turned on. You should try to type your password in another application (like word or email) to ensure that it is being entered correctly. This can help you see if CAPS lock, NUM lock, or a sticky key is causing the password to actually be entered incorrectly.
Password attempts
There's a set number of attempts before U3 locks your device and you have to reformat it.
Reformatting will delete all files and applications on the flash drive.
Password hint
If you set a hint when you enabled the password protection, click Hint in the log in window to display the hint you entered. If you did not set a hint or still can not remember your password you will have to reformat the drive.
It is recommended to keep a backup of all the data on your U3 device on your PC for safe keeping.
Jan 16, 2011 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
Dear Team Today when i try to use my CRUZER U3 (8GB) I GET MESSAGE "you have reached the maximum number of failed password...
Each U3 smart drive comes with a pre-defined number of login attempts. When you have only 3 attempts remaining, you will receive a warning message to prevent losing your data unnecessarily.
SanDisk does not have any method to bypass the password security feature on Cruzer U3 flash drives. SanDisk has not built in any back door or password reset methods. If the password feature is enabled and you exceed the number of incorrect password attempts, the drive will lock. Once the drive is locked there is no way to unlock the drive or gain access to the data stored on the device. You can only select the format feature, which will perform a secure erase (drive wipe) and data recovery will NOT be possible. U3 Cruzer flash drives which are password protected use 128bit AES encryption for data security
Sep 23, 2010 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
I am entering the correct password for Sandisk Cruzer Micro 16GB. But It says the password is incorrect. I have one out of five chances left before the drive is locked permanently. I am 100% sure that I...
You're out of luck on this one that is why they put the security feature on there. You'll either have to take a chance with another password and lose your info or format the drive and lose the info anyway. Sorry couldn't be much help.
Aug 26, 2010 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
Locked scandisk cruser 16GB, need help unlocking it...
There are a number of utilities that might be helpful, but if your data is encrypted it may not make any difference if you crack the filesystem lock.
First I would just try some simple diskedit program. Check here for candidates. http://en.wikipedia.org/wiki/Disk_editor.
If these cannot get through then I'd try Spinrite from grc.com. This costs $$ but is almost invincible.
In extremis, I'd do a quick format then a file recovery ritual with something like FileScavenger.
There is a locked boot partition on this little gem that contains the security features keeping you away from your stuff.
Sep 03, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Problem with launchpad sandisk cruzer micro 16Gb mem stick (u3)
Start at the beginning. Look at how you entered your password and retrace your steps.
Jul 05, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
How to recover data from SanDisk cruzer micro 8GB U3 launchpad?
My Micro Sandisk Cruzer USB U3 (16GB) indicates the error the disk in drive I is not formatted, Do you want to format it now? How do you resolve this without reformatting and lost of data?
Feb 19, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
I reached the maximum axcess password for U3 sandisk cruzer micro 2GB
your drive has been locked by the password.
these drives need unlocking software .
you may not get it easily or get it done from some one easily because 99% when you unlock a drive the data is either lost or data remains in encrypted form.
unlocking by a parson who has salvation data hd doctor hard ware and software.. is easy.
anaesarora
Jan 26, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Forgot my password on my sandisk u3 cruzer 4.0gb
I forgot my password, i've already tried all my options and attempts. My Sandisk Cruzer 4GB is permanently locked. I need help to retrieve my data. THANK YOU
Mar 10, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk Cruzer Micro 2GB USB 2.0 Flash Drive Logo
392 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Carlos Calvo
Level 1 Expert
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
