Question about Kenmore Elite 45986 Front Load Washer
Our washing machine won't complete the spin cycle and is giving us a code nd. Now when we press start we get the code II. This is a buisness that really needs it to work! Any ideas? Thanks, Nadine All About Cats
  • Kenmore Master
  • 8,220 Answers
Get the service panel off
Posted on Mar 16, 2011
How to fix nd code
ND means no drain. The issue could be using the wrong detergent. IT could also be something stuck in the filter or the pump.
Aug 05, 2017 | Washing Machines
Won't fully spin and alarms nd as a code
You may want to check your drain to be sure there's not a clog/partial clog when draining out the water. Also, you may want to check the filter and possibly clean it. A partially clogged filter may cause this problem. And, you might try...turning off the unit for 10 seconds and turn back on...select Spin Cycle...press Start/Pause to drain the water. Good luck and hope this helps.
Walt
Apr 26, 2012 | Samsung WF218ANB 4.0 Cu. Ft. Front-Load...
MY WF218ANB/XAA WON'T DRAIN BETWEEN WASH AND SPIN CYCLE, AND GIVES ME AND ND CODE
Hi gumby323,
Drain pump may be clogged. Please follow my below tip on the fix:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER...
If this does not help, the drain pump may be faulty.
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Sep 09, 2011 | Samsung WF218AN Front Load Washer
I've got an LE code on the front of my washer
This error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
Are there soap suds visible in the drum?
Over-sudsing is the main cause of LE error codes. Using non-HE (high efficiency) detergents or too much detergent will cause stress on the motor. In addition, detergent residue can also cause leaking and odor. Follow these steps to resolved an LE error code caused by over-sudsing.
Step 1: Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Step 2: Plug the washer back in and press [Power] to turn on the washer.
Step 3: Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Step 4: Press [Start/Pause] to begin a drain only cycle.
Step 5: After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause]. This will remove excess soap suds and light residue from the drum. Repeat this step until no visible suds are in the drum of the washer.
Hope this helps.
Jul 06, 2011 | LG WM2301HW Front Load Washer
Duet whirpool washing machine stop and DLF sign appear
Initially unplug the washing machine.While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for five seconds.
Plug the unit back in, and run a rinse and spin cycle to test if the DL code is cleared.
If you still face the problem then follow the procedure:
Hope this helps.
Shane
Apr 03, 2011 | Washing Machines
I've gotten the error code DL and then F, I tried sanding, unplugging but it still shows me the error. How can I fix it?
Hope this helps.
Shane
Mar 15, 2011 | Kenmore Elite 45986 Front Load Washer
My washing machine is cannot spin ,it show error code LE
Nov 28, 2010 | Washing Machines
Code nd FAV6800AWW, Serial number 10
Hello HopelessR,
Don’t buy a clutch I don’t feel it’s a clutch issue at this point. I hope you can hang in there for some basic troubleshooting. I’m an owner like you not a repair person but I have worked some issues. I feel with the info supplied that you have a true “nd” alarm. The “nd” alarm is triggered when the washer fails to drain completely as monitored by the pressure switch input to the control board and the factory program time limit required for draining the washer. I have never experienced an “nd” alarm until this evening. This was a user induced “nd” failure by pumping wash water back into the tub during the drain cycle of Quick Wash cycle. I started a Quick Wash cycle with no clothes in the washer and with the remaining three settings set to min settings. At the 22 min mark the washer started the drain pump and began a slow spin CCW of the wash basket. It took several minutes of pumping wash water back into the wash tub to trigger “nd” alarm. The washer indicated time stayed at the 21 min mark until the “nd” alarm triggered. 1st test; could you start a Quick Wash cycle with what you would consider a full wash load with the settings I mentioned and let’s see what the results are. I don’t feel you have a clutch issue with no dc/UC error codes to the console. I believe at this point that you have a drain restriction problem. I can’t explain why the washer completes the cycle with the wash basket empty at this point. The 2nd test, do you have a deep sink you can pump the wash water into and observe the stream output? The stream my FAV6800AWW will produce is about a 3” vertical column of water out of the drain pipe held over the deep sink with the drain pump running and no clothes in the wash basket. If you have a deep sink and a helper that can turn on the drain pump in service mode as outlined below we can compare your drain pump output to mine.
You can turn on the drain pump in Service Mode with the process below.
1. Enter Service Mode by pressing both the Enviro Plus and Spin Only keys simultaneously until the washer beeps.
2. Next you need to go into the Board Output Test by pressing the Delicates key; your display should now read “ot”.
3. Now press the Presoak key this will start the drain pump and it should begin to empty the tub.
You can press the Off button to stop the drain pump.
If the output stream is low we can troubleshoot the restriction starting at the Sump Cap Item 9 and work back toward the drain pump.
I’ll hang in there with you if you want to continue to troubleshoot the issue. Maybe we can get some suggestions from other forum members. Rich
The Service Manual for reference. Sears Parts Direct for reference.
May 12, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Washer will not complete cycle
washer fills up but wont start washing i can turn the knob just passed the numbers and the little marks and it starts washing and when it gets to the rinse cycle it wont rinse but when it gets to spin cycle it spins good
Mar 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore Elite 45986 Front Load Washer Logo
197 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
