Question about Panasonic RPHS43 Consumer Headphones
I need to get replacement headphone ear pads for my rp-hs43 headphones.
2 Suggested Answers
SOURCE: Where can I get replacement ear pads for my
Solved my problem by finally finding the Panasonic parts dept.
Posted on Aug 02, 2009
Where can I buy a panasonic ergo fit rp-HJE120-D
http://www.amazon.com/Panasonic-RPHJE120D-In-Ear-Headphone-Orange/dp/B003ELYQGG
Apr 13, 2013 | Panasonic RP-HJE120-A In-Ear Earbud...
How to replace ear cushion on bose QC 3 headphone
The ear cushions are held on the earcup with six snap fasteners, three on each side. To remove the ear cushion, simply pull it away from the earcup carefully so that you do not break the plastic snap tabs.
It should not be necessary to pry the ear cushion off with a sharp object, but if you do, be careful. There is also a thin gasket seal between the earcup and the ear cushion, take care not to damage it.
If you need to replace the ear cushions with new ones, they are available from Bose for $35/pair.
QuietComfort 3 Acoustic Noise Cancelling Headphones Bose Product Support
They are also available aftermarket at Amazon.com for $16.99/pair
Replacement Earpad ear pad Cushions For Bose QuietComfort 3 QC3 Headphones...
or $5.69/pair.
Bluecell Pair of Replacement Earpad Ear Pad Cushion for Bose Quietcomfort...
Apr 02, 2013 | Bose QuietComfort 3 Acoustic Noise...
Hey I have lost the Ear pad to my panasonic rp-htx7 and need to know where i can replace it! It's only a clip on thing so im hoping it shouldn't be hard
See my tip on replacing dodgy cables plugs on headphones. Just click my name. Link to a site that sells them at the bottom.
Nov 23, 2010 | Panasonic RP-HTX7 Consumer Headphones
Need earpad replacements for Optimus Pro-100 Wireless headphones
Just flip the headphone pad inside out on the Optimus Pro 100 wireless headphones.
Find the 3 screws on each headphone speaker, you have to push the existing cover back, but you'll find them. Remove the 3 screws. Be careful of the speaker wire that will be attached to the cover plate that has the ear pad on it. Also, look carefully at how the components are assembled inside the headphone, as you might disturb their setting. They are easy to return to their proper place if they move.
Gently remove the ear pad, turn it inside out and you will have a new covered ear pad. GENTLY, re-install ear pad onto speaker plate, be careful not to break the speaker wire that is attached. I found a little flat screwdriver helps to pull the edge of the pad over the plate. The ear pad is actually quite strong and can take some abuse, but don't pull the speaker wires loose.
After you have the cover back on, find the screw holes and put the 3 screws back in. Presto, a little cleanup on any loose pieces of covering from the original side and your done for another couple years or so.
Feb 26, 2010 | Audio Players & Recorders
Technics RP-DJ1200A's left speaker disconnection
If you try carefully removing the foam ear pad you might be lucky enough to find that the speaker plate is screwed to the backing cup. I hope this is true in your case. Some of them are just glued together. Hope this helps.
May 27, 2009 | Technics DJ Headphones
Panasonic RPHS43 Consumer Headphones Logo
127 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
