Question about Medical
Hi, i have a ECG machine model no-9022K and having some problems like graph is not good and when it comes out the graph is faded. what is the problem and how can i fix this??? plz help...
4 Suggested Answers
  • 16 Answers
SOURCE: the schiller at 2 plus ecg machine not printing ecg
Does it work in auto mode ? are you putting paper correctly means , there is a black mark on paper which is sensed by paper sensor .If you put paper up side down then paper sensor won't be able to sense any paper & gives you error for rifilling paper .If this doesn't help you then You need to replace battrey . Thanks
Posted on Jul 22, 2009
AJIN G
  • 6694 Answers
SOURCE: hi i am ECG technsition i face some trouleshooting
hi,
replase the battery or ur ecg machine. is a regular complaint with AT1.
OK
Posted on Dec 23, 2010
AJIN G
  • 6694 Answers
SOURCE: How does ECG machine find
hi,
When the at2 is in auto mode, first of all it check the leads are properly connected or not.Then it will acquire the ECG and store the same in its memory then only it starts printing. that's why it takes that much time to give a printout. When its starts printing you can remove the connections from the patient because it have already memorized the ECG.
If interpretation is in on position it will compare the acquired ecg with the standards in its memory (allready programed by the manufacturer). and will give a detailed report with ecg.
ok
Posted on Feb 06, 2011
How can I print out a stored ECG on the MAC 1200? After I choose the ECG, select 'Print' and press 'Enter' I get taken back to the ECG screen. Please Help!
- Go to the storage program by pressing "Shift" + "Store/retrieve" simultaneously.
- using the down arrow, move the cursor to the space where your ECG's are listed and underline the ECG you wish to re-print.
- Once the ECG is underlined, press "Shift" + "down arrow" simultaneously. Two little cursors will state that the ECG is selected.
- Press "Enter". The cursor will come back on top of the screen, on "Print".
- Press "Enter" again. The machine will start to print.
I hope this helps !
Fel
Nov 09, 2011 | Ge Medical Systems Ge Marquette Mac 1200...
My Fukuda cardimax fx-7102 sometimes have grounded electrodes and does not print very well. The printout is very thick which almost cover the whole paper. It does not also function when using the battery...
hi,
You have to check the battery of you machine. it is recommended that you have to take ECG with battery backup. you should use AC line only for charging the battery. When you take ECG when the machine is plugged in to the AC you should provide good grounding to your machine. there will be provision for grounding in your machine. when you use the Ac line and if the grounding is not proper then the machine will print AC interference with ecg. that's why the printout come thick. Try to change the battery for better ECG print out.
ok
May 05, 2011 | Life Science Fukuda Denshi Cardimax Fx7102...
We have a Marquette Mac 6 ECG machine it will stays on through the start up then the display reads; battery is 0/50 aborting. Do I just need a new battery or is there another problem?
hi,
You have to change the battery of you ecg machine. Because even if the power is connected the ecg machine works on battery. If the battery is low the machine will go OFF after booting.
ok
Apr 21, 2011 | Ge Medical Systems Ge Marquette Mac 1200...
How does ECG machine find that signals are good for printing (in auto mode)? some ECG machines take up to 20 second time for printing start
hi,
ok
Feb 04, 2011 | Schiller Welch Allyn Cardiovit At 2...
Ekg machine states left leg fail, but none of the leads are reading anything. works sometimes, but does this occasionaly. Does anyone else have these complaints?
hi,
ur machines patient cable have some problem in its left leg lead ,it may be broken inside. no ecg will come if any of the lead have problem. machine sences all the leads is it proper or not , then only it will process th ecg and give printout. u have to replace the patient cable of ur machine. or try to replace the left leg lead if it is repairable one type patient cable.
ok
Jan 10, 2011 | Life Science Bionet Cardiotouch 3000 12...
Artia 6100 machine showing err out of paper.
hi,
ur machines paper sensing sensor have some problem. did u used the paper with black mark on the side.
remove the paper cover . u can see a black square sensor near the side of thermal printer. clean the sensor with an ear bud. do not use any solutions. then check again.
remember use good quality paper. if the black mark on the side of the paper is not perfect this problem can occur (black mark on the paper is for page count and paper sensing)
ok
Dec 23, 2010 | RTO Quinton Cardiology Atria 6100 Ecg...
The schiller At-2 we have in the office is acting up. Model number 021-02609. Office number is 480-889-0508. The paper feeds and doesn't stop were needed and the ECG being preformed on a patient are not...
HI,
check the paper u have inserted. it should be Schiller original paper with page marking. also clean the paper sensor. u can see the paper sensor near the side of printing head. a small square portion. clean it with an ear bud, don't use any solution for cleaning only ear bud.
ok
Oct 13, 2010 | Schiller Cardiovit At 2 Light Ecg Machine
GE MAC1000ekg not printing clearly . My EKG machine is recording the EKG well but when I print it comes out very faded.
The heat on the print head can fade over time giving you a poor print. also the feed roller can wear and give poor pressure to the print head. thw way to diagnose it is to put a peice of electrical tape on the print roller and print an ekg. if it prints well in the area where the tape was, it is the print roller. if there is no change it is the print head.
wats@mesasales.com. www.overstockme.com. Jeff Watson
Nov 17, 2009 | Ge Medical Systems Ge Marquette Mac 1200...
Medical Logo
Top Medical Experts
Electro Med Services...
Rhonda Webster
Rhonda Webster
Are you a Medical Expert? Answer questions, earn points and help others
