Question about Refrigerators
LG Fridge-Freezer model no. GR-T632DVQ The upper freezer lights works. The lower fridge light stopped working. When tested the light bulb works and is NOT broken. There is a combination double switch that operates both fridge and freezer lights when each door pushes on a separate plunger. How do I replace this light switch?
  • Anonymous Mar 31, 2014
    can't get out the push door switch to replace it
Looking for a door for lg refrigerator GR-T632DVQ
if anyone can help me plz ring 0421203100
perfect fridge, had it for 10 years, door fell off today :(
i've been searching everywhere, *sigh
please help if u can
Posted on Feb 01, 2012
  • 90 Answers
SOURCE: FRIDGE/FREEZER MODEL: SR42NMB Multi Frost
You have a clogged defrost drain tube. best way is to thaw unit out. Your vents are being blocked so no air flow is pushed down.
Posted on Jan 05, 2008
yeroc
  • 397 Answers
SOURCE: lg fridge
heating element seems bad,,sometimes a easy fix
Posted on Jan 20, 2008
peyton32034
  • 410 Answers
SOURCE: Kenmore 5126101 middle separator b/t fridge/freezer extremely hot
There are 2 or 3 things that would cause this. first make sure the condenser coils are not plugged with dust (vacumn or blow them out) next check to make sure the fan that cools these coils is running, (this is the most likely problem). if both of these check out ok then you would need to check to make sure your interior lights ar going off when the doors are closed as these will add extra heat and cause the center rails to run hot. last and most uncommon would be a freon system problem.
fyi there is a hot gas freon line that runs in between the doors to prevent exterior sweating. when poor or no air flow problems for the condenser coil exist it causes this area to become hotter.
One more thing. if you do determine that the condenser fan motor is bad you can put a normal house fan blowing on to the coil to help cool this area down until you can get the unit repaired.
If you need any further assistance leave me a comment here and I'll gladly get back to you. Thanks Peyton
Posted on Mar 11, 2009
  • 161 Answers
SOURCE: LG GR-349R bottom mount freezer gets heavy ice
Find the drain tube in the back and check it for a frozen state. If it si,use a hair dryer to thaw it. If it does it again, you have a defrost problem
Posted on Jan 22, 2010
kel1guy2002
  • 3740 Answers
SOURCE: LG refrigerator GR-B258jvc - replacing light bulb
There are usually 3 or 4 locking tabs on the cover that just need to be pressed INDIVIDUALLY toward the bulb to release them and then carefully remove the cover. The ones with 3 tabs usually have and upper and lower tab then the thrid tab is on the side. Removed the upper and lower tabs by pressing inward to the bulb and then the cover will pivot out on the 3rd SIDE tab.
Thanks for using FixYa.
Kelly
Posted on Apr 09, 2010
I have a Model IC6 bottom freezer fridge. the fridge is working but the lights on the upper fridge went out. The freezer lights work and the compressors seem to be operating. I changed the bulbs but they...
there's a light or door switch that could be bad,look around and you'll see a switch that the door hits to turn the lights on and off,i've seen people put the bulbs in cross threaded i remove the bulb thread it in and it works try removing the bulb and put it back in again,also if you unplug the machine and stick your finger into the socket there's a metal tab in there that touches the bulb if that is pushed in to far it won't touch the bulb to work bend that out a little and try it again,all there is is the bulb the socket and the switch and the switches are pretty reliable,they're located on the side or up top where the door closes in on the machine
Nov 08, 2017 | Amana ABB2222FE (22.1 cu. ft.) Bottom...
Kelly
Apr 09, 2010 | Refrigerators
Fridge not making usual humming sound
I had a same problem, However the fan in the freezer seems stop and the freezer compartment is melting. Its a double door LG with 270 ltrs.
Mar 11, 2010 | LG LRTBC1825T Top Freezer Refrigerator
My freezer is working perfectly but the fridge is not
The channel in the back were the cool air comes down from the freezer to the fridge may be iced up. Try defrosting the fridge/freezer for much longer than usual, all day if necessary.
Aug 30, 2009 | LG LRTP1231W Top Freezer Refrigerator
LG GR-292R freezer works/fridge does not.
well i have the exact same refrigerator but opposite problem.... the freezer works but the entire refridgerator is a freezer....why is the fridge part freezing everything. This appeared to happen after the power went out and the entire fridge is a freezer now.
Mar 02, 2009 | LG LFD25860
No light in fridge compartment, Not freezing. Light in freezer co
Your door switch is bad.  When doors are opened, the fan stops.  No cooling.  When it closes, fan starts.  Bulb is just an indicator of no power to unit...probably burned out contact in switch.
Nov 12, 2008 | Refrigerators
Problem with GL-T 242 QM LG Fridge
Pull out the freezer and ckeck for ice build up on the back. Unplug and defrost the freezer for 3-4 hours - leave the freezer door open. There may be ice covering the vents to the fridge.
Apr 28, 2008 | LG LRBN22514ST Bottom Freezer Refrigerator
FREEZER SECTION WORKING OK, FRIDGE SECTION NOT WORKING
Check the vents of your fridge side if present, if no air then may be your blower not working or some ice formation that blocks the air(try defrosting). Check also your vents for obstruction or overloaded with stocks.
Jan 22, 2008 | Freezers
Refrigerators Logo
425 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
