Question about Panasonic PT-53WX42 53" Rear Projection Television
Panasonic t.v projector
I have a 52inch flat screen t.v and the green red and blue wont center up so I have ghosting all over the screen the red and blue will move in the convergence screen but the green wont go far enough to the left. I would appriciate some help. and its a hdtv
  • DAN1212 Aug 27, 2008
    I HAVE A 2001 50" RCA REAR PROJECTION TV . THE COLORS WILL NOT LINE UP AND ITS LIKE WATCHING 3 OF EVERYTHING. IF I TURN THE TV ON AND OFF ABOUT THIRTY TIMES REAL FAST IT GOES BACK TO NORMAL FOR A SHORT TIME.
  • Panasonic Master
  • 8,617 Answers
You need to replace both your convergence ICs they are both STK392-110 you can get replacments at the following link with free instructions with pictures.
http://servicemanuals.vstore.ca/
Posted on Aug 13, 2008
My Panasonic wont display picture only flashes. YPbPr
What type of input cable are you using. YPbPr is a three or five wire hookup red, green, and blue.
Dec 16, 2012 | Panasonic PT-AE700U Multimedia Projector
Green screen
If the lines you see are retrace lines, It means that the 200VDC are missing and not getting all the way to the video amplifier assemblies.
Did you touch the screen control settings by any chance before you replace the HV splitter?
Apr 14, 2008 | Proscan PS60690 60" Rear Projection...
Panasonic rear projection 52inch cinema vision 1080i hdtv looks 3D with double vision red, blue and green how do I fix
Replace the convergence chips--should be stk-392-110's in the Panasonic.
I have start to finish free instructions for this repair based on the model number----a email address will get them for free.
Jun 06, 2012 | Panasonic Televison & Video
I saw an answer up above regarding the green hue on the projector, is there anyway to remedy this problem? This is really annoying to me and I would like to fix the issue. Thanks,
Three LCD block in the Panasonic projector PT-L735 green,blue and red and two polarizer use with each LCD (as show in picture below) when polarizers faded due to age or any other reason then screen show the color. In your cause the green polarizers faded and need to be replaced good_help_9.png
Jan 08, 2011 | Panasonic PT L735U Multimedia Projector
Failure to get a trully blank or black screen
Have never worked on a panasonic projector before I admit, but you get that effect when the 3 LCD panels inside a Sharp (and I assume all brands) LCD are misalligned. To get total black (LCD Projectors find this rather difficult due to the technology) the red , blue and green lcd pixels must be precisely allignend ( they are adjustable by technician and it's a fiddly job) I reckon the green panel is a touch out and it's peeking out between the red and blue squares.
Dec 12, 2009 | Panasonic ET LA780 Projector Lamp for 780...
I was just given this t.v because friends couldn't figure out what is wrong with itl. The colors don't line up right,looks kinda blurry depending on the lighting of the program being watched. How do i fix...
According to the manual:
1) go to the "TV Main Menu"
2) Select "Screen"
3) Select Adjust Projection TV (obviously only if a projection TV).
This then allows you to adjust the TV's 3-colors. Selecting GREEN CENTERING brings up a control panel that lets you center the green projection tube on the screen. Selecting RED CONVERGENCE or BLUE CONVERGENCE lets you align the Red & Blue projector tubes. Centre the green projector tube 1st. Then adjust the red & blue until the test pattern on the TV screen appers white.
Good Luck!
Jun 08, 2009 | Proscan PS50700 50" Rear Projection...
Ghosting in Red, Green and blue
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 24, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Convergence
Did you remove 1 leg of each resistor out of circuit when you checked the resistors? sounds like thier is still one resistor open or maybe one of the new IC pins need abit more solder.
Apr 09, 2008 | Panasonic PT-53TW53 53" Rear Projection...
HItach cp-s860 problem
I have the same Hitachi CP-S860 and have found the problem is with the convergence on the left and right sides of the picture. The one I am working on has a bad ghosting problem also - you can really see the ghosting when the MENU is on the screen. The center convergence is OK. Following Pics show Circle / Cross pattern - 1st pic the red, green and blue are turned on - 2nd pic shows green and blue on only. I do not have the service manual for this set so I do not know the convergence procedure on this one. I have mostly been repairing NEC, Sanyo, Panasonic and Christie LCD & DLP Projectors.
Feb 29, 2008 | Hitachi CP-S860 Multimedia Projector
Thomson scenium rear projector 52inch
What is your tuner source? Cable, Satellite, or antenna?...accordianman
Nov 17, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-53WX42 53" Rear Projection Television Logo
51 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
