Question about Facebook Social Network
My alc is not opening - Facebook Social Network
  • 4,399 Answers
What is it saying?
Posted on Mar 16, 2011
Where exactly is the switch for the air suspension compressor on a 2006 Buick Lucerne CXL?
The automatic level control (ALC) system maintains a desired rear suspension position under all types of towing, hauling, and loading conditions.
The system uses the electronic suspension control module (ESCM), ALC relay, ALC compressor assembly, air dryer, air lines, LR and RR shock absorbers with integral air chambers, LR and RR suspension position sensors, exhaust valve, driver information center (DIC), and the serial data circuit to perform the system functions.
What switch ? there are sensors at the wheels that control the system .
The system uses the automatic level control module (ALCM) with integral suspension position sensor, ALC relay, ALC compressor assembly, air dryer, air lines, LR and RR shock absorbers with integral air chambers, exhaust valve, driver information center (DIC), and the serial data circuit to perform the system functions.
The
Jul 10, 2016 | Buick Cars & Trucks
How to turn up the power on the midland 78 plus
Midland 78-574: {L209, L212, L214, RV9-AMC, RV201-ALC, RV#-SSB MIKE GAIN, VR4-AM PWR}
Midland 78-976: {L7, L11, L13, RV12-AMC, RV2-ALC, RV11-SSB MIKE GAIN, VR4-AM PWR}
Midland 78-999: {L209, L212, L214, RV9-AMC, RV201-ALC, RV#-SSB MIKE GAIN, VR4-AM PWR}
I put these up due to not knowing which one you have
May 07, 2015 | Midland Radio Communications
Galaxy 99v no transmit power on both usb and lsb only. ALC is all the way up. Very low forward about a half a watt only. Looking for answer.
you either bought it used or you played with the inside because if the alc is all the way open then you have been inside it.got a watt meter to turn up the power.you will also need a volt meter. take it to some one that knows what to do and let them fix it.
Feb 25, 2013 | Galaxy Radios DX-99V 40-Channels Base CB...
B2575
2. Locate and remove the ALC relay from the Underhood Electrical Center (UHEC) .
2. Identify pins 86 and 85 of the UHEC. Install a testlight across these 2 pins. Turn the key on, engine off. Using the scantool command the ALC on. Check the testlight for illumination. It should light.
3. Turn the key off. Using a suitable jumper identify and short together pins 30 and 87. With the headlight switch in the off position, the headlights should light and switch from high to low beam when toggled by the dimmer switch.
4. If the lights work, replace the ALC relay.
Jun 24, 2012 | Pontiac Grand Am Cars & Trucks
Ttrying to fine out where to put the air for the airshock
Vehicles: Cadillacs with ALC-controlled rear shock absorbers
Each rear shock absorber has an ALC (air) port. One may disconnect the ALC air line and try to add air, but this is unlikely to work, since there is no spring-loaded valve to close the port off immediately (like a tire).
A better method for inflating the rear shocks to see if they hold air is to supply 12V DC (from the battery) directly to the ALC system (air) compressor.
Debugging your Cadillac's ALC system can be a challenge. Here are a few basics.
Here's a depiction of the ALC port on the rear shock - found at the end of the ALC air tube.
Fig. 1 The ALC connection on the rear shock absorber
Here's a close-up of the Cadillac ALC port on the rear shock
Fig.2 Cadillac ALC air line fitting
Automatic Level Control System - General Description
Vehicles Without Road Sensing Suspension
The Automatic Level Control (ALC) system automatically adjusts the rear height of the vehicle in response to changes in vehicle loading.
The ALC system consists of a height sensor, an air compressor assembly, an ALC compressor relay, an intake hose and filter, an air tube, and two rear shock absorbers . The air compressor assembly consists of an air compressor and an air dryer mounted on a bracket. The air compressor head is a replaceable part of the air compressor. The (air) exhaust solenoid is a non-replaceable part of the air compressor head.
The compressor is activated when the ignition is on, and weight is added to the vehicle. The exhaust solenoid is connected directly to the battery (+), enabling the system to exhaust with the ignition on or off when excess weight is removed.
Vehicles With Road Sensing Suspension
The ALC system consists of the CVRSS control module, two CVRSS position sensors, an air compressor assembly, an ALC compressor relay, an intake hose and filter, an air tube, and two rear shock absorbers. The air compressor assembly consists of an air compressor and an air dryer mounted on a bracket. The air compressor head is a replaceable part of the air compressor. The exhaust solenoid is a non-replaceable part of the air compressor head.
The vehicles rear vertical height is measured by the two CVRSS position sensors. These two position sensors convert this rear height measurement into an analog voltage (0 to 5 volts DC) which is read by the CVRSS control module. The control module then determines what action (exhaust, compress, or no action) shall take place. To compress, the CVRSS control module switches the low-side of the ELC compressor relay to ground.
The air compressor is enabled (switched to battery only when the ignition is on. The air compressor is activated when a sufficient amount of weight has been added to the vehicle.
The exhaust solenoid is enabled at all times. The exhaust solenoid is activated when weight is removed from the vehicle.
Automatic Level Control System Operation w/o F45
Raising the Vehicle
When a load is added to the vehicle, the vehicle body moves down causing the sensor actuating arm to rotate upward. The upward arm movement activates an internal timing circuit and, after an initial fixed delay of 17 to 27 seconds, the sensor provides a ground to complete the compressor relay circuit. The 12V (+) circuit to the compressor is then complete and the compressor runs, sending pressurized air to the shock absorbers through the air tubes.
As the shock absorbers inflate, the vehicle body moves upward rotating the actuating arm towards its original position. Once the body reaches its original height, +/- 25 mm (+/- 1 in), the sensor opens the compressor relay circuit, and the compressor is turned off.
Air Compressor Head Relief Sequence
In order to reduce current draw during air compressor starting, the height sensor performs an air compressor head relief sequence before air compressor operation. This sequence reduces the air pressure in the air compressor cylinder during start-up. The air compressor head relief sequence occurs as follows:
Exhaust solenoid is energized.
Air compressor is activated 1.3 seconds after the exhaust solenoid is energized.
Exhaust solenoid is de-energized 0.5 seconds after the air compressor is activated.
Lowering the Vehicle
When a load is removed from the rear of the vehicle, the body rises, causing the sensor actuating arm to rotate downward. This again activates the internal timing circuit. After the initial fixed delay, the sensor provides a ground to complete the exhaust solenoid circuit, energizing the solenoid. Now, air starts exhausting out of the shock absorbers, back through the air dryer and exhaust solenoid valve, and into the atmosphere.
As the vehicle body lowers, the actuating arm rotates to its original position. When the vehicle body reaches its original height, +/- 25 mm (+/- 1 in), the sensor opens the exhaust solenoid circuit, which closes the exhaust solenoid and prevents air from escaping.
Air Replenishment Cycle
The sensor actuating arm position is checked when the ignition is turned on. If the sensor indicates that no height adjustment is needed, an internal timer circuit is activated. After about 35 to 55 seconds, the compressor is turned on for 3 to 5 seconds. This ensures that the shock absorbers are filled with the proper residual pressure. If weight is added to or removed from the vehicle during the time delay, the air replenishment cycle is overridden, and the vehicle rises or lowers after the normal delay.
Automatic Level Control System Operation w/ F45
Raising the Vehicle
When a load is added to the vehicle, the vehicle body moves down causing the sensor actuating arm to rotate upward. The upward arm movement activates an internal timing circuit and, after an initial fixed delay, the CVRSS control module provides a ground to complete the compressor relay circuit. The 12V (+) circuit to the compressor is then complete and the compressor runs, sending pressurized air to the shock absorbers through the air tubes.
As the shock absorbers inflate, the vehicle body moves upward rotating the actuating arm towards its original position. Once the body reaches its original height, +/- 25 mm (+/- 1 in), the compressor relay circuit is opened and the compressor is turned off.
In order to reduce current draw during air compressor starting, the CVRSS control module performs an air compressor head relief sequence before air compressor operation. This sequence reduces the air pressure in the air compressor cylinder during start-up. The air compressor head relief sequence occurs as follows:
When a load is removed from the rear of the vehicle, the body rises, causing the sensor actuating arm to rotate downward. This again activates the internal timing circuit. After the initial fixed delay, the CVRSS control module provides a ground to complete the exhaust solenoid circuit, energizing the solenoid. Now, air starts exhausting out of the shock absorbers, back through the air dryer and exhaust solenoid valve, and into the atmosphere.
As the vehicle body lowers, the actuating arm rotates to its original position. When the vehicle body reaches its original height, +/- 25 mm (+/- 1 in), the exhaust solenoid circuit is opened, which closes the exhaust solenoid and prevents air from escaping.
An air replenishment cycle (ARC) is commanded after each ignition-ON cycle. The purpose of the ARC is to ensure that the ALC system is operating at or above minimum air pressure (residual air pressure). The ARC occurs as follows:
The EXHAUST SOLENOID IS ENERGIZED 20 seconds after the ignition has been turned on.
The AIR COMPRESSOR IS ACTIVATED 1.3 seconds after the exhaust solenoid is energized.
The EXHAUST SOLENOID IS DE-ENERGIZED 0.5 seconds after the air compressor is activated.
The AIR COMPRESSOR IS DEACTIVATED 3.2 seconds after the exhaust solenoid is de-energized.
Dec 01, 2011 | 1998 Cadillac DeVille
Sony Lens Cap for A100
The Lens cap model of the Camera depends on the model of Lens which you're using with the Camera. The model # of the Lens Cap for the Camera body and the lens differs. Few models and the details are given below:
55mm Front Lens Cap - G Series logo
Model Number: ALC-F55G
72mm Front Lens Cap - Carl Zeiss logo
Model Number: ALC-F72Z
77mm Front Lens Cap - Carl Zeiss logo
Model Number: ALC-F77Z
77mm Front Lens Cap - G Series logo
Model Number: ALC-F77G
α Rear Lens Cap
Model Number: ALC-R55
62mm Front Lens Cap - Carl Zeiss logo
Model Number: ALC-F62Z
49mm Front Lens Cap - Sony α logo
Model Number: ALC-F49A
62mm Front Lens Cap - Sony α logo
Model Number: ALC-F62A
62mm Front Lens Cap - G Series logo
Model Number: ALC-F62G
67mm Front Lens Cap - Sony α logo
Model Number: ALC-F67A
55mm Front Lens Cap - Sony α logo
Model Number: ALC-F55A
72mm Front Lens Cap - Sony α logo
Model Number: ALC-F72A
77mm Front Lens Cap - Sony α logo
Model Number: ALC-F77A
Please enter the SonyStyle webpage and check for the compatible ones for the Lens which you're using.
Thanks for using Fixya.
We wish you a happy holiday season..
Dec 21, 2010 | Sony Lens Cap for A100
I wont to download dg31pr mother board sound drivers. I dont have any links that i download the drivers.so please help me, and give me any links to download it.
It must be Realtek Alc Audio Drivers, you can download it from this link (click here), Open the link, click "Download" then on the next page, click "Accpept" and again on the next page click "Audio: Realtek * ALC Audio Driver" download will begin automatically, save it an install it.
If you need further help, let me know with the operating system installed on your computer.
Good luck.
Thanks for using FixYa.
Sep 06, 2010 | Intel DG31PR Motherboard
Where is the a.i.r. pump located
The air pump for the secondary air system (emission control device) is located under the battery. If you do replace it, replace the check valve too, it is on top of the exhaust manifold and connected to the pump with a hose. The check valve fails and ruins the pump. Source(s): http://repairpal.com/volvo-850-1997/comm…
http://repairpal.com/air-pump-check-valv…
OR
I think they are talking about the pump to provide vacuum to the climate control when the turbo is putting boost in the intake manifold. The vacuum can come from an electric pump or from an engine driven pump, something like an old engine driven fuel pump. I needed an electric pump for my 765T, and all the wrecking yards wanted to sell me the engine driven form. (A new one was $500, and it wasn't that important to me.)
An engine that takes the engine driven pump will have a hole in it while the others will not have a hole. Source(s): 35 years maintaining my own cars, including 17 years with a 1985 765T
OR
Rear Suspension Leveling Air Compressor
RH front of vehicle, attached beneath the fascia
Rear Suspension Leveling Air Compressor Relay K19
Lower I/P, to the RH side of the steering column, on the relay box
Automatic Level Control System Operation Check
Support the rear wheels or support the rear lower control arms when certain tests require raising the vehicle on a hoist. Use two additional jack stands in order to support the rear lower control arms in the normal curb weight position when a frame type hoist is used. Refer to Trim Height Specifications in Suspension General Diagnosis.
Refer to ALC Suspension System Check for electrical troubleshooting of the Automatic Level Control (ALC) system, or if DTC's are present.
Diagnosing Leveling Complaints Without DTCs Present Procedure
Perform the following preliminary inspections before performing the system performance test:
Inspect the ignition (pin A & pin H) at the ALC sensor connector.
Ensure that the ignition (pin A & pin H) at the ALC sensor connector connection is secure.
Inspect the ground (pin E) at the ALC sensor connector.
Ensure that the ground (pin E) at the ALC sensor connector connection is secure.
Inspect the ALC sensor link.
Ensure that the ALC sensor link is properly secured to the actuator arm.
Inspect the ALC sensor actuator arm for damage.
ALC Diagnosis Table Step
Action
Value(s)
Yes
No
Has the ALC compressor assembly and the air tube been replaced?
Go to Step 7
Go to Step 2
Raise and support the vehicle. Lifting and Jacking the Vehicle in General Information.
Inspect the air tubes running from the ALC compressor to both rear shock absorbers.
Inspect the air tube connection at the ALC air dryer.
Are the air tubes damaged and/or disconnected?
Go to Step 13
Go to Step 3
Squeeze the left rear shock absorber in the middle of the air sleeve.
Did the air sleeve slightly compress?
Go to Step 5
Go to Step 4
Operate the ALC system for 60 seconds.
Test the air tube-to-air dryer connection for leaks using a soap bubble solution.
Is a leak evident?
Go to Step 20
Go to Step 5
5
Disconnect the air tube from the ALC dryer.
Connect the Pressure Gauge to the ALC dryer.
Close the toggle valve on the Pressure Gauge .
Operate the ALC compressor.
Did the pressure build to the specified value?
80 psi
Go to Step 6
Go to Step 10
6
Shut off the compressor when the pressure reaches 80 psi.
Monitor the gauge for 1 minute.
Did the pressure leak down?
Go to Step 10
Go to Step 7
7
Connect the Pressure Gauge to the right rear shock absorber. Ensure that the toggle valve on the Pressure Gauge is away from the shock absorber.
Close the toggle valve.
Pressurize the shock absorber at the toggle valve on the Pressure Gauge to 80 psi.
Did the system leak down?
Go to Step 11
Go to Step 8
8
Use the toggle valve on the Pressure Gauge in order to slowly release the air pressure.
Disconnect the Pressure Gauge from the right rear shock absorber.
Connect the Pressure Gauge to the left rear shock absorber.
Pressurize the Pressure Gauge to 80 psi.
Go to Step 12
Go to Step 9
9
Disconnect the Pressure Gauge from the left rear shock absorber.
Connect the Pressure Gauge , inline, at the tee near the rear of the vehicle.
Reconnect the air tube to the ALC dryer.
Open the toggle valve on thePressure Gauge .
Using shop air, pressurize the system to 80 psi at the service connection of the Pressure Gauge .
Monitor the pressure gauge for 1 minute.
Go to Step 14
Go to Step 20
10
Replace the following components:
• Replace the ALC compressor. Refer to Air Compressor Replacement .
• Replace the air tube. Refer to Air Tube Replacement .
Are the replacements complete?
Go to Step 20
11
Slowly open the toggle valve on the Pressure Gauge in order to relieve the air pressure.
Replace the right rear shock absorber. Refer to Shock Absorber Replacement in Rear Suspension.
Reconnect all of the air tube connections.
Is the shock absorber replaced, and are all of the air tube connections reconnected?
Go to Step 20
12
Replace the left rear shock absorber. Refer to Shock Absorber Replacement in Rear Suspension.
Go to Step 20
13
Are any of the air tubes damaged?
Go to Step 14
Go to Step 18
14
Replace the air tube that runs from the air dryer to the two rear shock absorbers.
Is the replacement complete?
Go to Step 15
15
Remove the ALC air dryer from the compressor assembly.
Shake the ALC air dryer with the head connection down.
Did water/moisture come out of the ALC air dryer when the dryer was shaken?
Go to Step 16
Go to Step 17
16
Replace the ALC air dryer. Refer to Automatic Level Control Air Dryer Replacement .
Go to Step 17
17
Replace the air compressor head. Refer to Automatic Level Control Air Compressor Head Replacement .
Go to Step 18
18
Install the ALC compressor on the vehicle.
Is the ALC compressor reinstalled, and are all of the air tube connections reconnected?
Go to Step 20
19
Repair the air tube-to-air dryer connection leak.
Is the repair complete?
Go to Step 20
20
Reconnect all of the connectors that were disconnected.
Reconnect all of the components that were removed.
Clear all of the codes with the ignition ON and with the engine OFF.
Wait at least 5 minutes.
Is the rear of the vehicle trim level?
System OK
Aug 04, 2010 | 1998 Cadillac Catera
Iwant (ALC) head light system ....work normal
Pull out the ALC fuse from under the hood.
Dec 25, 2008 | 1999 Chevrolet Malibu
Brother mfc210c
two ways to refill lc41:
drill a 2 mm hole into the brandname (e.g. O of brother ) on top of the cart. You can leave the hole open and leave the carts in the printer in future for further refilling ;-)
The cart can be refilled by inserting a syringe without a needle into the ink Outlet(!) at the bottom, too. Carefully press a 12ml for C/Y/M and ca. 15ml - 18ml for BK into the carts.
Anyway:
Do use DYE-ink only!
Important: You must mix the dye-ink with some 85%-glycerin alc. to keep the print head nozzels alive = 10ml ink with 2ml glycerin alc (drugstore).
For BK: 15ml ink + 1,5ml glycerin alc!
Feb 29, 2008 | Brother MFC 210C All-In-One InkJet Printer
Facebook Social Network Logo
14 people viewed this question
Top Facebook Computers & Internet Experts
David Payne
David Payne
Are you a Facebook Computer and Internet Expert? Answer questions, earn points and help others
