Question about Samsung HLP4663W 46" Rear Projection HDTV
My TV is automatically turning off. I first thought it was getting a signal from a remote, but that's not the case. It turns off then is in a type of sleep mode for about 10 seconds with a red light indicating "standby / Temp" staying on and the green light indicating "lamp" stays on also.
    Problem Solver:
  • 10 Answers
It sounds like you are having a problem with a cooling fan.
Posted on Mar 16, 2011
  • stu0183 Mar 16, 2011
    Take the access cover off the back of the TV. Once removed, you'll see a blue switch at the bottom. Work that back and forth 6 or 7 times. Remove square cooling vent and make sure it's clean. This is a black square vent that just snaps out to the right of the switch. It's about 3 inches square, can't miss it. Put the vent back in place and replace outside cover making sure the screw holding the cover is tight. That's it. Your TV will not turn off anymore.
Why does my t.V keep switching to dvd screen.
TVs turn on in the last screen they were turned off. Try switching screens using the remote control. If the dvd screen keeps coming back, try pressing or tapping on the manual key located on the side or bottom or back of the TV panel. Sometimes this key gets stuck up. If this does not work, try unplugging your home theater and turn on the TV. Most TVs automatically switch to DVD when they sense signal from HDMI cables.
Nov 26, 2014 | Televison & Video
I purchased a used 32LG3000 3 weeks ago. Worked perfectly for 2 weeks. One week ago it turned itself on in the middle of the night and now we have all types of problems. Does not respond to remote at...
This problems the tv itself have a intermittent problems in the tv Tuner signal board.That the tv board that where the tv incomming broadcasting tv signal cable plug into it.This tv problems can't be fixed,because it could be anywhere in the tv Tuner signal board parts problems itself.If u bought this tv by a dealer,reconmendation exchange it for another tv.
Aug 13, 2011 | LG 32LG30 32 in. LCD HDTV
How do i search for codes on urc20-d1f
URC20 D1F
Set up by Automatic Search
1. Turn TV on
2. Point the remote at tv and Hold SET and TV buttons at the same time and keep pressed for 3 seconds.
3. The LED flashes and the remote control starts the automatic search.
4.The OFF signal is automatically sent to the tv from the remote control.
5. Once the TV switches off press any button except SET to stop auto search.
6. Switch your tv on using the POWER button.
Jan 02, 2011 | Televison & Video
Hello i need codes for asda's universal remote model URC20-D1F so i can sync it with my BEKO tv please can you help?
URC20 D1F
1. Turn TV on
Dec 27, 2010 | Beko 142746 TV
I need the codes for an ASDA remote control, model no: URC20-D1F
URC20 D1F
1. Turn TV on
May 09, 2010 | Universal Remote Control Remote Control
Need code for asda remote model#URC20-D1F for use with my sony tv
URC20 D1F
1. Turn TV on
Sony TV codes
010,011,028,030,031,077,107,128,131,166,203,237,302,309,367,444,445,446,449,160
To enter. Just hold SET and TV at the Same time.
The red led light stays on you are in set up mode.
Enter the first code on the list and try power button.
Keep following the steps untill you can turn the tv off.
Then its set.
Feb 08, 2010 | Televison & Video
Works on occasion.
I believe this set has two relays in the power supply. One for standby power and one for full power. I have seen cases where the full power relay drops out or not energise causing the same symptom you describe. Lightly tapping on the relay sometimes identifies the culprit.
Hope this helps
Skyassoc
Jun 20, 2009 | Hitachi 53UDX10B 53" Rear Projection...
TV DOESN'T STAY ON BUT A FEW MINUTES THEN AUTOMATICALLY TURNS OFF
lost my code book need the code for a phillips universal remote for a konka tv.
Oct 19, 2008 | Philips Magnavox Learning Universal Remote
Magnavox 15" lcd says it has attention no signal
Had the same problem. The solution: My remote has a button labeled "TV/VIDEO". I must have accidentally pushed this button so when I turned the TV on it was searching for the signal from a VIDEO source. It couldn't find the signal so it's programmed to automatically turn off if no signal is received. All I did to solve problem was I turned TV on and before it could turn off by itself I pushed the "TV/VIDEO" button on my remote to switch it back to receiving TV signal.
Jul 13, 2008 | Philips Magnavox 27MS343S 27" TV
Picture partially cropped at bottom of screen
Normallly, if the picture size button on the remote for the television does not achieve the desired affect, then, a cable box or a satelite box is where the change needs to be made.
For example:
A Motorola Cable box needs to be set up to go to a wide screen or zoom when an analog signal is detected.
Some Dish Network boxes have Size buttons on their remotes and also in their main menu.
It's difficult to determine the repair without knowing the types of the peripherals.
Hope this helps.
Dec 24, 2007 | JVC AV-27230 27" TV
Samsung HLP4663W 46" Rear Projection HDTV Logo
611 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
