Question about Velodyne DPS-12 Subwoofer
The LED light above the 'night' button on my DPS subwoofer is blinking (fast) constantly and I can't tell which preset my subwoofer is currently in - I tried to restore the default and the 'Jazz Classical' light illuminates when I turn it on and then it disappears - I've tried to select 'Movies' but it doesn't seem to work. I'd like to have in in 'Movies' preset and have the LED lights stop blinking constantly - can you help? Thanks
3 Suggested Answers
  • 151 Answers
SOURCE: how to connect pioneer reviever to velodyne subwoofer
Look for the sub pre out on the back of your amp and connect a sub cable to this and next to the LFE or phono type input on the back of the sub ,if it has two inputs left and right pick the left side ,set the cross over to suit your system and speakers,if you are not sure set the cross over to 80 hertz,this is a thx standard.
hope this helps.
Posted on Jul 03, 2008
SOURCE: Subwoofer is not working
Please check the pins of the plug (round one connecting woofer and speaker). Most probably one or more of the pins could have been bent.You can straighten it with a long and strong needle. All the 10 or more pins need to be seated in the slot. Each pin has a specific function for the sound system.I tried this to my computer speaker Altec Lansing VS2521 and it was successful. I have already posted my method after I made a query like you. If my suggestion does not work be patient for a while and apply your mind exclusively on the problem and you will also come across a solution. Any way keep us informed of your progress.
Thanks and regards
M. Narayanan
Posted on Jan 17, 2010
What resistors do I need to fit LED tail lights to a 2012 PX Ford ranger ute
fast blinking light tells you that one of the bulbs is bad. replace the bad one and it should be fixed not need for resisters EVER
Jan 05, 2015 | Ford Cars & Trucks
DPS-219EP A problems
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link
Dec 02, 2013 | Sharp Aquos Televison & Video
I can't program the presets on the radio. when I push the memo button, the only thing that flashes is the memory light, and not the station #. The manual is not very helpful. How do you program the...
On most radios you select the station you want and then press the preset number you want (1-6) for a few seconds. For example; if you want 90.5 in preset number 4, you would press the number 4 button for 2-4 seconds until it blinks.
Apr 14, 2011 | Car Audio & Video
Blinking night light
Night mode limits the maximum output of the subwoofer for later night listening or to be more considerate of close neighbors. Press the night button to turn the night mode feature on or off. Night
mode, when active, is indicated by the flashing blue power LED.
May 16, 2010 | Velodyne DPS-12 Subwoofer
The night button is flashing and the sub is not working correctly what should i do?
First I would sugest you contact the place you purchased it, they may be able to test and repair if needed.
The other option is to contact Velodyne directly for service.
Nov 25, 2009 | Velodyne DPS-10 Subwoofer
I can't get Jabra BT 2050 bluetooth into pairing mode. I follow the instructions but never get the solid light. What can I do?
Booklet instructions for how to pair it with a new device are wrong. It tells you holding the power button will put it into pairing mode but it does not.
Pairing mode is done by turning off the ear piece, then holding both power and answer/hangup at the same time. The LED should flash fast 3 or 4 times and then stay on solid. You might need to hold just power till the very first flash THEN begin holding answer/hangup as well as power till the LED goes constant. I’ve also had luck when frustrated by just holding all 4 buttons at once.
Oct 10, 2009 | Jabra BT2050 Bluetooth Headset
D530s will not power up, odd blinking green LED on mobo
Ok, this is acting as if your MB is getting power but doing nothing with it. This very well could be a MB problem where something (unknown without looking at it) is fried. Just for grins, take the cmos battery out and let the pc sit for 1/2 to 1 hr before putting it back. If this does not work, I would contact HP for a replacement MB.
Aug 17, 2007 | HP Compaq Business d530 Small Form Factor...
Velodyne DPS-12 Subwoofer Logo
102 people viewed this question
Top Velodyne Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
Vito Vacirca Jr.
Are you a Velodyne Audio Player and Recorder Expert? Answer questions, earn points and help others
