Question about Ovens
Hi, i have got newworld NW70DO model oven. I switched on power for pre heating purpose but in 15-20 minutes it had blown up. There was no light in other appliances and the light bulb due to fuse blown up. I fixed the main switch board and power came back to other stuffs but power not on in oven. so, could you please guide me?
  • 6 Answers
SOURCE: Main oven not heating.
Hi, Is this your fan oven element that is not getting heating up? If so we have a guide on our site which may be of assistance: http://www.ransomspares.co.uk/fan_element_article.html
Posted on Mar 01, 2007
  • 1462 Answers
SOURCE: fan oven not heating, bosch hbn 202t
the fan oven element is separate from the grill element. the problem is that the circular element round the fan is blown. remove the back panel of the oven and you will see the element. replacement is easy. on most bosch, the element is removable from inside the oven but for some you have to remove the oven and take off the back casing
Posted on May 04, 2007
hotuna
  • 288 Answers
SOURCE: Oven Switching Off
I have a few questions. Does the oven reach the set temperature? How do you get it to go back on? and if you do not set the time do you have the same problem?
Posted on Dec 06, 2007
aborcass
  • 2651 Answers
SOURCE: Wont' heat in broil or bake
check incoming electric first, pull it out and gain access to main wire terminal, With multimeter set to at least 250v AC , check your power across the wiring as such. black to white (110v), red to white(110v) and then black to red 230v. if that ok ok turn, then start ckin elements for continuty also there might be a thermostat( usually an 1 in. round component with 2 wires located right inbetween the elements that has gone bad, will show no continuity. ck that before electronic control the fact that its clickin sounds like the relays are workin properly
Posted on Feb 23, 2008
SOURCE: Main bottom oven not working
i solved the problem by replacing element . new one cost 23 euro from electrolux spare parts dealer .1 undo 4 screws of plate inside the bottom oven . [ plate has holes in a circle patern in the middle of it ] . 2 gentle remove plate and expose the element .3 element has 3 srews .undo these and gentle take away from ovens backwall wall this will expose 2 wires that are connected to the element .3 very gentle unclip the wires from element . {grip the clips not the wires } connect new element and replace all screws and outer plate . this worked for me ....... remember to turn off the power to the oven before you go at it .
Posted on Apr 17, 2008
My newworld newhome cooker's ignition does not work. Please could you tell me where the battery goes as I cannot find it.
The battery is in a case (plastic holder) left hand side right near the floor in the plinth, opening the oven door will make it easier to see. (Assuming I have the correct model)
Dec 09, 2013 | New World Ovens
My new world double oven fan makes a loud noise and now the large oven does not heat up
Newworld model 444447289 made a loud bang and doesn't come on. The top oven oven is ok. What could the problem be
Oct 11, 2013 | Ovens
When the oven is heating up, a light inside the oven flashes very brightly. Not sure what that means or if it is unsafe.
when the oven is cold open it and ensure the light inside is screwed in fully. It is probably making poor contact when it is cold.
If that does not fix it, ignore it. If the power to the element was shorting it would trip the earthleakage or your main power switch.
LPG
Sep 10, 2012 | Whirlpool Ovens
Hi - have a Neff U1721 double oven, the element in main oven went bang cracked the element and blow a hole in fan cover. replaced the element but now temp light comes on but doesn't heat up, can you...
Test element check for continuity across the terminals and it is getting power when switch onon. If both ok, chances are the front selector switch has blown.
Feb 01, 2011 | Neff U1721 Double circotherm Electric Oven
Pre-heat oven, insert food, after few minutes, stove shuts off - no heat.
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jan 10, 2011 | Kenmore Ovens
I dont no how to pre heat the oven
To pre-heat an oven is to simply turn it on to the desired temperature and wait 5 to 10 minutes. If you have a timer then set the timer for the desired time you want to pre-heat then begin baking as usual.
There is no magic to pre-heating an oven and everyone that bakes has a different opinion.
Sep 23, 2010 | Ovens
Newworld dfeo 90 main fan oven not heating - fan works! - which part most likely faulty
If it is an electrically heated fan oven, then I would suspect the oven element has failed, this is at the rear of the oven compartment behind a removeable cover.
If it is heated by gas, then I do not have an answer for you,as I have no knowledge of gas ovens.
Hope this helps.
Jan 30, 2010 | Stoves Ovens
My HBL452 double oven is slow to heat both upper
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Dec 01, 2009 | Bosch HBN 452 / HBN 456 Electric Double...
Hi. I have a ge convection oven(JCTP17) that has been working great until recently. I bought a Taylor oven thermometer model number (503) To check othe oven temps to see how accurate the oven is. I do a...
The Taylor oven thermometer you bought is decent at best. It is most likely the sensor inside the oven. Has your clock displayed any fault codes? F, followed by a number? Changing the sensor will probably correct the problem.
Aug 19, 2009 | Ovens
Electrolux oven wont heat up after power cut
hiya
sounds like the fan element could have blown, causing the electrics to trip out. best thing to do is remove all the racking
and then the rear panel that covers the fan and element. if he element has blown most of the time it will be visible.
hope this helps
please dont forget to rate the helpfulness of this reply thanks kj
Aug 03, 2008 | Electrolux EOB6636X Ultrafan Electric...
Ovens Logo
50 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
