No Color My parents recently bought a Sanyo DP37647 LCD HDTV. When they hooked up their DVD/VCR, there was no color when playing dvds or tapes.The player worked fine before the change of televisions. The previous tv was older. I don't have a clue as to the age of this dvd player. I assume there is a compatiability problem between the TV and the dvd player but I would hate for them to buy a new dvd player only to find the same problem!
  • natalie3086 Aug 02, 2008
    dvd's only perform in black and white and no color.have already changed the cable.
  • Anonymous Aug 16, 2008
    I have no color it was working fine where do you go to change the color i cant seem to find it
sandrew
  • 2961 Answers
SOURCE: HELP! I can't figure out how to Connect my Sylvania DVD/VCR Combo to my older TV
Even if you do get it connected you cannot copy from vhs to dvd as you have bought a vcr recorder with dvd player, not a dvd recorder. You can only record to the vcr tape from a dvd, in the players controls.
Posted on Feb 08, 2007
markevans
  • 148 Answers
SOURCE: VCR/DVD setup for color on LCD TV
check to see you have the cables required by the tv. usually you need hdmi or dvid for hd display. digital rights management protocols have resulted in chips in playing devices that allow only the use of the referenced cables to protect content from being copied. in some sets they default to not playing in hd, but still play something.
look there first, otherwise you may have an input source mismatch. follow instructions on the dvd player first, then make sure the tv has compatible settings.
if that does not solve, you have a service issue with one or both.
good luck
mark
Posted on Dec 23, 2007
  • 7 Answers
SOURCE: new dvd/vhs player but old tv
The easiest thing to do would be get a new TV plain and simple sounds as if you could use one n e ways. But first make sure you are hooked up through coaxal to the tv that will allow everything to run on channel 3. Let me know your current hookup.
Posted on Dec 25, 2007
SOURCE: DVD plays only in black & white
Try turning on component (cable) for the V2 input  on your TV
Posted on Jan 08, 2008
SOURCE: Can't get picture on TV.
If you were using RCA cables, you may have had them hooked up wrong. I know this may sound like an easy fix, but I still hook them up wrong from time to time. Especially if there are more than one set of RCA hook-ups on the back of the unit. If you were using a S-video cable you shouldn't have to use RCA cables, if you had both hooked up that could cause your DVD/VCR unit to not work properly and only get a partial feed to the TV. I hope this helps a little. Good luck.
Posted on Jun 18, 2008
Why GE TV plays color DVD/VCR tapes in black and white
Some inputs on tvs won't process the color signal. Try one of the other inputs. Mine does the same. If u have already used the working ones on something else, U will need a switch to select one or the other available at Radio Shack if u can find one.
Jan 22, 2018 | GE Televison & Video
I have a Sanyo DP37647, the red color seams to have disappeared. We've adjusted manually, but can't get the red color back to the screen. Red's are now showing as black.
Tries the broadcasting incomming signal cable,with another tv connected to see,if can get the red color,if no than,the imcomming the broadcasting cable it the problems.If yes,ur tv have a Tuner board problems,it dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner signal board for the replacement.
Oct 25, 2010 | Sanyo DP37647 37 in. LCD TV
How do I hook up my vcr to my dvd recorder so I
You will need one RCA video cable it will have a yellow, red and white plugs. On the back of your VCR locate where the color inputs are find where it says VIDEO OUT hook it up there. On the back of the DVD Recorder look for the same color input jacks NOW find where it says VIDEO IN hook it up there. You may have to turn on your TV,DVD recorder and VCR to get the right channel. your Recorder may have one or more video inputs if it does turn on all three. Use the channel on your TV you use to watch DVDs make sure you see your DVD screen. Now to record to a DVD. Change the channel on the DVD Recorder. Look for the input channels It may be Video 1 Video 2 etc... depends on the inputs you have. ( A great way to tune your DVD Recorder is to play a prerorded VCR tape. Turn the channel on your DVD Recorder unil you see the prereorded tape playing. )
Jul 21, 2009 | Toshiba Audio Players & Recorders
Plays vhs tape in only black and white (no color).
my old series of ROOTS is playing in black and white and says on cover that they are in color
Jul 03, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
PAL VHS bought from England won't play in my (USA) Sanyo VCR
Short answer is no,if it was a dvd you could,but not tape...sorry
May 03, 2009 | Televison & Video
Can't get my sony dvd/vcr model rdr-vx560 to record from my tv
I just gave up. I was told this tv didn't have a video input. Just decided to recford on my old vcr and just use the dvd/vcr to dub tapes to dvds. thanks anyway. JoElla
Jan 11, 2009 | Televison & Video
DVD hookup to LCD monitor only appears in black and white!
I have a RCA flat screen television and my dvd player when hooked up is in black and white. How would i fix this and if so plz be more specific then these other people.
Jan 02, 2009 | Insignia 32" 720p Flat-Panel LCD HDTV
VCR WON'T RECORD
you may have the outputs hooked up correctly however you may need to set the inputs to the selected type of cable you are using. S video 1 cable or video input witch is an rca adapter yellow in color. you will find these setting in the "setup section" on the remote set up button will get you there and then input or source.
Dec 04, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Toshiba MW27F51
It is not clear whether one DVD or all DVDs play in black and white. If it is only one make sure that the format of the DVD is correct. If it is all DVDs, given that the VHS tape and cable play with color, there could be a problem with the chroma circuit in the unit. This is probably something that a technician would need to diagnose. Good luck.
Jun 30, 2006 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
