Question about Philips Televison & Video
I am trying to connect a Advent notebook to a Phillips 42PF9641D/10 TV via the VGA socket and the Audio L/R socket from the headphone socket on notebook. I can get picture but no sound on TV but ok if headphones are fitted? have set up menus on tv as per manual and used new cables to tv, What am I doing wrong ????
  • 11,361 Answers
Does my HP dv9449us has HDMI port? Can I connect it with my tv using this cable or what cables do I need? We have LG LCD tv.
Your laptop does not have a HDMI port. You only have VGA, you have to purchase a VGA to VGA cable VGA is video only interface. So you will need it along with the stereo audio cable
http://pctvcables.com/vga-with-audio-pc-to-tv-cables.html
Note that the stereo audio cable shoulb be connected from the headphones jack on your laptop to the headphones jack on you home theater system if you have one or buy this adapter plug the stereo audio cable coming from the laptop into it and connect it to the stereo audio in (red and white audio)of your tv
http://www.amazon.com/Male-3-5mm-Stereo-Female-Y-Cable/dp/B000I23TTE
Aug 18, 2011 | HP Pavilion DV6449US Notebook
I have an Acer aspire m3200. I tried to connect it to my hdtv, i got picture but no sound using the VGA cord, and got nothing using the HDMI cord. Please help
Using a vga cable to connect your laptop to a hdtv is very easy but the cable does not transfer the audio signal, you need another cable aswell. You need a 3.5mm jack to jack cable, one end plugs into your headphone socket on your laptop and the other end plugs into the pc audio socket at the back of your tv (usually next to where you plug in the vga plug).
May 28, 2011 | Acer Computers & Internet
Want to connect laptop to tv?
If you are using a LCD/TFT tv it will have HDMI and VGA inputs.
You only need a simple vga lead but this only transfers video not sound.
You can get a usb to hdmi lead, you can also plug in audio leads from your headphone socket and this will transfer video and audio.
Jul 10, 2010 | Toshiba Satellite A100-S8111TD Notebook
Connect a acer aspire to a tv to play films does it have a vga card??
Please check the ports at the bacj your tv if it has a vga-in. If it does, then you can connect a vga cord, then set your laptop to display on external viewing device by pressing Alt+F5 or please see the manual that came with your Acer Aspire.
Apr 01, 2010 | Computers & Internet
No audio output to tv on my dell 1545
That, & most, earphone sockets, simply doesn't have enough "Current" or signal voltage to drive your TV set's audio in Amplifier. You need to get a Pre-Amp, to amplify the signal, up to a level that can be used by the TV. So you need to purchase, or build from a kit, a small stereo pre-amp and insert it between your laptop & TV audio In.
Feb 04, 2010 | Dell Inspiron 1545 Notebook
Connecting an Acer 6920G to a LCD TV
Unfortunately, DVI doesn't support audio. Your headphone output may work if you have a PC audio input on the TV. However, you might need to change the audio output on the Acer 6290G. It is probably defaulting to using the HDMI audio output.
Go to the Control Panel (click on Start). Select the Hardware and Sounds section. In Sounds, look for Manage Audio Devices. Change the Default Audio Device to a different Audio device (look for Output in the description). Note: you may need to turn off the computer and TV and turn them both on for the headphone jack cable to be identified.
If this doesn't work, check the manual for the TV. It might only have the PC audio connection available for a VGA port. Please add a comment with the TV model, if you need assistance with this step. Make sure that you aren't connecting the headphone out of the 6920G to a headphone out on the TV.
I hope this helps.
Sep 07, 2017 | Acer Aspire 6920-6422 Notebook
How can I connect my notebook to my TV
In order to display PC video on a TV the PC must have a TV-OUT function and interface, or you need a VGA to TV converter box.
If your PC has TV-OUT functionality, your user manual will tell you this. If you have, Google "Display PC on TV" and you should find some good articles on how to connect the PC to the TV, and how to change the settings on the PC. NB. even if your PC supports TV-OUT, you may still need to buy a converter cable (but not a box).
If no TV-OUT functionality, E-Bay lists some converter boxes from about £15. NB. the much cheaper cables only work on PCs with TV-OUT functionality.
Oct 03, 2009 | Advent 4211c Notebook
Issue playing audio from AcerTravelMate6593 on Phillips37PFL7603D
You need to run the audio out to an amplifier such as a stereo unit. The computer doesn't have enough power via the line out to make the TV pick up the sound by itself unless you turn the volume all the way up and maybe not even then, so an amplifier is your answer. It work for me.
Aug 17, 2009 | Acer TravelMate 6593-6656 Notebook
Taptop connect to TV audio preoblems
Hi there.
If your TV supports a VGA cable it should also support computer audio in. You need to purchase a mini stereo cable and plug it in to the headphone socket on the laptop and run it to the computer audio in on the TV,just using the VGA cable alone will not produce any sound.
Purchase something like this for the audio >>>>>>
Good luck and thanks for using FixYa!!
May 23, 2009 | Dell Inspiron 1525 Notebook
UMC 19in TV with built-in DVD player - model L19/7TCD
Try connecting earphones or headphones to the 3.5mm Headphone socket on the TV and check this works correctly, i.e hear TV when watching TV, hear DVD when watching a DVD etc.
If all is OK, purchase a 3.5mm Jack to L/R Audio/Phono cable. Connect the 3.5mm jack in to the headphone socket on the TV and connect the red/white phone ends to the 5.1 surround system.
It should solve it. SCART out is not always live in all sources so is not a reliable way to connect.
May 22, 2009 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Televison & Video Logo
572 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
