It wont switch on i have checked the fuse and opened tv up to see if ther was power goin in to it but nothing the lead is ok but whats wrong possible answers?
  • 11,361 Answers
Make and model of the TV?
Mian AC fuse in the power supply module is OK?
LCD flat panel? Plasma? DLP?
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Posted on Mar 16, 2011
Replaced fuse for interior lights still dont work
ok, if you are sure the bulbs are good AND theres power to the line its most likely your switch. typically two types of swtches, the one in the dash that you control and the door switches for when the door is opened. look at the dash switch first, slide underneath the dash and see if you have access to the switch wire. using a current tester check the hot line leading to the switch (make sure its the hot side). if theres power going only one side of the switch it will need to be replaced... dealer, salvage yard or even Ebay should be easytofind before going to dealer. if theres power on both sides of the switch then you will need to check the door switches which is harder to access. check your manual for wire codes and get close as possible to the switches. always use safety when checking wires, you dont want to tap the wrong wire for many reasons.
Nov 30, 2013 | 2008 Nissan Sentra
My tv screen has turned white
Check and replace its T'Con board.
May 07, 2013 | LG 42LG30 42 in. LCD HDTV
92 plymouth voyager wont start and nothing work the windows wont go down the lock and unlock button does nothing idk what the problem is i had the battery tested and the battery is fine what would cause...
Nothing works? How about the headlights, do they work? If yes, then start checking all fuses in the Power Distribution Center or Box under the hood. If no, then look for a bad maxi-fuse in the PDC, and check for a bad fusible link between the battery and the PDC. The battery positive cable goes to the starter, but a pigtail lead off the positive would go to the PDC, to distribute power to all the various circuits on the car.
When you turn the key to on, does the dash light up? If yes, at least power is getting to, and going through the ignition switch. One could then check for power on the starter solenoid wire when key was held in crank or start position.
If nothing when turning key to on-no dash lights, nothing-then check for an ignition fuse in the PDC. If fuse is good check for power being available at the ignition switch connector. If no power there, check wiring between PDC and the ignition switch-if power is up to the switch, but nothing happens with key on, no dash or warning lights, then could have a bad ignition switch.
It just sounds like a maxi-fuse has blown, or a bad fusible link. Good luck.
Mar 18, 2013 | Cars & Trucks
Wharfedale LCD2710HDAF no power to tv, checked cable and changed fuse a few times, new power lead? or is this a common problem?
Hi.
The power cord must be checked using a multimeter. The test is done reading impedance (ohms) between plug's prongs and contacts to TV power board.
If the power cord is OK and there is no power, then the problem is the power board inside the TV.
Regards.
Ginko.
Dec 04, 2011 | Televison & Video
95 volvo 850 drivers door inside wont open
got the panel off?, i'm gonna assume it's power not a hand crank and that you've also closely checked your fuses, the only thing left is maybe a wire has come off the contact or you've burnt out the switch and that may need to be replaced but I'm sure if you inspect and follow the wires it may lead you to a problem along those lines. If nothing is wrong with the wiring, it could be the switch itself I don't know either how to nail down the issue so you could find out, maybe use a battery with some wires and try touching the leads and just give it power and if the door unlocks then you know it is your switch. Good luck
Sep 21, 2011 | 1995 Volvo 850
Will not switch on - machine has no power
I wonder if you just went to turn it on via the power switch on the operation panel and nothing happened? if so then its just possible one of the switches on the operation panel has become stuck. this will prevent any other switches from doing anything. So thats the first thing to check. 2nd make sure you have power to the machine from the power lead. have you checked and changed the fuse in the plug? If all these are ok then its either going to be the power supply in the machine (they never go wrong) or the logic board. Best take it to a canon agent for further diagnosis.
Srri
Jul 21, 2011 | Canon PIXMA MP600 all-In-One InkJet...
26la30q wont turn on
Hi
You have to start checkin from its main ON/OFF switch itself. If the switch have any contact contact trouble, the set will not turn On, even though you hear the click sound from the switch. If switch is Ok, then you have to come to the power supply regulator board. It can be easly recogonized the powe supply regulator boad. The main supply line will go straight to it. There will be more that 5 or mor secondary voltages from it, according to Tv model. These secondary wupplies will energzed only after the power supply switching circuit work properly.
Ther is a fuse [ a cartridge type; replaceable]. Check the fuse first. If it has blown; be carefull when you replace it; because there must be some reason for the blowing of that fuse. It is really a protection device. Before replacing it, you have to check the entire power supply board for some short circuit. If you have sound knoledge in repairing Switched Mode Power Supply [SMPS]; just proceed. Otherwise get it repaired by any experienced service technican or by authorised service center for Proscan. OK.
Jul 08, 2011 | Proscan 26LA30Q 26 in. LCD Television
No power - have checked fuses, power leads and master switch
Well yes, there a problem in the power supply modual.
It does sound like a failing power supply , becuse of the
fact you don't get charge up spark from the plug , wich is normal
affter it's been off /unpluged for 20 min or so .
check the resistance of the plug coming from the set with a volt meter if you have 10 meg ohms or higher,
it's an open circuit and more than likely a 1.50 fuse in the power
supply. If the fuse blows instantly then it's a shorted output transistor or rectifier diode in the switching power supply.
Be a shame to pay 300.00 plus for a stupid fuse.
hope that helps a little . if you have any questions just comment
an i'll respond
Rob
Oct 03, 2009 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
Tv wont switch on
This could be a problem with the power supply. Yes there is a fuse on the power supply & if you have a multi-meter & are competent with electrical safety, you could test it. However, if it has blown then almost certainly something else will have caused it. You might have a short circuit bridge rectifier or faulty chopper transistor. If the fuse is ok, then you will need to check voltages from the power supply to find out what feeds you have. There may be a start resistor open circuit for example. If most of the start up voltages are ok, then you need to look at the line output stage & check if this circuit is getting any voltage supply.
Jul 15, 2009 | Panasonic CT-32SL13 32" TV
Tv will not turn on no red light
take a reading at the main power coard with a multi meater.
if reading is open ther might be a internal open fuse.
Jan 09, 2009 | Spectroniq PLTV-42HW68 42 in. LCD TV
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
Electro Med Services...
