Question about Minolta DiALTA Di520 Laser Printer
Minolta cspro ep 3010 code c0924 - Minolta DiALTA Di520 Laser Printer
  • Minolta Master
  • 6,161 Answers
On the control panel is there a little icon like wrench in the left hand corner of the screen, if so touch it then new screen will appear, once new screen appears open close the front door to reset the code
Posted on Feb 22, 2015
SOURCE: ep2080 minolta cspro
Ep2080 minolta cspro error code comes up with c0500
Posted on Jun 17, 2008
Cogz
  • 1326 Answers
SOURCE: problem in minolta cspro 2050
What code are you looking for??? I'll tell you what it means for FREE.....
Posted on Aug 20, 2008
SOURCE: meaning of code C04 ( EP 2030)
minolta cspro1054 turns off once you turn it on and code is c
Posted on Nov 03, 2008
  • 17 Answers
SOURCE: Minolta CSPRO EP 3050 turning it On appears display Code: C0200
A C0200 is a problem with one of the coronas - could be the charge, transfer, or separator.
First try resetting the code by opening and closing the main front door with the machine powered up and the error code showing. This should make the code go away.
It may or may not come back. If it does, clean the coronas.
It is necessary to remove the drum assembly in order to access the charge corona.
The EP3050 originally came with a self-replacing charge corona. It actually had a small spool of corona wire in the charge corona assembly, along with a small motor that advanced the wire every few thousand copies. This was prone to malfunctions, and there was a retrofit kit which replaced the whole thing with a conventional wire.
If you still have the code, and have no idea what I'm talking about, then it is probably time to call a technician. :-)
You will need to call an independent, as Konica Minolta no longer supports this model.
Posted on Nov 13, 2008
claudiomn
  • 10 Answers
SOURCE: my Minolta ep 1030 shows C04
Verify exposure lamp or  lamp's fuse.
Posted on Jan 17, 2009
Cspro ep 2030 minolta copying rough in the morning, but okay in the afternoon, solution please
Sounds like the warm up controls are not opperating properly. Or it is in a very cold environment. The "fuser" that provides the heat required to "glue" the toner to the paper may be defective, or the connections to it's controller or the controller is defective. Temporary solution may be to leave it "on" overnight to keep it as warm as it gets in the afternoon. Will take more electricity. But eventually it will need to be repaired, or replaced with a lightly used equivelent. It may be less costly than repair.
May 07, 2015 | Minolta Office Equipment & Supplies
MMY COPY MACHINE IS CSPRO MODEL EP 3010 MINOLTA APER ERROR CODE C061
Lens Motor, under the big glass is to your right is the lens assy. there is a motor that works the mirrors on that side it is either jammed or burned out. Or worse case the board controlling it is bad. You have a Legacy Minolta Machine, get a tech out (Old School one:))
Jun 02, 2014 | Konica Minolta Office Equipment & Supplies
Minolta cspro ep 6000
what is the code 0070 ??? what about the motor?????
Apr 18, 2014 | Konica Minolta Office Equipment & Supplies
Minolta ep 3010 error code c920
DO you mean a Di3010 or EP 3010 totally different one is anaolog the other digital?
Jul 13, 2013 | Minolta Di3010 Copier
Sir/mam which is it EP3010 or Di3010 one is digital the other anolog
Detaile of Code of Minolta Ep 6001 coper
pleas send me cs pro 6001 code 611 salvation
Feb 12, 2011 | Garden
Problem in minolta cspro 2050
Aug 19, 2008 | Minolta EP4000/5000 CS/PRO Copier
319 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
