Question about Peg Perego John Deere Gator HPX Ride on Toy
Toy making loud clicking/clanking noise when driving...awful sound. Does the motor/gearbox assembly need to be replaced? Is this the correct part? I also see just gearbox parts. When purchasing these parts, do instructions for replacement come w/them?
    Genius:
  • Peg Perego Master
  • 1,508 Answers
Yep you have a bad gearboxes, you can order replacements here www.powerwheelsoutlet.com
Posted on Jun 12, 2012
3 Suggested Answers
  • 156 Answers
SOURCE: I need the instructions to assemble John Deere
I had the same problem and needed a parts list so I finally found it at
this peg perego parts site
the company is
http://www.shopjandl.com/fius0101g24.html
and they were really helpful with my other repairs
Hope this helps
Posted on Mar 16, 2010
Ironfist109
  • 3018 Answers
SOURCE: have 12 v gator it grinds uphill...is it gearbox
  • Hope this helps.
Regards,Tony
Posted on Oct 04, 2011
Loud grinding noise and won't reverse
if it is a 4 wheel drive sounds like your rear axle may have been cooked do to low fluid bad bearing or both check fluid level nad look for any kind of metal specs in fluid .
Jan 17, 2014 | Chevrolet Tahoe Cars & Trucks
12 volt gator makes loud winding noise from rear wheels when driving
you'll need to replace the gearboxes or motor, the easiest way to test this would be to remove the rear dumpbox and then lift up the panel above the motors this will give you access to the motors then disconnect one and see if the problem persists if not reconnect the motor adn then disconnect the other side and test again, hopefully its just one of the gearboxes
May 01, 2012 | Peg Perego John Deere Gator HPX Ride on...
When i accelerate there is a loud clanking sound from engine i guess
Possible the faults can be related to the following:
1. check the clutch settings- if the clutch is slipping this noise can come up. release the clutch very slowly and check if the noise reduces.
2.Possible that the drive links, the drive shaft , bearing assembly is faulty.
3. Possible there is loose linkages on the brake assembly which could get into the movement of the wheel and make noise.
4. The noise can be within the engine, possible that the belt slipping, water pump bearings, alternator bearings or idler units.
Mar 03, 2011 | 1995 Mitsubishi Diamante
Loud clicking/clanking noise on 200 Intrepid
Sounds like the motor is going out. 2.7s are bad about rod bearings going out. If you don't use the correct weight oil, and change it every 3K, they don't hold up too well.
Jun 08, 2009 | 2000 Dodge Intrepid
Machine makes loud grinding noise and the drum will not spin.
Ok, your direct drive system is experiencing gear breakdown issues. the transmission(gearbox) is stripped and causing the grinding situation. The clutch is ruined as well. you may have some minor electrical motor trauma as well. i recommend disassembling the unit if possible, to inspect the direct drive and transmission/clutch assembly. you should see the drive/transmission under the drum assembly.
Check thoroughly for trauma spots. replace the direct drive assembly if damage is noticed.
There should be some kind of oil leakage around the drive assembly. inspect the motor as well.
If the motor is not smoking or humming, it should be fine. More than likely, it will be the drive and transmission assembly that will need to be replaced.
Please rate and have a great day:)
May 13, 2009 | Fisher Paykel EcoSmart GWL15
Loud clanking noise in dishwasher
Most likely the motor as food caught in the sump would not make a noise you described.
http://tclaundryrepair.com/home
Feb 19, 2009 | Kenmore Dishwashers
Kensmore 70 series
Often times, the coupling is not fitted completely, and the excess pressure is binding the motor or gearbox up
Not a guaranteed solution, but something to check
reopen the case and motor, and use a dowel and hammer to ensure the spiders are fully pressed onto the gearbox and motor shafts
Jun 30, 2008 | Kenmore 15864/15862 Top Load Washer
Engine knocking in front
if the sound is a constant clanking and its awfully loud and people turn their heads when you drive by....and its coming from the front, its most likely the harmonic balancer
Jun 24, 2008 | 1991 Oldsmobile 88
Kenmore washing maching 25862
yes you need to replace the motor coupling between the motor and transmission let me know how you make out
Dec 21, 2006 | Kenmore 25862 Top Load Washer
Peg Perego John Deere Gator HPX Ride on Toy Logo
168 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
