Question about Manitowoc - QD-0212A/115-1
I have a manitowoc qd0212 and the machine comes on and will do one prop of ice then qit producing. Can you give me some advice on what could be wrong?
4 Suggested Answers
  • 112 Answers
SOURCE: manitowoc ice maker does not produce ice
If it doesn't run at all open the front panel and peer inside of the control box. See if there are any indicator lights on the control board lit or blinking. Check the plastic water curtain on the machine and make sure that the magnet is in place on the bottom right. Will need more information as to what lights are lit. Printed on the board next to each light is its corresponding function or response.
Posted on Dec 11, 2010
  • 112 Answers
SOURCE: Manitowoc Ice machine only makes 2/3 bin of Ice
The unit shuts off based on the magnetic reed switch in the plastic curtain on the front of the evaporator. If the ice is not falling as one single sheet with about 1/4"-3/8" of a bridge conecting all of the cubes then the ice is too thin. When the ice falls (in a single sheet of ice) if there is enough ice in the bin to hold that ice up and keep the curtain open the unit shuts down. A full bin may only be what appears to be 2/3 or 3/4 of a bin full because the ice sheet is propped up behind the curtain. If the ice sheet is too thin and does not fall as a single sheet more often than not a single cube or a piece of a cube can get caught between the curtain and the evaporator plate. This can shut the unit down for several hours until that piece melts and the curtain closes again.
Posted on Jan 04, 2011
  • 22 Answers
SOURCE: My Manitowoc Ice machine is making ice slowly and
You're bridge thickness is set to high, lower the bridge on the sensor located when you open the front door behind the water curtain on the top. If the sensor is scaled badly replace it.
Posted on Feb 14, 2011
Ice machine manitowoc gets stuck when full of ice why?
Service Literature Downloads - Manitowoc Ice
www.manitowocice.com/minisite/service/servicedownloads
Manitowoc Ice has a complete library of service documentation offered in two different formats. First, Interactive Electronic Document Catalog (EDC). Second .
Aug 25, 2015 | Kitchen Appliances - Others
My manitowoc new ice machine is not making ice
Its plug and play. You need to call who ever sold it to you and have it checked out its under warranty.
Sep 24, 2014 | Manitowoc Indigo Ice Machine - Full Dice,...
Manitowoc troubleshooting
Clean the condenser thoroughly, descale and sanitise the waterways inside.
Feb 15, 2014 | Manitowoc Ice SM-50A Undercounter Ice...
Manitowoc Ice Maching. Model B400. Water comes out instead of ice.
that is a 400 lb. per 24 hours machine. can you explain the problem in further detail.
Sep 18, 2011 | Manitowoc Heating & Cooling
Manitowoc Ice machine only makes 2/3 bin of Ice and shuts off
Dec 19, 2010 | Manitowoc - QD-0212A/115-1
Manitowoc ice maker does not produce ice
Nov 11, 2010 | Manitowoc SY0454A S Series Ice Maker...
Manitowoc QY1304A Ice Machine Compressor will not start
Does the compressor make any noise at all?
You can ohm out the compressor windings. I dont know off the top of my head which compressor manufacturer they are using but if it is Copeland you can get an electrical handbook and it will have ohm values for the compressor. If not assume the rule of thumb Common to Run is X, Common to Start is Y, Start to Run is X+Y, and Y should be 3 to 5 times whatever X is. On Rx10,000 scale check each terminal to ground should be open.
Aug 06, 2009 | Ice-O-Matic ICEU220HA Undercounter Ice...
Manitowoc ice machine that will not produce ice
This is odd that Manitowoc is listed on a page showing a Whirlpool refrigerator model and number. What is the model number listed on your Manitowoc? Not the base model number. The number listed inside the top section. Manitowoc has a really good service reputation. Their control boards have a series of self diagnostics. Get me your model and we will go from there. Sea Breeze
Jun 11, 2009 | Whirlpool ES5FHAXS Side by Side...
Manitowoc - QD-0212A/115-1 Logo
64 people viewed this question
Top Manitowoc Kitchen Appliances - Others Experts
John Tripp
John Tripp
mike cooper
Dan Webster
Dan Webster
Are you a Manitowoc Kitchen Appliances - Other Expert? Answer questions, earn points and help others
