Question about Mitsubishi WS-65515 65" TV
Green light flashs even after reset button is pushed what should i do
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 453 Answers
Need to replace bad capacitor on dm board witch look like leki a cable box , this is inside the tv 7 bad capacitor 1000uf at 25v original on tv are 1000uf at 16v
Posted on Mar 16, 2011
P1102 reser counter
  • I take it you are refilling the toner cartridge...
  • Switch the printer off.
  • Press and hold the green button on your printer and turn the printer on. You will see that the lights flash for a moment and then turn off. After a few seconds, the attention light will turn on followed by ready light and the green light. Keep pressing the green button. In a few seconds, the attention light and the ready light will turn off.
  • Push the toner rotate button while you continue pressing the green button. As you briefly push the toner button, you will see the light flashing. Release both the toner button and the green button.
  • Repeatedly push the red button (cancel button). Now all the working lights on the printer will turn off.
  • Open and close the lid of HP printer once. The light will start blinking.
  • Press the green button. Your HP toner cartridge chip will be reset.
  • Apr 25, 2014 | HEWLETT-PACKARD Hewlett Packard P1102...
    Is not working more
    Jan 29, 2013 | HP DeskJet F4280 All In One Printer InkJet
    I recently replace the battery in my 2005 Ford Mustang GT. After I installed the new battery the green light for my dealer installed alarm keeps flashing even when I am driving the car. I went to the...
                  Hi
                  Before Battery Change
                  • When was/or when did you notice alarm green light illuminated?
                  • When after alarm was disarmed, did green light shine?
                  First thing to check would be electrical connections starting from the battery.
                  1. Follow positive wire lead from battery to fuse box connections. (Should be along driver side frame rail, or near battery.)
                  2. Follow wrie harness to Relay Center. (Find Alarm Relay/Fuse)
                  3. Also to Power Distribution Center. (upper driver corner engine bay)
                  Relay Switch and Fuse to Alarm should be okay, given the alarm green light illumination.
                  The Cars Brain, ECM Engine Control Module, manages messeges between power BattV and Alarm, also other modules and various sensors throughout the vehicle.
                  When Battery Supply was disconnected, something happened, that stunned the memory in the ECM.
                  Yes, the alarm does need resetting, its actually the memory messages saved in ECM need to be Refreshed.
                  (saying "alarm needs resetting") sounds like alarm is broken, when that is not the case. Similar scenario is, when smart phone screen webpage freezes(alarm memory info in ECU). No buttons work, not even power button (Key Fob control). Only way to gain access is to remove battery.
                  Lets try an experiment, this will be to loose still/saved frozen information, stuck in computer memory.
                  How to Reset Vehicle Computer.
                  1. Remove Neggative Post connection.
                  2. Remove Positive Post connection.
                  3. Let vehicle sit over Two Minutes, this time allows capacitors in vehicle Modules (ECM/PCM, TCM), to release any/all stored voltage, also any voltage in Vehicles ground circuit will be released.
                    • (I would typically wait 15 minutes) Capacitors with out constant Voltage input, will disipate rather quickly, depending on capacity size.
                  4. With Battery Still Disconnected. Open Driver Car door, and turn Ignition to RUN Position.
                  5. Reconnect Positive Post.
                  6. Reconnect Negative Post.
                    • IGNITION is in RUN Position, when reconnecting Battery. Driver Door Is Open.
                    7. Turn Ignition to Off.
                    • Notice if alarm green light is illuminated.
                    8. Hit LOCK Button On Driver Door Switch to Reinitialize Alarm.
                    • Be SURE Key Fob not locked in car.
    Mar 26, 2017 | 2005 Ford Mustang
    Green flashing light on front does not stop flashing even after pushing reset button
    gotta be a mitsubishi tv.problem is most likely dm board with swollen caps 1000mf/16volt use25volt caps
    Sep 01, 2009 | Televison & Video
    Light flashing and tv won't turn on
    Hi there, I have a Mitsubishi HDTV 1080 and when I tried to turn it on the tv this morning it wouldn't turn on and the power light is flashing green. I pushed in the reset button but it just keeps flashing and still won't turn on.
    Oct 05, 2008 | Mitsubishi WS-55513 55" Rear Projection...
    Error number 1700 canon s9000 printer
    knowing printer manufacturers I doubt they even have a sensor to detect that its full at all, they probably based on something crumby like print count. here are some instructions to reset the waste ink tank, the instructions vary so try them until one does the job :
    Waste Ink Tank Reset
    1: Power off printer
    2: Hold Resume button then press and hold POWER, the beeper will sound once.
    3: Hold POWER and release RESUME
    4: Press RESUME twice, then release all buttons
    5: When the indicator lights steady, press RESUME three or four times. The indicator should be orange.
    6: Press Power to set data
    1. Turn off printer
    2. Hold down Resume button and press Power button.
    3. Keep holding down Power button and let Resume button go.
    4. Press Resume button 2 times then let BOTH buttons go.
    5. Green lights will flash and then stop blinking.
    6. When green lights are solid, press the Resume button 4 times.
    7. Press the Power button and the printer should turn off, if not, press the Power button once more.
    8. Your printer should respond as normal.
    1. power off Printer
    2. Push and hold resume button and push power button
    3. Hold Power button and release Resume button
    4. Push Resume button twice ( 2x ), and now release resume button and power button
    5. Green light will blinking and stop.
    6. When green light on, push resume button 4 x
    7. Push Power button and printer will off, if that isn't off, push power butto again until print off position.
    Aug 20, 2008 | Office Equipment & Supplies
    Tv problem
    can you tell in what patter does the light blinks??
    Mar 11, 2008 | Mitsubishi WS-55613 55" Rear Projection...
    Tv problem
    How can this be a generic problem? I had a flashing green light on a Phillips PTV it had a bad solder joint on one of the pins to an optic isolater.
    Dec 13, 2007 | Televison & Video
    Mitsubishi WS-65515 65" TV Logo
    106 people viewed this question
    Top Mitsubishi Televison & Video Experts
    matt martin
    matt martin
    Jaime Hernandez
    Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
