Question about Dell Inspiron 1501 Notebook
My Dell insprion 1501 was showing a messag everytime i turned it on "Battery nor recognised, system will be unsable to charge battery" However, i pressed enter, ignored this messgae and it was fine. the other day i turned it on, had the same message and this time it didnt charge up. The led on the Adapter is still green. someone told be to run a bios from the dell Website (A16 i think), in the process of running this bios my computer shut down and wont turn back on? any solutions? Do i buy a new adapter and Battery? or is it the motherboard? or entirly different issue? Thanks Amanda
  • 65 Answers
You can buy a new battery that is compatible for your computer
to know the details you can visit this website support.dell.com
Posted on Mar 16, 2011
Hi, I have a Dell Inspiron 1501 laptop, model no. PP23LA. My problem is that the system does not recognise the power adaptor/charger & will not charge the battery. The laptop will run with the power...
If the battery is not charging, the problem is most likely the battery...not the charger. Check around to see if you can get a battery replacement I think would be your best course of action. If you have a friend with a model laptop with the same battery you could always "test out the scenario" before purchasing one.
Good Luck
May 19, 2011 | Dell Inspiron 1501 Notebook
I am using a Dell Laptop and it is inspiron 1501. But its battery is not charging. I get 2 error message the adapter can not recognise... The battery can not recogise.. Something like that. The laptop gets...
try to remove the battery from the computer, after unplugging it, plug in the AC adapter without the battery and check if it will turn on. if it doesnt then 2 possible reason
1. the AC adapter is busted, you can try a known good Dell AC adapter. if its still now working with a know good AC adapter then
2. its the motherboard that needs to be replaced.
Hope this help
May 19, 2010 | Dell Inspiron 1501 Notebook
I bought a new dell charger and it's not being recognized.It's a PA-12 family charger and in the list is supposed to work with my 1501 Inspiron. Tried bios update.Microsoft ACPI is 6.0.6 already to.
Check in BIOS and see whether its recognised there..If its not, it could be the Motherboard which is the culprit here...if system is Out of Warranty, and its charging, then forget the recognising issue...other Contact Dell's Out Of warranty for repair options.Would suggest using Dell spares for the system than going with other 3rd party supported adaptors
Dec 26, 2009 | Dell Inspiron 1501 Notebook
My dell 1501 does not recognise its battery on start up, and does not charge the battery either
if youre battery does not charge and is not recognized by your laptop then its time to have it replaced or fixed, you will always need to plug your laptop in order for to you use it which is sometimes annoying, have it replaced
regards
michael
Nov 20, 2009 | Dell Inspiron 1501 Notebook
Laptop not turning on
If you replace the main battery and it will not charge, make sure the AC adapter is working (You can test the output with a multimeter) and make sure the LED on the Adapter stays on when connected to the system. Most likely, the motherboard has failed and will need replacement
Sep 14, 2009 | Dell Inspiron 1501 Notebook
DELL XPS 1210 i purchased a replacement battery not recognised
If the battery is not detected in the BIOS (F2 at boot) and doesn't show as charging, then return the battery and get a replacement.
If neither the original battery or the new replacement battery are not detected in the bios a problem with the motherboard may exist. If still under warranty, contact Dell Support for a repair, if not, then you may be investing in a new motherboard
Jan 29, 2009 | Dell Inspiron 1501 Notebook
Dell Inspiron 1501
Are you using the original charger or another. The Dell power system will give this message when you use a 70W charger on a system that needs a 90W charger - check the sticker on the back. Also, if the plug to the main board gets just a little loose you will get this message. Be careful you are not putting too much strain at the power plug or you will need a repair soon!
Jon
Dec 31, 2008 | Dell Vostro 1000 Notebook
Replacement battery for Dell Inspiron 1501 won't charge
If your old battery was doing the same (not charging), then is is because the charger is not charging the battery. Do you have a friend with a Dell laptop? Maybe you can use a borrowed charger to test and see if it will charge the batteries. To answer your question , no Dell does not have anything built in to prevent you from using a 3rd party battery.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 28, 2008 | Dell Inspiron 1501 Notebook
Dell Inspiron 1501
sounds like a dead cell in battery try replacment battery batterys can still show good even if they have a dead cell
May 31, 2008 | Dell Inspiron 1501 Notebook
Dell 1501 battery recognition
Hi
please check for update your bios dell.com.
Thanks
Mar 16, 2008 | Dell Inspiron 1501 Notebook
Dell Inspiron 1501 Notebook Logo
91 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
