Question about AT&T Lucent MLS-12D Phone
Lines ring to a certain group and I need to change a phone from group 73 to group 72 - how can I do this?
  • 79 Answers
From Ext 10 or 11>
Dial feature 00>
Hit the left intercom button twice>
The display will show "System Programming"
To remove the Ext. from group 73
Dial #502>
The display will show 'Group"
Dial 3 for group 73
The display will show "Extension"
Dial the Ext # of the phone that needs to changed
Dial 2 to un-assign the Ext from Group 73
To add the Ext. to group 72
Dial #502>
Dial 2 for group 72
Dial 1 to assign the Ext to Group 72
Dial Feature 00 to exit System Programming and save the changes
Be sure to ask me if you need more information
Posted on Apr 23, 2011
Hi I have a Panasonic KX-T7667 Telephone and it rings for intercom calls, but for external line calls it won't ring, I just get the flashing lights for the phone line. I have tried the volume...
Solid lights mean it's not programmed in the ICD group. Depending on the issue of your system cabinet, ICD ring group pilot numbers begin with 600 or 601 and grow to as many as you need. Each phone that rings has to be a member of the group and you can program it to not ring, ring immediately, or a delay of up to 6 rings. In my office system ICD group members are assigned in system program 620.and the ringing is programmed in 621. It's not entirely friendly to change it by hand as the tables are assigned by group and position, but it can be done.
It's an installer function and requires the system password or permission to change it.
Carl
Jun 19, 2011 | Lands Phones
I have 3 CO lines coming in. I want the 3rd to be available, but not to ring (it is the fax line). How can i have the first two ring, but not the 3rd?
TDA ringing is controlled by ICD groups. If the fax is part of the system (an extension) then you need to set up an ICD group (like #2) that puts the fax extension in it and rings only the fax. If your fax is external to the phone system but you still want to use the fax line, then you take the incoming CO out of any ring group at all (leave the column blank). All of this requires installer access or a really good read on the PTPM manual.
Carl
Mar 30, 2011 | Panasonic KX-TDA50 Phone
We've added 2 extensions in the office, but we can't pick up external calls on them - how do we add them to the group call facility on the T7633
The extensions need to be added to the ICD group and given either an Immediate or some ring delay. It's fairly easy to tell because if they're not in the group the line is red and doesn't blink on incoming calls. By default ICD group 1 is access code 600 or 601(try dialing it on the intercom from any phone and see if your phones don't start ringing). Unfortunately, you need higher level access to modify ICD groups. It's either done from the programming tool, or a phone with a class of service allowed to make such changes.
Carl
Mar 23, 2011 | Panasonic KX-T7633 Corded Phone
We have 4 Panasonic KX-T7736 phones. We have 5 phone lines on these phones. Only one of them can answer all 5 lines. The others can only answer their specific line. Is there a way for all 4 phones to...
There is. If your question is really "can I do that" then it's a different answer. You need access to installer programming to assign all of the lines into the same ICD group. By default, ICD group 600 is the first ICD group and it has the ability for you to put all members (extensions) into it with either a direct or delayed ring. Putting those phones into an ICD group that's assigned will make the phones blink or ring on an incoming call.
Needless to say, any further programming is beyond the scope of a free forum as it is a dealer function.
Carl
Mar 16, 2011 | Panasonic KX-T7736 Corded Phone (KXT7736)
Partner ACS phone system won't fwd calls to mailbox
If they want all calls to be answered by the general delivery mailbox only them you need to change the Group Distribution (#206) on all the lines in group 7 from (1) assigned to (3) VMS Line Cover and also change the Line Coverage Ext (208) on all lines to ext 10
Dec 18, 2009 | Comdial Avaya Partner ACS Phone
I have a Samsung iDCS system. We have a phone
This clip shows how to add a phone to the group, so just reverse the process to remove a phone from the ring group on Samsung iDCS. This also works on other models from Samsung. There are loads more clips at www.AbbeyTelecom.com which you may want to "bookmark".
Oct 12, 2009 | Samsung DCS 12 Corded Phone
Trying to make every phone ring when the main phone rings
Well that is better than most people in finding the arrows...
Ok, first you need to know the extensions that you want to program to ring, and the lines, record these numbers... if you do not know the extension numbers and actual line numbers; going to each set, and doing a FEATURE * 0 and the Intercom and line buttons this will tell you the extension number and line number (this also tells you what is on every button).
Then goto your set and put in:
-> FEATURE 2 6 6 3 4 4
-> Password: 2 6 6 3 4 4
Now you will have to look at your LCD for 3 arrows
<- Heading....Enter->
<- Back .......Next->
You will not see these words in the LCD display, you just have to look for the arrows that correspond.
-> you will now see “TERMINALS&SETS” and press Enter (the top right arrow key)
-> now put in the extn that you want to change (Eg. 227).
-> you should now see the extension number “227: NAME”
-> press Enter (the top right arrow key) again
-> you will now see “LINE ACCESS
-> press ENTER
-> you will now see “LINE ASSIGNMENT
-> and Enter
-> now you can type in the lines that you want to ring on this extension (Eg. 025 for line 5)
-> hit CHANGE till it says "APPR&RING" (Appear and ring means that the line will have a button on the set)
-> hit NEXT to save changes
-> press FIND to look for more lines and change the appropriate lines to appear and ring
-> then the RLS button (the little orange button) to exit programming.
After this programming is done, dial Feature * 0 and look for these new lines.
Good luck.
May 05, 2009 | NorStar Meridian M7310 Phone
Ringing & voicemail transfer for DCS
I would need to know what group your lines are ringing in to.(Look at the phone display on any ringing phone and it will tell you the "ringing group" probably 500, 501 etc.) With that known we can add all three stations to that group and mark the "NEXT" option to go to station 202. Just have 202 forwarded to voice mail on a NO ANSWER condition and it will work for you
Nov 14, 2008 | Samsung DCS 12 Corded Phone
Changing Ring Tones
If you're using Nokia fone, go to Contact through the menu and select Caller group. There you'll be able to customize groups for your user. Select a group and customize/edit it.
Aug 21, 2008 | Meridian Two-Line Corded Business phone
Only First Phone in the system will ring on incoming calls
These manuals are available on the norstar web site.
Jul 08, 2008 | NorStar M7310 Corded Phone
AT&T Lucent MLS-12D Phone Logo
188 people viewed this question
Top AT&T Lands Phones Experts
george  peters
george peters
Paul C.
Level 1 Expert
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
