Question about Excalibur MARS-32 Car Alarm - Rem Start 2way LCD
While driving my engine shut down and will not attemp to start
  • 17,970 Answers
Sound like a problem with the ANTITHEFT system or re-program request.
Keep us updated.
Posted on Mar 16, 2011
My 96 Ford windstar was running just died in the middle of the street I bought a computer thinking that was the problem it cranks but won't fire
Ford Windstar Starting/Stalling Problems - Edmunds.com
forums.edmunds.com > Ford > Ford Windstar
Oct 16, 2007 - 31 posts - ‎26 authors
Learn more about Ford Windstar at the Edmunds.com Car Forums! ... Then on Friday it died while I was driving down the street. ... I have a 3.8L v6 1996 Ford Windstar. .... Then yesterday the car just died while driving and had to be towed back to .... The engine will crank, start run about 5 seconds then stop.
Fixing A Car That Randomly Dies While Driving - YouTube
? 3:59
https://www.youtube.com/watch?v=zwlruD4JXmY
Jul 20, 2010 - Uploaded by Scotty Kilmer
Fixing A Car That Randomly Dies While Driving. Scotty Kilmer ...Just check it out at https://www.youtube.com ...
2002 Ford Windstar Engine Stalls/Shuts Down While Driving ...
www.carcomplaints.com/Ford/Windstar/.../engine_stalls_shuts_down_wh...
The 2002 Ford Windstar has 11 complaints for engine stalls/shuts down while driving. ... 2002 Windstar just starting shutting off in the middle of driving. ... The engine diesupon acceleration and will crank but won't start unless switch is ... Inspected the Fuel Pump shut-off Switch, Fuel Filter, Run several full tanks of gas ...
Jan 26, 2016 | Ford Cars & Trucks
2005 focas ,driving down the interstate my car just shut off I noticed that there was a hole in my oil filter replaced oil filter and oil but still won't start motor turns freely
2001 Ford Focus Engine Stalls/Shuts Off While Driving: 18 ...
www.carcomplaints.com/.../Focus/.../engine_stalls_shuts_off_while_drivi...
I'd be driving down the interstate and my car would start sputtering like it was out of ... Mountain Hugh Howel Rd. Hill in my 2001 Focus and the car just cut off.
2005 Ford Escape Engine Shutdown While Driving: 24 ...
www.carcomplaints.com/.../2005/.../engine_shutdown_while_driving.sht...
The 2005 Ford Escape has 24 complaints for engine shutdown while driving. Average repair ... This problem caused my car to quit while driving down the road, it could have ended in and accident. ... I was 80 miles from home when the engine shut off. ... Was going to take it to the mechanic on Monday and the car just died.
Engine revs and loses power when driving. - CarGurus
www.cargurus.com > Questions > Ford > Focus
CarGurus
Jan 05, 2016 | Cars & Trucks
Ssangyong Kyron 2007 shuts down when driving
run fault codes and look for a problem with the TCM ( possible reading and engine over speed which shuts the engine down)and it should re-engage gears immediately upon reselection
Feb 09, 2014 | 2007 SsangYong Kyron 2.0D
2001 4.0 ford. Engine has had rough idle at cold start up for a few weeks now it will only attemp to start up but shuts down in 5 or 6 seconds. can any one help with this problem I'am having.
Is your check engine light on? if so have you had the codes read? If not have it done and post the codes here. cannont conclusively say what is causing that until that is done...
Jun 09, 2012 | 2001 Ford Explorer
Have to make several attemps to start, at first just clicks then will start
if its diesel it sounds like could be the glow plugs not sure both problems are related
Jun 06, 2012 | 1999 Buick LeSabre
P0300 engine would not start. engine not turning over
This code means that the engines computer has detected that not all the cylinders have have been firing correctly. It can be caused by a number of things but start by checking your ignition circuit eg plugs, leads, coil etc. If you have a spark the enine should start.
It seems you now have a flat battery so you will need to get it charged up or get a booster start from someone. I think you will find that with a good battery the car will go, especially if you use a little starting fluid. Once it is going you can investigate the misfire problem.
Aug 19, 2009 | 1996 Chevrolet Blazer
My 2000 Jimmy won't start, I can hear the fuel pump running and then shutting off before I attempt to start the engine. I also hear it running while I attemp to start the engine. The engine won't start...
The pump is working normally the reason it stops before you start the engine is it has built up enough preasure and cuts out. When you turn over the engine it starts up again as the preasure goes down when the carburator open's. The pump only helps the fuel from the tank. It seem's like dirt in your carburator. The reason it wont start after 3 minutes is the excess petrol in the carburator has evaporated hence need to pour more in. Check all pipes filters and carburator for dirt.
Aug 06, 2009 | 2000 GMC Jimmy
Engine shuts down when driving. will start after shut down. This happen repeatedly.
  • make sure that engine is in proper condition
  • chechk for the oil count
  • check for the coolant liquid if its below the mark
Jul 17, 2009 | 1998 Honda Accord
Laptop boots up intermittently or screen freezes
basing on the information you have given here are the possible solutions:
remove any external device connected to your system (printer, external hard drive and others) if removing this does not work and still gets a blank screen with blinking cursor try to go to safe mode with networking. if successful try to download the driver for your video adapter.
when you try to start the computer , do get anything on the screen like a logo? when does the blank screen occurs, is it during the turning ON of the computer or during the windows xp logo appears on the screen?
a blank screen could be caused by the following: defective video adapter, corrupted video driver, defective memory, unknown device causing the issue like the hard drive, optical drive or other peripheral installed inside the computer.
try also using an external monitor
Sep 19, 2007 | Toshiba Satelite 5205-S505 Notebook
Excalibur MARS-32 Car Alarm - Rem Start 2way LCD Logo
51 people viewed this question
Top Mars Vehicle Parts & Accessories Experts
rdjagger
Denis FixYa...
Denis FixYa...
Brett Duxbury
Brett Duxbury
Are you a Mars Vehicle Part and Accessory Expert? Answer questions, earn points and help others
