Question about Kenmore 63942 Dryer
Kenmore series dryer. dryer will not shut off when cloths dry. is it timer or is it heat or dry sensor? thank you.
  • hidan Mar 16, 2011
    timer is working is there a heat sensor in the machine as the heat was tremendous and i caught it just in time
    Guru:
  • 262 Answers
Is the timer advancing?
If the timer is not advancing then it is bad.
If it is advancing we will need to pull the wiring diagram and do some circuit checks.
Please post answer to timer question.
Thanks.....
Keith
Posted on Mar 16, 2011
  • Keith Drake
    Keith Drake Mar 16, 2011
    First....I need to know if the timer has counted down to zero?
    There is a high limit thermostat but when this goes bad or temp exceeds rated temperature the thermal fuse blows. It acts as a safety.The heat will not come on it is is blown.
    I need to know the answer to the timer question please. And the complete model number so I can look up the wiring diagram.
    Link for all appliance model numbers.
    Please post your entire model number.
    After you have clicked on the link below....
    Just to the right of the "search" tab click on "help me find my model number"
    Just click on the model of your choice In either video or image presentation
    Then please repost the information.
    Click on the link http://www.repairclinic.com/Appliance-Pa...
    Thanks....
    Keith
    Click on the link http://www.repairclinic.com/Appliance-Parts
    Thanks....
    Keith
  • Keith Drake
    If timer counts down to zero....
    Check for a stuck/welded closed start switch with an ohm meter. Should be open ( no continuity ) when not pushed and closed ( has continuity ) when pushed.
Kenmore 110.60812990 will not stop
if it's not advacing in time dry you have a bad timer,that timer should count down no matter what the dryer is doing,if you have it in auto then it could be no heat,when it's in auto or more or less cycle the heat comes on and the timer won't move until the heat shuts down,when the heat is off timer advances,when the heat starts the timer stops,it will do this until the clothes are dry and then timer will shut off but in timed cycle,timer isn't counting down get a new timer.
Apr 05, 2013 | Washing Machines
Kenmore dryer 110.86864100 - Where is the moisture sensor?
Ain't no moisture sensor. This is is not an electronic sensing machine. It uses another method to determine dryness. An orange wire connects to the base of the heating element. The timer motor is driven by power from it in auto dry. The timer motor is VERY slow. Slower than most dryer timer motors.As the clothes get dryer the heat is not needed so the element is turned off by the control thermostat which is mounted next to the skinny white fuse on the blower housing. This allows for the turtle like motor on the timer to advance. Once the clothes get to the point of dryness the heater stays off way longer and the timer motor advances on over to the cool down and carry on over to the end of cycle. So the clothes won't always be dry due to factors like lint buildup in the blower housing, venting to outside and so forth. having said that my mom bought a brand new Kenmore dryer and I set it on 55 minutes timed drying. At the end of that them clothes is still damp. I then set it to auto dry high heat and that usually gets em dry. I think the main probo with this dryer is the thermostat ain't set as high as older models to keep the heat at a moderate temp so that the limits won't blow on models in apts and such. Just a theory.
Sep 16, 2012 | Kenmore 659 Electric Dryer
Kenmore Dryer 70 series electric-quit heating and timer wont shut
https://www.repairclinic.com/RepairHelp/Dryer-Repair-Help
This link will help you in diagnosis/disassembly/parts.
Possibly a faulty heat element is most common failure. Fix the no heat problem and the dryer should shut off ok.
Make sure you have correct voltage to the unit before tearing apart. Again visit the link above
Nov 24, 2017 | Kenmore Dryers
My Kenmore model 70 dryer works with the timer but the auto-dry feature will never turn off the dryer. I'm assuming that this is a moisture sensor problem. Info from the tag inside the dryer: type:...
are your clothes drying?when the dryer heats up the heat shuts off then the timer will move,when the heat starts the timer stops,no heat no timer movement.when did you last clean out the dryer?you need to clean out the vent line if it's a long run i use a leaf blower to clean it out,you need to clean out the duct that the lint filter slides into and vac out the inside of dryer where the motor is,you should do this once a year so you don't have a fire and your clothes will dry on time and you won't have any problems like this,try running it with the vent line off to see if this helps.you also could have a bad thermostat but you should clean it first anyway
Apr 17, 2010 | Kenmore Dryers
My Kenmore dryer (model # 11077732795) would not shut off or heat up. I replaced the timer and thermal fuse. The dryer now heats up and the timer moves but never shuts off. Any suggestions.
Just inside the drum on the front panel is a metal sensor strip that detects a change in capacitance as the clothes get dryer. When no more dampness is read the motor is energised by the moisture sensing board. Get the goop off the sensor strips so they can send a dry message.
Mar 01, 2009 | Kenmore 62602 Electric Dryer
Dryer starts drying and thinks clothes are dry, but they aren't
Check the timer, and the sensor. Sounds like it is having a problem with the timer or sensor no noticing that the clothes are still wet. Please rate if satisfied. Thank you
Feb 12, 2009 | Kenmore Elite HE4 Electric Dryer
Auto Dry not advancing
It sounds like a timer problem since it happens during timed also. Some dryers don't have an actual moisture sensor for auto dry. They work by knowing that as long as the clothes are wet the temp won't go past a certain point. As the clothes dry it trips a thermostat that lets the timer advance. Until this is fixed DON"T trust the timer to shut off the dryer. Sometimes it won't or could leave the dryer running for hours. This has nothing whatsoever to do with fuses. There are no fuses in a dryer. Just high limit thermostats and other devices that will shut off the heat but usually not the motor.
May 30, 2008 | Kenmore 73952 Gas Dryer
Kenmore 70 Series
hello,
i have a kenmore series 70's gas dryer that will not heat up when it is turned on and i am now smelling gas when i do try to dry my clothing. it was working yesterday but now this is happening? please help.
thank you,
tina
Jan 05, 2008 | Kenmore 74602 Gas Dryer
Kenmore 70 series clothes dryer
My dryer is making a loud sound while drying the clothes. The heater still works, but is just very loud while drying. What is the problem with my dryer?
Feb 15, 2007 | Kenmore 60172 Electric Commercial Dryer
Kenmore 63942 Dryer Logo
37 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
