Question about Maytag MSD2554VE (250 cu ft) Side by Side Refrigerator
I have a Maytag side by side MSD2554Arw and the water dispenses constantly. I disconnected the water flow valve to stop it. What might be the cause and how do you take the contol panel off the freezer door?
  • 1462 Answers
SOURCE: Defrost Problem
there is a drain in the middle of the defrost water collector and it is probably blocked - usually with ice. dry ot the tray and put very hot water in to melt the ice. you may have to do several times. do this until water flows away freely
Posted on Jul 25, 2007
SOURCE: Maytag Ice20 refrigerator
There's a very detailed guide explaining how to fix this yourself for about $5 in parts. Some basic experience with soldering is helpful.
My Maytag dealer did not offer to fix for free, so I resorted to doing it myself rather than spend $300-$400.
http://www.liny.net/MaytagIce2O.htm
Posted on Jan 30, 2008
22yooper
  • 828 Answers
SOURCE: maytag side by side multi problems
1. Ice maker is not cold enough to start the ice making process.
3. having to take off the back panel is an indication of a problem in the defrost system. Call to have a service tech check this out.
Posted on May 31, 2008
SOURCE: maytag side by side fridge water dispenser not working
there are two water inlet valves on the back of refrigerator, one for icemaker the other for water in door. the valve for the water inlet is plugged or the soelinoid coil is bad. replace faulty valve, usually about 20 to 30 greenbacks at the appliance parts store
Posted on Apr 09, 2009
bobicehouse
  • 1524 Answers
SOURCE: Maytag model MSD2554ARW Freezer is in defrost mode and wont
You have a bad defrost thermostat.
Posted on May 05, 2009
Ice and water light will not go out on Maytag MSD2756DEB refrigerator and no ice or water will dispense.
There's a good chance that the water filter needs replacement.
May be some other reasons. Here's page 12 of the manual, also look at page 21 for troubleshooting ideas.
http://www.manualslib.com/manual/506002/Maytag-Msd2554arw.html?page=12#manual
Aug 04, 2016 | Maytag Refrigerators
The water from the dispenser is running and i can't stop it how do you turn of???
The cause of the problem you describe could be ether water inlet valve or the water lever dispenser switch.Locate the water valve at the back of the refrigerator, open the water and take off both plugs from the valve. If the water flow want stop replace the water valve. If it will, replace the water lever switch.
Mar 24, 2013 | GE GSL25JFPBS Side by Side Refrigerator
I have a maytag dual cool side by side fridge, recently the ice maker has reduced ice production and the ice cubes are not fully formed ( Almost hollow). When you use the water despenser it makes a...
It sounds like you have a water flow problem. I would inspect the unit for ice building up in or around the freezer fan motor. If the ice is forming in side the freezer, the trouble could the a restriction in the fill tube. But this does not affect the water dispenser. The noise you hear could be the water line moving when water flows through the line, or your water valve itself could be the problem, like the valve shutters when in use.
The valve is easy to check, its located behind the unit in the back left corner. Remove the screw holding the valve in place, while dispensing water hold the valve and see if the issue is only the valve. If the valve is the issue this could cause both problems you have. Part number 67005154
Water Valve
Good Luck
Aug 21, 2011 | Maytag Refrigerators
Water flow is slower than the normal. we check the saddle valve, lately we changed the water filter from that day on water flow is very slow.
In some models it creates an automatic by-pass when the filter is removed. If this is one of those models remove the filter and use the dispenser with it out. If you get good pressure now, it indicates a problem in the filter housing. If it's still slow it could be due to low supply water pressure or a defective valve. You can check the water at the valve inlet and outlet. First turn the inlet (main) water supply valve off. Now disconnect the water inlet line at the valve and place the end of it in a pitcher. Turn the water valve back on and check if there is a good solid water flow. If the water flow is good reconnect the water to the valve and now take the water line loose on the back side of the valve. Activate the water dispenser and check how the water flow is coming out of the valve. You will probably need another person to help you with this check. If the water seems slow, then the valve will need to be replaced.
Jan 16, 2011 | Maytag MZD2766GES Side by Side...
Poor water flow from door dispenser
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} If you have a water filter it may need changing.
Your water line could be frozen in the door. You can disconnect the line at the bottom before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does, leave the door open till it thaws.
If it doesn't come out there disconnect it at the water inlet valve and see if it comes out there. The valve could be bad.
A strainer before the inlet valve can also get stopped up restricting flow.
Dec 13, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Water dispenser is leaking
suspect water is more of a constant drip or is it a flow but part that is probably the culprit is the water inlet valve leaking past it is probably a duel valve one side for ice-maker other water in door good luck ron
Dec 12, 2009 | Maytag MFD2561HE Bottom Freezer French...
Water not stopping coming out of the ice maker
The water inlet valve may be staying open. You can swap the wires on the dual water inlet valve and disconnect the water line at the valve which goes to the ice maker. When you try the water dispenser the water will come out there. When you stop the water dispenser, if the water at the valve doesn't stop, the valve isn't closing so you'll need to replace it. If it does stop after trying it several times then the problem is with the ice maker
Nov 05, 2009 | Maytag MSD2454G Side by Side Refrigerator
Water to ice maker does not shut off after filling tray
The water inlet valve may be staying open. You can swap the wires on the dual water inlet valve and disconnect the water line at the valve which goes to the ice maker. When you try the water dispenser the water will come out there. When you stop the water dispenser, if the water at the valve doesn't stop, the valve isn't closing so you'll need to replace it. If it does stop after trying it several times then the problem is with the ice maker.
Sep 03, 2009 | Maytag PSD2450G Side by Side Refrigerator
Built in water dispenser drips/leaks (fridge model
It is very possible that the water control valve on the rear of your refrigerator needs replaced. It would also be a good idea to install a pre-filter before the water gets to the water control valve. I believe the side of the valve that controls the water dispenser is stuck open slightly allowing water to drip. You can test by disconnecting the wires to the dispenser side and see if the drip stops. When you press dispense water the dual water control valve opens completely on the rear for the water to flow. If the seal inside is defective it will leak. Here are a couple places to finds the Dual Water control Valve
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com/
Just enter your part number or model number or click on the photo on the second site listed. They are both good suppliers. Let me know if this is helpful or if you need more help Thanks, Sea Breeze
appliancepartsoutheast@live.com
Aug 10, 2009 | Maytag Refrigerators
Watner dispenser gradually stopped working (slow flow to begin with)
you need to change the water filter, usually around $35.00.
May 23, 2009 | Maytag MSD2758GEW
Maytag MSD2554VE (250 cu ft) Side by Side Refrigerator Logo
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
