Question about CAS CL5000 LABEL PRINTING SCALE [cl5000b] Printer
U need service manual for cl5000b, i have for cl5000j but is not the same, i need to cl5000b print 10gram on label
2 partial labels being printed on 1 label
most likely to do with sensor --- label has a notch in it it in middle make sure it is clean --- do labels have a hole that align with sensor?
Look at Cleaning printer to locate sensor
http://www.zebra.com/content/dam/zebra/manuals/en-us/printer/ql-qlp-qrg-en.pdf
Mar 18, 2013 | Zebra QL420 Plus Portable Thermal Barcode...
My new hp 2035n printer give an error when i try to print. the error says: load paper to tray 1
Instructions Things You'll Need:
  • Inkjet printer
  • Labels
  1. 1
    Prepare your printer. Make sure the power is on and the drivers are installed correctly on your computer.
  2. 2
    Wait for printer to stop. Make sure your printer is idle or ready or waiting for paper to be loaded. Don't load labels when your printer is already printing or running an operation.
  3. 3
    Prepare your labels. Make sure they are all facing the same way and are right side up. The label side should be face up. Many labels have an up and a down as well, look for a "this side up" or "load this way" indicator. Or take a look at the print preview before you print and make sure your labels will be fed correctly.
  4. 4
    Find the correct paper tray. Some printers have manual feeds and automatic feeds. Refer to your manual to find out which one you should use for labels. If you are going to use the manual feed, follow the manual's instructions. However, most printers will use the automatic feed, so read on.
  5. 5
    Align the paper guide. This is a moveable piece on the paper tray. There should be markers for the width of your paper. Standard pages are 8.5 inches. Move the marker so your labels will fit.
  6. 6
    Load your labels. Place your labels in the tray so it touches the immoveable side of the paper guide. Slide the paper guide over to touch the other side if it is not already close. Do not bend the labels by pushing in too far.
  7. 7
    Find the paper thickness lever. Try looking under the door that lets you change the cartridges. Or search around on the back or side. Check your manual, too.
  8. 8
    Set your paper thickness level. Usually you'll use the standard size. However, your printer may need to use a thicker setting. Check your manual.
  9. 9
    Change your media type. In your printer settings, find the media type option. You can access settings by clicking properties or settings on the print dialog right before you print. Select "labels."
Oct 02, 2010 | HP P2035N LaserJet Monochrome Printer
1992 Honda VT 600 C Shadow emission label location
Hi, Tonycanchola for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
1992 Honda VT 600 Shadow emission label location Google Search
Fed emissions sticker location 04 vlx 600
Honda VT600C Shadow VLX Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda VT600C Owner Manual
Sep 08, 2010 | 1992 Honda VT 600 C Shadow
PRINT LABELS
You will need to use the manual feed slot which is above the paper tray.
The manual feed is meant for labels and envelopes
Dec 02, 2009 | Brother HL-5240 Laser Printer
How do I print a label on a cd/dvd
your printer does not support CD label orinting. though you can still print CD labels but with some softwares. there are HP printers that prints CD labels. Check them out.
HP Lightscribe
Use LightScribe technology to label CDs and DVDs.
HP Photosmart D5460, D5463, D5468, and D7560 Printers - Printing Directly onto a Printable CD or DVD in HP Solution Center ...
On a computer running Windows, print directly onto a CD or DVD using the HP Solution Center software.
HP Photosmart Premium C309a, C309c, C309g, and C309n All-in-One Printers - Printing Directly onto a CD or DVD - c01622666
Review steps for printing directly to a CD or DVD.
HP Deskjet 900C series printers - CD Label.
These printers comes with a special software that enables them print on CD labels. Also try to get their softwares and see if you can interface them with your own printer and them print. Else you may have to get one of these printers that support CD labelling. Cheers!
May 19, 2009 | HP OfficeJet 4255 All-In-One InkJet...
I have an Label Printer Intermec Easycoder 3400 which is kind of old (more than 8 years), and since 2 days now i cannot print anything on it (the "Empty/Pause light is always On, even if it has or not a...
the empt ause light is related to the loading of the label
turn off printer open side door and release print head feed label stock so that it stays up against the back side of the machine(left side as youface front)
Teh print head pops up like a **** shell also make sure the label stock goes under the photo eye which senses the gap between labels
There are a series of dip switches which put the printer in manual mode which is required to install labels and make sure the machine advances properly
the switch settings ar locatd on the inside for the side cover or on the very back I think manual mode is 1onat top bank and 1 on at bottom bank
Once you do this turn machine on and it shuld advance two labels and stop and green light should come on
Now you can switch the machine to compter mode ( not sure of switch setting)
If you need help yoan contact Scan Source technical support they are distributor
Good luck these are good printers and will give good service once you are familiar with them
Nov 18, 2008 | Intermec EasyCoder 3400 Thermal Label...
I-class cutting issues
You need to calibrate the printer using the instructions located in the manual. This should be in area 5.2 of the manual. If you don't have the manual you can download them at this address along with software updates and firmware updates.
http://www.datamaxcorp.com/software/i-class/
Label printers are always finicky. I have strtix printers where I work and they give off wacky errors too.
Sep 19, 2008 | Datamax DMX-I-4212 Label Printer
Can't print labels
I found out that each time you print from the manual load tray, i.e. letters and labels, once you have the paper in the manual load tray press print and then press the demo button to start the manual feed. I hope this helps.
Aug 28, 2008 | Samsung ML 1430 Laser Printer
CAS CL5000 LABEL PRINTING SCALE [cl5000b] Printer Logo
109 people viewed this question
Top CAS Office Equipment & Supplies Experts
k24674
Are you a CAS Office Equipment and Supply Expert? Answer questions, earn points and help others
