Question about Haier hwr10xc6 Air Conditioner
My window air is leaking on the inside of my house
Why is my window air leaking on the inside of the house
  • 550 Answers
Usually because the drain hole/duct/tube, on the outside is blocked, or the aircon is mounted leaning Into the house, condesate that is supposed to drip into the outer casing and run out the hole is funneled over the lowest point of the casing, the house side.
check and unblock the drain,
and ensure the aircon is mounted tilted back.
Posted on Aug 02, 2008
Some rooms in my house are really drafty, are there leak detectors that can show me where air is leaking into the house?
You don't really need a special machanism to check for air leaks in your house. The usual suspects are doors and windows. To check you can hold a candle near the door or window and if the flame flickers then you have a draft. You can also use incense to find leaks because the smoke will be pulled to the leak if the leak is from the house out, or pushed away from the leak if its air coming in from outside. All you have to do is follow the smoke.
Oct 13, 2013 | Measuring Tools & Sensors
Frigidaire FAC107S1A leaking water thru the inside of the house
Hello, first make sure the unit is tilted back in the window about a 1/4 inch. Also, check the drain on unit, sometimes they can clog and prevent condensate from draining.
Jul 31, 2012 | Frigidaire FAC126P1 wall/window Air...
Water is draining into the house?.where is the drain?
Hello, the unit must be tilted back in the window to prevent the condensate from leaking inside. Some units will have a drain plug on the bottum, while others use the condenser fan to scoop up the condensate and splash the condenser to keep it cooler and evaporate the condensate.
May 29, 2012 | Maytag M3X05F2D Air Conditioner
Leaking from inside unit
What is leaking? If it is water, you need to find the drain pipe leading from the inside unit to the outside of the house, and open up the obstruction in it. You could push a wire up through it, or send some compressed air up it. The drain pipe is probably near the ground next to the foundation or in the ceiling of an outside porch.
If this is a window unit leaking water you need to clean the obstruction out of the drain pipe or hole on the outside of the window, probably at the bottom outside rear of the unit.
I wasn't sure from your question if it is leaking water, or leaking refrigerant gas. If it's the gas you probably need to call an A/C repair service.
good luck,
genetuck
Jan 15, 2011 | Carrier Heating & Cooling
Water leaks from unit often
mcdevito75 Here, all A/C units leak water, if your unit is a window unit you"ll have to re-tilt the unit so that it is leaning more toward outside the window and not toward the inside. Contact an A/C shop in your area they come to the house.
Aug 26, 2010 | Heating & Cooling
Leaking inside house , condensation or something causing liquid to leak inside house and i have to use towels to catch fluid
Should have a drain hole on back to drain outside it maybe pluged or unit is not leveled to outside has to have a slight tilt for water to drain out not in.
Jul 11, 2010 | Sunbeam SAW10CR1FHU Thru-Wall/Window Air...
FEDDERS WINDOW AIR CONITIONER
Clean the drain so it leaks outside the house.
Jul 27, 2008 | Fedders Heating & Cooling
Haier hwr10xc6 Air Conditioner Logo
638 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Edd
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
