Question about Ingersoll Air Tools & Compressors
Unloader not functioning correctly. where can I get a service manual or parts breakdown for that compressor.
  • 90 Answers
Not sure if you can get a parts breakdown but it sounds like you may just need a new pressure relief valve. you can also try a hydraulic specialist for the manual as they usually also specialise in pneumatics which is air compressors and tools etc.
Posted on Mar 17, 2011
How to reset low unload sump
Low unload sump. Would love to help but don't fully understand question. Gas as in air conditioning or refrigeration compressors low pressure (HP/LP) devise can be auto reset or if manual reset, will have a lever or button to push. If it happens often, you will need a refrigeration mechanic.
With an air compressor, make sure there is correct oil and at right level. Unless a big industrial type, there should only be a pressure regulator to control compressor electric motor. Nothing to reset. Good luck
Herman
Nov 15, 2015 | Air Tools & Compressors
Looking for manuals for husky air compressor model FP204500AV
The manual and parts breakdown for your compressor can be found at: http://www.chpower.com/IMAGES/pdfs/manual02/608800_1102.pdf
If that doesn't work look for it on the Campbell-Hausfeld homepage at http://www.chpower.com/ under Service and Support. They have been working on the site so some links are not working correctly.
Your compressor is an oil-less type that has very little for you to do as far as service. Mostly you just have to keep it clean and occasionally drain the water from the tank. The frequency of that is dependent on where you are (humidity levels in your area) and how ofter you use it.
May 22, 2012 | Air Tools & Compressors
How can i get owners manual
Go to the Campbell Hausfeld home page at http://www.chpower.com/. Under Service & Support select Manuals/Parts Lists. Search on your model number and you'll get the manual and parts breakdown.
Mar 08, 2012 | Campbell Hausfeld 2 Gallon Air Compressor
Need instruction manual
Go to the Campbell Hausfeld website at http://www.chpower.com/ and under 'Service and Support' click on 'Manuals/Parts List'. Put your model number, WL6510, in the search box and you'll be presented with all the parts breakdowns and manuals for that series compressor. The first part of the serial number on your compressor is a date stamp so use that to determine which manual or parts list you need.
Feb 26, 2012 | Air Tools & Compressors
I need an instruction manual for husky air compressor model no. Wl651003aj
Compressor builds correct pressure but will trip rest before it can restart.
You need to check the head unloader.
Compressed air that is trapped over the piston when the compressor shuts off will be evacuated to atmosphere through the unloader valve, to prevent that compressed air pressure from adding load to the start up of the compressor motor, when the pressure switch again calls for air. For example, the last time you did a sit-up, you may have folded your arms over your chest, or if you are particularly masochistic : - ) , even held a weight to your chest. What you were doing is increasing the load against which your muscles have to work to effect the sit up.
Compressed air, captured in the cylinder after the compressor shuts off, would increase the load against which the electric motor would have to work. It may increase the load too much, and the motor may fail to start, or it may pull too many amps and fry a fuse or pop a breaker in the panel.
When the compressor shuts off, the unloader valve operates, it unloads the trapped air to atmosphere, and that problem is solved.
The unloader valve is plumbed somewhere in the line between the compressor and the compressor tank.
It is often part of the pressure switch assembly. It will, in many cases, be opened by the pressure switch, when the air in the compressor air tank reaches the set point and the pressure switch trips the power supply to the motor off, and at the same time, trips the unloader valve to open.
it is normaly on the bottom of the pressure switch it will have a small tube hooked to i
Jan 04, 2012 | Air Tools & Compressors
Can,t find replacement parts for this lemon thanks
ww.ppe-air-compressors.com/coleman-powermate-air-compressor... - CachedColeman Powermate Air Compressor Parts, Breakdowns & Manuals. Choose Your Model # Below to find Breakdowns & Repl.
I just browsed the net and found several sites that sell coleman parts. Above is just one I copied and pasted. If your unit is older, if you know the type of pump you can search for that. eg. (debilvius) A lot of compressors have the same pump under a different name like Coleman, Sanborn etc. I have found some units that are just so old they are obsolete and parts just aren't available.Hope this helps. Good luck!
Aug 16, 2011 | Coleman Air Tools & Compressors
Hard starting does this model have an unloader
There are two types of unloaders used on IR compressors. One is oil pressure controlled, and second is manually activated for starting. According to the photo and model number provided, yours is manually operated. Follow air line from compressor to tank. The pilot valve (brass valve) between airline and tank is a multi-function component. There is a flip leaver or pull ring w/ hold that unloads the compressor by venting air thru small muffler. The valve also contains the check-valve holding pressure in the tank, a means of adjusting pressure and controlls throttle for engine. For easy start, flip leaver upright and start; to run, flip leaver to right angle of stem.
Nov 19, 2010 | Ingersoll Rand 2475F13GH Ir Stationary...
Compressor wont restart because of head pressure
Piston air compressors have to unload to permit a restart, the two mot common types are an unloader valve or free air unloaders.
with an unloader valve this system uses a check valve mounted in the discharge line as it enters the tank, when the pump stops this check closes and does not permit the tank pressure to return to the pump. a unloader valve also opens to allow air pressure in the discharge line to vent, this valve is either on the pressure switch or on some models is on the pump, and is a centrifugal type.
Free air unloaders or head unloaders are a set of fingers that hold open the intake valves on the cylinders to permit the piston not to pump air against a head load, and once the pump is running the fingers retract to allow the pump to function as normal.
Jan 19, 2010 | Air Tools & Compressors
Hi - While being moved, Speedaire compressor (model 32180) fell on its side. Side opposite pulley and dammaged unit directly opposite of pulley. I have no idea what the unit is called or its function. Was...
Lee,
I'll email you the breakdown. The pump is probably actually a 3Z180, made for Speedaire by Champion. If you are looking for the assembly sticking out of the back of the pump, it is probably the centrifugal unloader, which vents the pressure after the compressor shuts down. You can get the parts from Grainger parts (888-361-8649), or your local Champion compressor distributor.
Nov 06, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
108 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
