Question about HP Photosmart C6180 All-In-One InkJet Printer
When i got to fax,fax paper gets jammed half way out.
  • 122 Answers
Hello friend, all you have to do is to check on the mechanism, by taking it out and cleaning it.
Posted on Mar 16, 2011
The printer is showing that paper jam but there is no paper in the printer.
Open the tray in the front and remove the toner cartridge, open the back panel and make sure that is is clear as well, and then slide open and closed the paper tray. Now reinsert the toner.
For some reason when this thing jams, if there isn't an actual paper jam then you have to check every panel before it will let you move on. You don't even have to remove any paper half the time...just open and close each panel and remove-reinsert the toner.
May 12, 2010 | Brother MFC-8220 Fax
Paper jam in Panasonic KX-FHD331
from person who sending fax ' please eng. hany use it good
Jul 07, 2009 | Panasonic KX-FHD331 Plain Paper Thermal...
Your document feed is separate from your received and report prints so that's why your reports are printing ok and the document feeder jams. When you open up the doc feeder and look inside the machine you will see a roller and above it on the cover that opens you will see a rubber pad. Clean both the roller and pad (in fact anything in there that is rubber) with a rubber cleaner, alcohol, or even soap and water on a cloth without it been dripping wet. You will probablt find that they are very dirty. The roller feeds the document in so that needs to be clean and the pad helps to keep all the other docs from feeding in at the same time and that should be very clean so it produces good friction.
Paper jam
Open the paper tray and remove the first couple of sheets of paper - If the paper tray is fully loaded leave it half full.
May 21, 2009 | Canon Office Equipment & Supplies
Philips Magic2memo, type PPF 456/10B
Unfortunately the machine will have to be disassembled to remove paper
Jun 15, 2008 | Philips PPF-531 Plain Paper Thermal...
Panasonic kx-fp 342 papaer jam
paper jam or missfeed always due tothe following:-
1-malefunction of paper feeding system due to broken gears belt chain please check smoth mechnical movement and apply light grease in gears and change any broken part.
2-something is blocking the paper path (staplers-pins)droped inside.
3-malefunction of paper detection micoswitch please confirm free operation for the lever in mechnical one and clean of dust and dirt from optical one,
Mar 06, 2008 | Panasonic KX-FHD351 Plain Paper Thermal...
PAPER JAM
Did not specify where it is jamming?
is the paper size correct?
is the paper under the metal tabs in the tray?
is it jamming in the fuser?
is the fuser OK, if constant jamming in fuser then replace.
Jan 06, 2008 | Sharp AR-5316 Advanced Digital Imager...
Can't print faxes due to error messages
Please check rear door area for paper, can you use manual feed slot? Power off machine with all jams removed and paper loaded, then power on, can you tell us exact error message/lights that are shown in this state?
Oct 15, 2007 | Brother IntelliFax-2820 Laser Fax
HP Photosmart C6180 All-In-One InkJet Printer Logo
19 people viewed this question
Seeker5211
Seeker5211
