Question about General Electric Washing Machines
I have a beko 1512s washing machine, it goes thru the cycle but then wont do a final empty and spin. Its not the pump and its not the brushes please help :(
    Brigadier General:
  • 6,277 Answers
Are you refering to the main motor when you say 'Its not the 'pump' and its not the brushes' or have you been able to check the separate drain pump and clean the filter, please?
Because I do not know your answers and just in case with no promises ;-0) ---------->
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter.
Here are my complete, general pre-typed guidance notes for checking both the filter and the motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 16, 2011
  • Andrea hughes Jul 22, 2011
    Im having same problem with my washing machine its a beko wm5100w. The pump is fine and has new brushes put in. It just wont drain water out. Any suggestions as to what problem could be
  • john_cross Jul 22, 2011
    Hi Kirsty, I presume it's the main motor which 'has (had) new brushes put in'? Sorry to ask but have you tried checking the drain pump action (last paragraph above), please? It's unfortunate that 'wack_sue' did not qualify the 2 thumbs up by explaining what was wrong with hers if my notes didn't clearly identify ;-0( Bear with me on this ;-0) Cheers, John C
  • General Elec... Master
  • 744 Answers
Hi if your beko 1512s washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
Posted on Feb 14, 2015
My beko washing wont do a cycle instead jumps to spin then whilst trying to do a spin it jumps all over the kitchen
Hi if your beko washing machine wont drain or has a spin problem then you have to check the carbon brushes first. there are a few possibilities here see below
Aug 21, 2014 | Washing Machines
Washer will not spin, it makes noise as if bearings have gone, empties ok and washes ok
Hi if your beko washing machine is causing a problem and wont drain or has a spin problem then you have to check the carbon brushes first.
May 03, 2014 | Beko Washing Machines
Washing machine fills with water but then won't wash, spin or drain
Hi Claire if your beko washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Jan 28, 2014 | Beko Washing Machines
Wont do final spin
Hi if your Beko WME7247W washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
you might find this test video helpful but only do it if you have checked the motor more beko test videos at site
Dec 02, 2011 | Beko WME7247W Washing Machine
My beko washing machine is stuck on the end spin cycle and stops and starts a spin in short bursts.it has water in it and wont move on from this.
Hi jennyandeddy,
Most likely your washing machine is trying to drain, but cannot, and as such cannot start to spin.
Please follow my Tip below, for detailed directions on how to access, drain & clean your Drain Pump Filter (Please Note: Your Filter compartment is located at the Bottom Right):
DRAIN PUMP FILTER
Hope this helps :-)
JEDEMEYER1
* If you found this solution helpful, please rate it
Jul 13, 2011 | Washing Machines
Drum does a small turn then stops but wont empty -wont wash either beko 1000 rpm
Hi if your beko 1000 spin washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Aug 23, 2009 | Washing Machines
Beko washing machine wont drain or spin water stays in drum
the pump itself could be blocked or broken check inside pump first for any obstructions
Jul 01, 2009 | Washing Machines
Beko washing machine wma 1512S will not spin.
hi
try changing the carbon brushes in the motor
Apr 29, 2009 | Washing Machines
Washing Machines Logo
361 people viewed this question
Top General Electric Washing Machines Experts
Dan Webster
Dan Webster
Paul Bade
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
